可以通过按键切换不同的闪烁频率
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit LED=P3^7;
- sbit LED2=P3^6;
- uchar num=0,t=0,mode_num=0,data_H,data_L,stop_num=0;
- uchar tab[]={0xc0,0xf9,0xa4,0xb0,0x99,
- 0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
- void delay(uint k) //延时函数
- uint m,n;
- for(m=0;m<k;m++)
- for(n=0;n<120;n++);
- void Timer1() interrupt 3 //中断函数 中断方式3
- t++;
- TH1=0x3C; //计数器赋初值50ms
- TL1=0xb0;
- void T0_init() //开中断
- TMOD=0x11;
- TH1=0x3C;
- TL1=0xb0;
- ET1=1;
- TR1=1;
- EA=1;
- EX0=1;
- IT0=1;
- EX1=1;
- IT1=1;
- void display(void) //显示函数
- P1=0x01;
- P2=tab[data_H];
- delay(1);
- P1=0x02;
- P2=tab[data_L];
- delay(1);
- void dat_tim()
- switch(mode_num)
- case 1:
- if(t==20)
- LED2=0;
- LED=~LED;
- t=0;
- if(LED==1)
- num++;
- }break;
- case 0:
- if(t==2)
- LED=0;
- LED2=~LED2;
- if(LED2==1)
- num++;
- t=0;
- void data_in(void) //将a的值分割为个位和十位函数
- data_L=num%10;
- data_H=num/10;
- main()
- LED=0;
- T0_init();
- while(1)
- dat_tim();
- data_in();
- display();
- void mode()interrupt 0
- mode_num++;
- num=0;
- if(mode_num>1)
- mode_num=0;
- void stop()interrupt 2
- stop_num++;
- if(stop_num>1)
- stop_num=0;
- switch(stop_num)
- case 0:
- TR1=1;
- }break;
- case 1:
- TR1=0;
- }break;
下载:
LED不同频率闪烁.rar
(49.64 KB, 下载次数: 16)
