- #include"reg51.h"
- sfr P4=0xE8;
- #define led P2/*定义P2端口*/
- typedef unsigned int u16;
- typedef unsigned char u8;
- sbit k2=P3^3 ;
- sbit k1=P4^2 ;
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- u8 code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- u8 a,b,c,d[8],e,i,r;
- void delay(i)
- while(i--);
- void InitTimer0(void)
- TMOD = 0x01; /*定时一毫秒*/
- TH0 = 0xFC;
- TL0 = 0x59;
- EA = 1;
- ET0 = 1;
- TR0 = 0;/*关闭计数器*/
- void dd()/*计算数值*/
- d[0]=smgduan[c%10];
- d[1]=smgduan[c/10];
- d[2]=0x40;
- d[3]=smgduan[b%10];
- d[4]=smgduan[b/10];
- d[5]=0x40;
- d[6]=smgduan[a%10];
- d[7]=smgduan[a/10];
- void kk()/*按键*/
- if(k1==0)
- delay(1000);
- if(k1==0)
- led=0xa3;e++;TR0=!TR0;/*开计数器*/
- if(e==2)
- e=0;led=0x63;
- }while(!k1);
- if(k2==0)
- delay(1000);
- if(k2==0)
- a=0;b=0;c=0;TR0=0;/*关计数器*/
- }while(!k2);
- void show()
- for(i=0;i<8;i++)
- switch(i)
- case(0):
- LSA=0;LSB=0;LSC=0;break;
- case(1):
- LSA=1;LSB=0;LSC=0;break;
- case(2):
- LSA=0;LSB=1;LSC=0;break;
- case(3):
- LSA=1;LSB=1;LSC=0;break;
- case(4):
- LSA=0;LSB=0;LSC=1;break;
- case(5):
- LSA=1;LSB=0;LSC=1;break;
- case(6):
- LSA=0;LSB=1;LSC=1;break;
- case(7):
- LSA=1;LSB=1;LSC=1;break;
- P0=d[i];
- delay(100);
- P0=0x00;
- void main(void)
- InitTimer0();
- while(1)
- dd();
- kk();
- show();
- void Timer0Interrupt(void) interrupt 1
- TH0 = 0xFC;/*定时一毫秒*/
- TL0 = 0x59;
- r++;
- if(r>=50)
- r=0;
- c++;
- if(c>=20)
- c=0;
- b++;
- if(b>=60)
- b=0;
- a++;
- if(a>=60)
- a=0;
复制代码 |
