如题,12864液晶驱动资料,包括软件程序和资料
LCD12864显示图形、文字(请使用keil uvision3或以上版本打开)
- #include <reg51.h>
- #include <intrins.h>
- //#include <at89x51.h>
- sbit LCD_RS=P1^0;//定义引脚
- sbit LCD_RW=P1^1;
- sbit LCD_E=P1^2;
- sbit PSB =P3^6; //PSB脚为12864-12系列的串、并通讯功能切换,我们使用8位并行接口,PSB=1
- #define LCD_Data P2
- #define Busy 0x80 //用于检测LCD状态字中的Busy标识
- void WriteDataLCD(unsigned char WDLCD);
- void WriteCommandLCD(unsigned char WCLCD,BuysC);
- unsigned char ReadDataLCD(void);
- unsigned char ReadStatusLCD(void);
- void LCDInit(void);
- void LCDClear(void);
- void LCDFlash(void);
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
- void DisplayImage (unsigned char code *DData);
- void Delay5Ms(void);
- void Delay400Ms(void);
- code unsigned char uctech[] = {"大雄电子营业部"};
- code unsigned char net[] = {"ic2012*taobao*co"};
- code unsigned char mcu[] = {"专业元件供应商!"};
- code unsigned char qq[] = {" QQ: 571630059 "};
- code unsigned char tmp[]={//128*64点阵图形数据
- 0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
- 0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,};
- void main(void)
- Delay400Ms(); //启动等待,等LCD讲入工作状态
- LCDInit(); //LCM初始化
- Delay5Ms(); //延时片刻(可不要)
- while(1){
- LCDClear();
- DisplayImage(tmp);//显示图形
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- LCDClear();
- DisplayListChar(0,1,uctech); //显示字库中的中文数字
- DisplayListChar(0,2,net); //显示字库中的中文数字
- DisplayListChar(0,3,mcu); //显示字库中的中文
- DisplayListChar(0,4,qq); //显示字库中的中文数字
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- LCDFlash(); //闪烁效果
- //写数据
- ReadStatusLCD(); //检测忙
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_Data = WDLCD;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 0;
- //写指令
- void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC为0时忽略忙检测
- if (BuysC) ReadStatusLCD(); //根据需要检测忙
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_Data = WCLCD;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 1;
- LCD_E = 0;
- //读数据
- LCD_RS = 1;
- LCD_RW = 1;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- return(LCD_Data);
- //读状态
- LCD_Data = 0xFF;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_E = 1;
- while (LCD_Data & Busy); //检测忙信号
- LCD_E = 0;
- return(LCD_Data);
- void LCDInit(void) //LCM初始化
- WriteCommandLCD(0x30,1); //显示模式设置,开始要求每次检测忙信号
- WriteCommandLCD(0x01,1); //显示清屏
- WriteCommandLCD(0x06,1); // 显示光标移动设置
- WriteCommandLCD(0x0C,1); // 显示开及光标设置
- void LCDClear(void) //清屏
- WriteCommandLCD(0x34,1); // 显示光标移动设置
- WriteCommandLCD(0x30,1); // 显示开及光标设置
- void LCDFlash(void) //闪烁效果
- WriteCommandLCD(0x08,1); //显示清屏
- Delay400Ms();
- WriteCommandLCD(0x0c,1); // 显示开及光标设置
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- Delay400Ms();
- //按指定位置显示一个字符
- if(Y<1)
- Y=1;
- if(Y>4)
- Y=4;
- X &= 0x0F; //限制X不能大于16,Y不能大于1
- switch(Y){
- case 1:X|=0X80;break;
- case 2:X|=0X90;break;
- case 3:X|=0X88;break;
- case 4:X|=0X98;break;
- WriteCommandLCD(X, 0); //这里不检测忙信号,发送地址码
- WriteDataLCD(DData);
- //按指定位置显示一串字符
- unsigned char ListLength,X2;
- ListLength = 0;
- X2=X;
- if(Y<1)
- Y=1;
- if(Y>4)
- Y=4;
- X &= 0x0F; //限制X不能大于16,Y在1-4之内
- switch(Y){
- case 1:X2|=0X80;break; //根据行数来选择相应地址
- case 2:X2|=0X90;break;
- case 3:X2|=0X88;break;
- case 4:X2|=0X98;break;
- WriteCommandLCD(X2, 1); //发送地址码
- while (DData[ListLength]>=0x20) //若到达字串尾则退出
- if (X <= 0x0F) //X坐标应小于0xF
- WriteDataLCD(DData[ListLength]); //
- ListLength++;
- X++;
- Delay5Ms();
- //图形显示122*32
- void DisplayImage (unsigned char code *DData){
- unsigned char x,y,i;
- unsigned int tmp=0;
- for(i=0;i<9;){ //分两屏,上半屏和下半屏,因为起始地址不同,需要分开
- for(x=0;x<32;x++){ //32行
12864说明书+例子程序.rar
(608.94 KB, 下载次数: 22)
