查看: 1220|回复: 0
51时钟
ID:333495 发表于 2018-5-19 10:22 | 显示全部楼层 |阅读模式
#include <reg52.h>
                   #include "24c02.h"
                   sbit dula=P2^6;
                   sbit wela=P2^7;
                   sbit rs=P3^5;
                   sbit lcden=P3^4;
                   sbit s1=P3^0;
                   sbit s2=P3^1;
                   sbit s3=P3^2;
                   sbit rd=P3^7;
                   sbit beep=P2^3;
                   uchar count,s1num;
                   char miao,shi,fen;
                   uchar code table[]="  2018-5-20 MON";
                   void delay(uint z)
                     uint x,y;
                         for(x==z;x>0;x--)
                            for(y=110;y>0;y--);
                   void di()
                     beep=0;
                         delay(100);
                         beep=1;
                   void write_com(uchar com)
                     rs=0;
                         lcden=0;
                         P0=com;
                         delay(5);
                         lcden=1;
                         delay(5);
                         lcden=0;
                   void write_date(uchar date)
                     rs=1;
                         lcden=0;
                         P0=date;
                         delay(5);
                         lcden=1;
                         delay(5);
                         lcden=0;
                         void write_sfm(uchar add,uchar date)
                          uchar shi,ge;
                          shi=date/10;
                          ge=date%10;
                          write_com(0x80+0x40+add);
                          write_date(0x30+shi);
                          write_date(0x30+ge);
                          void init()
                            uchar num;
                                rd=0;
                                dula=0;
                                wela=0;
                                lcden=0;
                                fen=0;
                                miao=0;
                                shi=0;
                                count=0;
                                s1num=0;
                                init_24c02();
                                write_com(0x38);
                                write_com(0x0c);
                                write_com(0x06);
                                write_com(0x01);
                                write_com(0x80);
                                for(num=0;num<15;num++)
                                      write_date(table[num]);
                                          delay(5);
                                        write_com(0x80+0x40+6);
                                        write_date(':');
                                        delay(5);
                                        write_com(0x80+0x40+9);
                                        write_date(':');
                                        delay(5);
                                miao=read_add(1);
                                fen=read_add(2);
                                shi=read_add(3);
                                write_sfm(10,miao);
                                write_sfm(7,fen);
                                write_sfm(4,shi);
                                TMOD=0x01;
                                TH0=(65536-50000)/256;
                                TL0=(65536-50000)/256;
                                EA=1;
                                ET0=1;
                                TR0=1;
                        void keyscan()
                        if(s1==0)
                            delay(5);
                                if(s1==0)
                                {   s1num++;
                                while(!s1);
                                di();
                                if(s1num==1)
                                    TR0=0;
                                        write_com(0x80+0x40+10);
                                        write_com(0x0f);
                                if(s1num==2)
                                    write_com(0x80+0x40+7);
                                if(s1num==3)
                                    write_com(0x80+0x40+4);
                                if(s1num==4)
                                    s1num=0;
                                        write_com(0x0c);
                                        TR0=1;
                                if(s1num!=0)
                                    if(s2==0)
                                            delay(5);
                                                if(s2==0)
                                                   while(!s2);
                                                   di();
                                                   if(s1num==1)
                                                        miao++;
        if(miao==60)
        miao==0;
        write_sfm(10,miao);
        write_add(1,miao);
        if(s1num==2)
        fen++;
        if(fen==60)
        fen==0;
        write_sfm(7,fen);
        write_add(2,fen);
        if(s1num==3)
                                       {            shi++;
        if(shi==24)
        shi==0;
        write_sfm(4,shi);
        write_add(3,shi);
                                                if(s3==0)
                                                   delay(5);
                                                   if(s3==0)
                                                              while(!s3);
        di();
        if(s1num==1)
        miao--;
        if(miao--);
        miao==59;
        write_sfm(10,miao);
        write_add(1,miao);
        if(s1num==2)
        fen--;
        if(fen--);
        fen==59;
        write_sfm(7,miao);
        write_add(2,fen);
        if(s1num==3)
        shi--;
        if(shi--);
        shi==23;
        write_sfm(4,shi);
        write_add(3,shi);
                                        void mian()
                                          {  init();
                                                  keyscan();
                                        void timer0() interrupt 1
                                                TL0=(65536-50000)%256;
                                                count++;
                                                if(count==20)
                                                   count=0;
                                                   miao++;
                                                   if(fen==60)
                                                      fen++;
                                                        if(fen==60)
                                                           fen=0;
                                                           shi++;
                                                           if(shi==24)
                                                               shi=0;
        write_sfm(4,shi);
        write_add(3,shi);
        write_sfm(7,fen);
        write_add(2,fen);
        write_sfm(10,miao);
        write_add(1,miao);
