//有些地方没删除,是调试的时候用的。请专家帮看看,为什么我写到开发板上,数码管调节时间一个暗一个亮的,
功能:显示时钟
显示日期
调节时钟日期
四位数码管显示
- #include<reg52.h>
- #include<intrins.h>
- sbit Ge=P0^0 ; //数码管段
- sbit Shi=P0^1 ;
- sbit Bai=P0^2 ;
- sbit Qian = P0^3;
- sbit SCK = P1^0; //DS1302模块
- sbit DS = P1^1;
- sbit CE = P1^2;
- sbit KEY1=P1^3; //按键
- sbit KEY2=P1^4;
- void configTime0(unsigned int ms);//配置定时器0配置中断
- void configUART(unsigned int begin);//配置UART串口通信设置波特率
- void Shownum(); //扫描函数
- void display(); //数码管刷新函数
- void Write_ds1302(unsigned char dat); //写1302函数1字节
- void Write_ds1302_CE(unsigned char cmd,unsigned char dat); //读取1302函数1字节 对命令处理
- //void read_ds1302_burst(unsigned char *dat); //burst模式读取8个字节 突发模式
- void initds1302();//初始化ds1302
- void keyset();
- void keycan();
- unsigned char Read_ds1302_CE(unsigned char cmd); //1302函数1字节 对命令处理
- unsigned char Read_ds1302(); //读取1302函数1字节
- unsigned char Smg[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};//真值表 123456789abcdefg
- unsigned char SmgI[] = {0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0x08,0x03,0x46,0x21,0x06,0x0e};//带标点的真值表1.2.3.4.5.6.7.8.9.
- unsigned char SmgTmp[8];//数码管缓存
- unsigned char Time[8]; //时间缓存
- unsigned char Tmp[4]; //调节时间的数组//0~分钟 1~小时 2~天 3~月
- unsigned char flg = 1;//决定显示日期还是时间
- unsigned char T0RL,T0RH;//重装定时器时间
- unsigned char flg0,flg1,set0,set1;
- bit backup0,backup1;
- bit gb;
- void main()
- EA = 1;
- configTime0(500);
- configUART(9600);
- initds1302();
- while(1)
- Shownum();
- keyset();
- void Shownum() //扫描函数
- static unsigned char i;
- if(flg0==0){
- for(i=0;i<7;i++)
- Time[i]=Read_ds1302_CE(i);
- gb = (bit)(Read_ds1302_CE(0)&0x01);//将ds1302秒寄存器最低位取出用于数码管中间的两个点闪烁
- SmgTmp[0]=(Time[1]&0x0F); //显示分钟,小时
- SmgTmp[1]=(Time[1]>>4);
- SmgTmp[2]=(Time[2]&0x0F);
- SmgTmp[3]=(Time[2]>>4);
- SmgTmp[4]=Time[3]&0x0F; //显示日期,月份
- SmgTmp[5]=Time[3]>>4;
- SmgTmp[6]=Time[4]&0x0F;
- SmgTmp[7]=Time[4]>>4;
- void configTime0(unsigned int m) //配置定时器0配置中断
- T0RH =(65536-m)/256;
- T0RL =(65536-m)%256;
- TMOD &=0xF0;
- TMOD |=0x01;
- TH0=T0RH;
- TL0=T0RL;
- ET0 = 1;
- TR0 = 1;
- void configUART(unsigned int begin) //配置UART串口通信设置波特率
- SCON = 0x50;
- TMOD &=0x0F;
- TMOD |=0x20;
- TH1=256-(11059200/12/32)/begin;
- TL1=TH1;
- ET1 = 0;
- ES = 1;
- TR1 = 1;
- void Write_ds1302(unsigned char dat) //写1302函数1字节
- unsigned char mask;
- for (mask=0x01; mask!=0; mask<<=1) //低位在前,逐位移出
- if ((mask&dat) != 0) //首先输出该位数据
- DS = 1;
- else
- DS = 0;
- SCK = 1; //然后拉高时钟
- SCK = 0; //再拉低时钟,完成一个位的操作
- DS = 1;
- } //最后确保释放IO引脚
- unsigned char Read_ds1302() //读取1302函数1字节
- unsigned char dat = 0;
- for (mask=0x01; mask!=0; mask<<=1) //低位在前,逐位读取
- if (DS!= 0) //首先读取此时的IO引脚,并设置dat中的对应位
- dat |= mask;
- SCK = 1; //然后拉高时钟
- return dat; //最后返回读到的字节数据
- void Write_ds1302_CE(unsigned char cmd,unsigned char dat) //读取1302函数1字节 对命令处理
- CE = 1;
- Write_ds1302((cmd<<1)|0x80);
- Write_ds1302(dat);
- CE = 0;
- unsigned char Read_ds1302_CE(unsigned char cmd) //1302函数1字节 对命令处理
- unsigned char dat;
- CE = 1;
- Write_ds1302((cmd<<1)|0x81);
- dat=Read_ds1302();
- CE = 0;
- return dat;
- /*void write_ds1302_burst(unsigned char *dat) //burst模式写8个字节 突发模式
- unsigned char i;
- CE = 1;
- Write_ds1302(0xBE);
- for(i=0;i<8;i++)
- Write_ds1302(dat[i]);
- CE = 0;
- void read_ds1302_burst(unsigned char *dat) //burst模式读取8个字节 突发模式
- unsigned char i;
- CE = 1;
- Write_ds1302(0xBF);
- for(i=0;i<8;i++)
- dat[i]=Read_ds1302;
- CE = 0;
- void initds1302()
- unsigned char dat ;
- unsigned char code init[]={0x00,0x56,0x20,0x28,0x02,0x05,0x18}; //2018 2 16 20 20 00
- CE = 0;
- SCK = 0;
- dat=Read_ds1302_CE(0);
- if((dat&0x80)!=0)
- Write_ds1302_CE(7,0x00);
- for(dat=0;dat<8;dat++)
- Write_ds1302_CE(dat,init[dat]);
- Write_ds1302_CE(7,0x80);
- void display(unsigned char a,unsigned char b,unsigned char c,unsigned char d) //数码管刷新函数
- static unsigned char i = 0;
- P2 = 0xFF;
- switch(i)//调用不带标点的数组
- case 0:Qian = 1;Bai = 1;Shi = 1;Ge = 0;i++;P2 = Smg[a];break;
- case 1:Qian = 1;Bai = 1;Shi = 0;Ge = 1;i++;P2 = Smg[b];break;
- case 2:Qian = 1;Bai = 0;Shi = 1;Ge = 1;i++;P2 = Smg[c];break;
- case 3:Qian = 0;Bai = 1;Shi = 1;Ge = 1;i=0;P2 = Smg[d];break;
- default:break;
- void displayI(unsigned char a,unsigned char b,unsigned char c,unsigned char d) //数码管刷新函数代表点
- P2 = 0xFF;
- case 1:Qian = 1;Bai = 1;Shi = 0;Ge = 1;i++;P2 = SmgI[b];break;
- case 2:Qian = 1;Bai = 0;Shi = 1;Ge = 1;i++;P2 = SmgI[c];break;
- default:break;
- void keycan()
- static unsigned char keybuf[]={0xFF,0xFF};
- keybuf[0]=(keybuf[0]<<1)|KEY1;
- keybuf[1]=(keybuf[1]<<1)|KEY2;
- if(keybuf[0]==0xFF)
- set0 = 1;
- else if(keybuf[0]==0x00)
- set0 = 0;
- else
- if(keybuf[1]==0xFF)
- set1 = 1;
- else if(keybuf[1]==0x00)
- set1 = 0;
- else
- void keyset()
- if(set0!=backup0)
- backup0 = set0;
- if(set0==0)
- flg0++;
- if(flg0>5)
- flg0=0;
- switch(flg0)
- case 1: P2 = 0xFF;Qian = 1;Bai = 1;Shi = 1;Ge = 0;P2 = Smg[SmgTmp[0]];//小时的个位
- P2 = 0xFF;Qian = 1;Bai = 1;Shi = 0;Ge = 1;P2 = SmgI[SmgTmp[1]];break; //小时的十位
- case 2: P2 = 0xFF;Qian = 1;Bai = 0;Shi = 1;Ge = 1;P2 = SmgI[SmgTmp[2]];//分钟的个 位
- P2 = 0xFF;Qian = 0;Bai = 1;Shi = 1;Ge = 1;P2 = Smg[SmgTmp[3]];break;//分钟的十位
- case 3: P2 = 0xFF;Qian = 1;Bai = 1;Shi = 1;Ge = 0;P2 = Smg[SmgTmp[4]];//月份的个位
- P2 = 0xFF;Qian = 1;Bai = 1;Shi = 0;Ge = 1;P2 = Smg[SmgTmp[5]];break;//月份的十位
- case 4: P2 = 0xFF;Qian = 1;Bai = 0;Shi = 1;Ge = 1;P2 = Smg[SmgTmp[6]];//日期的个位
- P2 = 0xFF;Qian = 0;Bai = 1;Shi = 1;Ge = 1;P2 = Smg[SmgTmp[7]];break;//日期十位
- case 5: Write_ds1302_CE(7,0x00);
- Write_ds1302_CE(1,SmgTmp[1]<<4|SmgTmp[0]);
- Write_ds1302_CE(2,SmgTmp[3]<<4|SmgTmp[2]);
- Write_ds1302_CE(3,SmgTmp[5]<<4|SmgTmp[4]);
- Write_ds1302_CE(4,SmgTmp[7]<<4|SmgTmp[6]);
- flg0 = 0;
- default:break;
- if(flg0!=0)
- if(set1!=backup1)
- backup1 = set1;
- if(set1==0)
- switch(flg0)
- case 1: Tmp[0]=(SmgTmp[1]*10)+SmgTmp[0];Tmp[0]++;if(Tmp[0]>=60)Tmp[0]=0;SmgTmp[0]=Tmp[0]%10;SmgTmp[1]=Tmp[0]/10;break;
- case 2: Tmp[1]=(SmgTmp[3]*10)+SmgTmp[2];Tmp[1]++;if(Tmp[1]>=24)Tmp[1]=0;SmgTmp[2]=Tmp[1]%10;SmgTmp[3]=Tmp[1]/10;break;
- case 3: Tmp[2]=(SmgTmp[5]*10)+SmgTmp[4];Tmp[2]++;if(Tmp[2]>=31)Tmp[2]=0;SmgTmp[4]=Tmp[2]%10;SmgTmp[5]=Tmp[2]/10;break;
- case 4: Tmp[3]=(SmgTmp[7]*10)+SmgTmp[6];Tmp[3]++;if(Tmp[3]>=12)Tmp[3]=0;SmgTmp[6]=Tmp[3]%10;SmgTmp[7]=Tmp[3]/10;break;
- default:break;
- void interruptTime() interrupt 1 //定时器0
- static unsigned int i;
- TH0=T0RH;
- TL0=T0RL;
- i++;
- if(i==6000)
- i=0;
- flg=~flg;
- if(flg0==0)
- if(flg == 1)
- if(gb==0)
- display(SmgTmp[0],SmgTmp[1],SmgTmp[2],SmgTmp[3]);
- else
- displayI(SmgTmp[0],SmgTmp[1],SmgTmp[2],SmgTmp[3]);
- else
- display(SmgTmp[4],SmgTmp[5],SmgTmp[6],SmgTmp[7]);
- keycan();
- void interruptUART() interrupt 4 //串口
- if(RI)
- RI = 0;
- i = SBUF;
- SBUF = SmgTmp[i];
- if(TI)
- TI = 0;
复制代码 |
