查看: 2840|回复: 3
单片机51+蓝牙+l298
ID:252744 发表于 2017-11-23 17:02 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include<reg52.h>
sbit PWM1 = P2^0;//右后轮电机驱动使能
sbit PWM2 = P2^1;//左后轮电机驱动使能
sbit PWM3 = P2^2;//右前轮电机驱动使能
sbit PWM4 = P2^3;//左前轮电机驱动使能
sbit motor_control_1 = P0^0;//右后轮后退
sbit motor_control_2 = P0^1;//右后轮前进
sbit motor_control_3 = P0^2;//左后轮后退
sbit motor_control_4 = P0^3;//左后轮前进
sbit motor_control_5 = P0^4;//右前轮后退
sbit motor_control_6 = P0^5;//右前轮前进
sbit motor_control_7 = P0^6;//左前轮后退
sbit motor_control_8 = P0^7;//左前轮前进
unsigned char ucBluetoothData = 230;//设置初始速度最大值为255最小为125
unsigned char ucLock = 0;//互斥量,俗称原子锁
unsigned int uiPWMCnt1 = 0;
unsigned int uiPWM1 = 230;
unsigned int uiPWMCnt2 = 0;
unsigned int uiPWM2 = 230;
unsigned int uiPWMCnt3 = 0;
unsigned int uiPWM3 = 230;
unsigned int uiPWMCnt4 = 0;
unsigned int uiPWM4 = 230;
unsigned char ucTempPWM;//设置中间变量
void initial_myself();
void initial_peripheral();
void T0_time();
void usart_service(void);
//void usart_send(unsigned char ucSendData);
void delay_long(unsigned int uiDelayLong);
void go_forward(void);//前进
void fall_back(void);//后退
void turn_left(void);//左转
void turn_right(void);//右转
void stop();//刹车
        initial_myself();
        delay_long(100);
                usart_service();
//                delay_long(500);
//串口服务函数
void usart_service()
                switch(ucBluetoothData)
                        case 0x04://前进
                                ucBluetoothData = 0x02;//避免一直触发
                                go_forward();
                                ucLock = 1;
                                uiPWM1 = uiPWM2 = uiPWM3 = uiPWM4 = ucTempPWM;
                                ucLock = 0;
                                break;
                        case 0x05://左转
                                turn_left();
                                ucLock = 1;
                                uiPWM2 = uiPWM4= ucTempPWM / 4;
                                uiPWM3 =uiPWM1 = ucTempPWM;
                                ucLock = 0;
                                break;
                        case 0x06://右转
                                turn_right();
                                ucLock = 1;
                                uiPWM2 = uiPWM4 = ucTempPWM;
                                uiPWM3 =uiPWM1 = ucTempPWM / 4;
                                ucLock = 0;
                                break;
                        case 0x07://后退
                                fall_back();
                                ucLock = 1;
                                ucLock = 0;
                                break;
                        case 0x01:
                                stop();
                                ucLock = 1;
                                ucLock = 0;
                                break;
                        case 0x00:
                                stop();
                                ucLock = 1;
                                ucLock = 0;
                                break;
                        default :
                                break;
                delay_long(100);
//                usart_send(ucBluetoothData);
                //速度调节的数据
                if(ucBluetoothData!=0x00&&ucBluetoothData!=0x01 && ucBluetoothData!=0x02 &&  ucBluetoothData!=0x04 && ucBluetoothData!=0x05 && ucBluetoothData!=0x06 && ucBluetoothData!=0x07)
                        ucLock = 1;
                        ucTempPWM = uiPWM1 = uiPWM2 = uiPWM3 = uiPWM4 = ucBluetoothData;
                        ucLock = 0;
void T0_time() interrupt 1
        TF0 = 0;//清除中断标志
        TR0 = 0;//关定时器
        uiPWMCnt1 ++;
        uiPWMCnt2 ++;
        uiPWMCnt3 ++;
        uiPWMCnt4 ++;
        if(ucLock == 0)
                if(uiPWMCnt1 > 255)
                        uiPWMCnt1 = 0;
                if(uiPWMCnt1 < uiPWM1)
                        PWM1 = 1;
                        PWM1 = 0;
                if(uiPWMCnt2 > 255)
                        uiPWMCnt2 = 0;
                if(uiPWMCnt2 < uiPWM2)
                        PWM2 = 1;
                        PWM2 = 0;
                if(uiPWMCnt3 > 255)
                        uiPWMCnt3 = 0;
              //  if(uiPWMCnt3 < uiPWM3)
              //          PWM3 = 1;
              //    else
              //            PWM3 = 0;
                if(uiPWMCnt4 > 255)
                        uiPWMCnt4 = 0;
               //  if(uiPWMCnt4 < uiPWM4)
               //         PWM4 = 1;
              // else
              //            PWM4 = 0;
        TH0 = 0xff;
        TL0 = 0x28;
        TR0 = 1;///开定时器
        TMOD = 0x01;//设置定时器0为工作方式1
        TH0 = 0xff;
        TL0 = 0x28;
        //配置串口
        SCON = 0x50;
        TMOD = 0x21;
        TH1 = TL1 = -(11095200L/12/32/9600);
        IP = 0x10;
        stop();
        PWM1 = 1;
        PWM2 = 1;
                PWM3 = 1;
        PWM4 = 1;
        EA = 1;//开总中断
        ES = 1;//允许串口中断
        ET0 = 1;//允许定时器中断
        TR0 = 1;//启动定时器
        TR1 = 1;//
void usart_receive(void) interrupt 4
        if(RI == 1)
                RI = 0;
                ucBluetoothData = SBUF;
//                uiSendCnt = 0;
                TI = 0;
//        ES = 0;
//        TI = 0;
//        SBUF = ucSendData;
//        TI = 0;
//        ES = 1;
        unsigned int i;
        unsigned int j;
        for(i = 0 ; i < uiDelayLong ; i++)
                for(j = 0; j < 500; j++);
void stop()//停止
        motor_control_1 = 0;
        motor_control_2 = 0;
        motor_control_3 = 0;
        motor_control_4 = 0;
        motor_control_5 = 0;
        motor_control_6 = 0;
        motor_control_7 = 0;
        motor_control_8 = 0;
void fall_back()
        motor_control_1 = 1;
        motor_control_3 = 1;
        motor_control_5 = 1;
        motor_control_7 = 1;
void go_forward()
        motor_control_2 = 1;
        motor_control_4 = 1;
        motor_control_6 = 1;
        motor_control_8 = 1;
void turn_left()//左转
void turn_right()//右转
收藏收藏1 分享淘帖 顶 踩
ID:265197 发表于 2017-12-22 10:43 来自手机 | 只看该作者
前来学习了
ID:74784 发表于 2017-12-19 21:09 | 只看该作者
上位机代码在哪?
ID:243748 发表于 2017-12-9 00:27 来自手机 | 只看该作者
历害了楼主
