查看: 6841|回复: 4
【求助】51单片机电子琴,1-7按键播放音符,8按键自动播放音乐
ID:211761 发表于 2017-6-22 09:33 | 显示全部楼层 |阅读模式
20黑币
学校实训,要求51实现电子琴,要求如题。
数码管为共阴数码管,但多了595芯片
程序借鉴了一部分网上内容,目前可以实现1-7的发音和数码管显示,但按8按键却蜂鸣器长鸣,不知道什么地方出错
希望各位大神帮忙看下
#include <reg51.h>
sbit BeepIO =P1^7;
sbit DI1 =P1^0;
sbit DI2 =P1^1;
sbit DI3 =P1^2;
sbit DI4 =P1^3;
sbit DIO =P1^4;
sbit RCK =P1^5;
sbit SCLK =P1^6;
uint tune[]={0xfc44,0xfcac,0xfd09,0xfd34,0xfd82,0xfdc8,0xfe07};
uchar code num[]={
                   0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                   0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,
                                   0x00,0xff
//void KeyProc(uchar dat);
uchar SoundTH;
uchar SoundTL;
unsigned char Time;
unsigned char High,Low; //定时器预装值的高8位和低8位
                         // 音阶频率表 高八位
unsigned char code FREQH[]={
                         0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
                         0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
                         0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
                         0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
                         // 音阶频率表 低八位
unsigned char code FREQL[]={
                         0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
                         0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
                         0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
                         0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
                          //世上只有妈妈好数据表
unsigned char code MUSIC[]={ 6,2,3,      5,2,1,      3,2,2,    5,2,2,    1,3,2,    6,2,1,    5,2,1,
                     6,2,4,      3,2,2,      5,2,1,    6,2,1,           5,2,2,         3,2,2,           1,2,1,
                     6,1,1,      5,2,1,      3,2,1,         2,2,4,           2,2,3,         3,2,1,    5,2,2,
                     5,2,1,      6,2,1,      3,2,2,         2,2,2,    1,2,4,         5,2,3,           3,2,1,
                     2,2,1,      1,2,1,      6,1,1,         1,2,1,           5,1,6,         0,0,0
void delayTips(unsigned char t);
void PlaySong();
void Song()
   uchar i;
   uchar k;
   i=0;
        while(i<100)
            k=MUSIC[i]+7*MUSIC[i+1]-1;//去音符振荡频率所需数据
            High=FREQH[k];
            Low=FREQL[k];
            Time=MUSIC[i+2];          //节拍时长
            i=i+3;
                    PlaySong();
                //        delayTips(Time); //延时所需要的节拍
                 if(P0==0xef)
                   while(P0==0xef);
                   break;
  // PlaySong();
      TR0=0;
//延时函数大约约2*z+5us
void delay2xus(unsigned char z)
   while(z--);
// 延时函数大约约1ms
void delayms(unsigned char x)
   while(x--)
     delay2xus(245);
     delay2xus(245);
//节拍延时函数
    unsigned char i;
          for(i=0;i<t;i++)
            delayms(250);
    TR0=0;
//播放音乐的函数
void PlaySong()
   TH0=High;//赋值定时器时间,决定频率
   TL0=Low;
   TR0=1;      //打开定时器
void Song()
   uchar i;
   uchar k;
   i=0;
       while(i<100)
            High=FREQH[k];
            Low=FREQL[k];
            i=i+3;
   PlaySong();
void LEDIO(uchar x)
   uchar i;
   for(i=0;i<8;i++)
     if(x&0x80)
           DIO = 1;
           DIO = 0;
     SCLK = 0;
         SCLK = 1;
         x <<= 1;
//数据送入74HC595的并口输出寄存器
void LEDRCK()
  RCK = 0;
  RCK = 1;
//延时50*T时间函数
void delay_50ms(uint t)
   uint j;
   for(;t>0;t--)
   for(j=6254;j>0;j--)
/*void LEDdisplay()
  uchar i;
  for(i=0;i<18;)
    LEDIO(num[i]);
        LEDRCK();
        delay_50ms(20);
        i++;
        if(i==18)
        i=0;
   uchar dat;
   TMOD = 0X01;
   ET0 = 1;
   TR0 = 0;
   EA = 1;
   DI1 =1;
   DI2 =1;
   DI3 =1;
   DI4 =1;
   { dat=~P0;
     KeyProc(dat);
    uchar i;
    if(dat==0x00)
           TR0=0;BeepIO=1;
           return;
    switch(dat)
          case 0x01: i=0;
                     break;
          case 0x02: i=1;
                     break;
          case 0x04: i=2;
                     break;
          case 0x08: i=3;
                     break;
          case 0x10: i=4;
                     break;
          case 0x20: i=5;
                                    break;
          case 0x40: i=6;
                     break;
          case 0x80: i=7;
                 break;
          default:break;
     if(i<7)
         LEDIO(num[i+1]);
         LEDRCK();
         SoundTH =tune[i]/256;
         SoundTL =tune[i]%256;
         TR0=1;}
         {Song();
void BeepTimer()interrupt 1
  BeepIO=!BeepIO;
  TH0= SoundTH;
  TL0= SoundTL;
ID:211761 发表于 2017-6-22 13:43 | 显示全部楼层
自己顶下
ID:261683 发表于 2017-12-17 21:53 | 显示全部楼层
调试有错
ID:262881 发表于 2017-12-17 22:08 | 显示全部楼层
你按键没有消抖
ID:262912 发表于 2017-12-17 22:59 | 显示全部楼层
消抖动
