超声波程序单片机源程序如下:
- #include <AT89x51.H> //器件配置文件
- #include <intrins.h>
- #define RX P1_0
- #define TX P1_1
- #define z1 P1_6//左传感器
- #define y1 P1_7 //右传感器
- #define z1_1 P1_2//左电机
- #define z1_2 P1_3//左电机
- #define y1_1 P1_4//左电机
- #define y1_2 P1_5//左电机
- #define LCM_RW P2_1 //定义LCD引脚
- #define LCM_RS P2_0
- #define LCM_E P2_2
- #define LCM_Data P0
- #define Busy 0x80 //用于检测LCM状态字中的Busy标识
- void LCMInit(void);
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
- void Delay5Ms(void);
- void Delay400Ms(void);
- void Decode(unsigned char ScanCode);
- void WriteDataLCM(unsigned char WDLCM);
- void WriteCommandLCM(unsigned char WCLCM,BuysC);
- unsigned char ReadDataLCM(void);
- unsigned char ReadStatusLCM(void);
- unsigned char code Cls[] = {" "};
- unsigned char code ASCII[20] = {'0','1','2','3','4','5','6','7','8','9','.','-','M','f','l','a','g',':',' '};
- static unsigned char DisNum = 0; //显示用指针
- unsigned int time=0,buff=0,buff1=0;
- unsigned long S=0;
- bit flag =0;
- unsigned char disbuff[4] ={ 0,0,0,0,};
- //写数据
- ReadStatusLCM(); //检测忙
- LCM_Data = WDLCM;
- LCM_RS = 1;
- LCM_RW = 0;
- LCM_E = 0; //若晶振速度太高可以在这后加小的延时
- LCM_E = 0; //延时
- LCM_E = 1;
- //写指令
- void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
- if (BuysC) ReadStatusLCM(); //根据需要检测忙
- LCM_Data = WCLCM;
- LCM_RS = 0;
- LCM_RW = 0;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- //读数据
- LCM_RS = 1;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- return(LCM_Data);
- //读状态
- LCM_Data = 0xFF;
- LCM_RS = 0;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- while (LCM_Data & Busy); //检测忙信号
- return(LCM_Data);
- void LCMInit(void) //LCM初始化
- LCM_Data = 0;
- WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
- Delay5Ms();
- Delay5Ms();
- Delay5Ms();
- WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
- WriteCommandLCM(0x08,1); //关闭显示
- WriteCommandLCM(0x01,1); //显示清屏
- WriteCommandLCM(0x06,1); // 显示光标移动设置
- WriteCommandLCM(0x0F,1); // 显示开及光标设置
- //按指定位置显示一个字符
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
- X |= 0x80; //算出指令码
- WriteCommandLCM(X, 1); //发命令字
- WriteDataLCM(DData); //发数据
- //按指定位置显示一串字符
- unsigned char ListLength;
- ListLength = 0;
- Y &= 0x1;
- while (DData[ListLength]>0x19) //若到达字串尾则退出
- if (X <= 0xF) //X坐标应小于0xF
- DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
- ListLength++;
- X++;
- //5ms延时
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //400ms延时
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- void Conut(void)
- time=TH0*256+TL0;
- TH0=0;
- TL0=0;
- S=(time*1.7)/100; //算出来是CM
- if(S<10)
- buff=1;
- else
- buff=0;
- if((S>=100)||flag==1) //超出测量范围显示“-”
- flag=0;
- DisplayOneChar(0, 0, ASCII[11]);
- DisplayOneChar(1, 0, ASCII[10]); //显示点
- DisplayOneChar(2, 0, ASCII[11]);
- DisplayOneChar(3, 0, ASCII[11]);
- DisplayOneChar(4, 0, ASCII[12]); //显示M
- DisplayOneChar(5, 0, ASCII[18]); //显示M
- DisplayOneChar(6, 0, ASCII[13]); //显示M
- DisplayOneChar(7, 0, ASCII[14]); //显示M
- DisplayOneChar(8, 0, ASCII[15]); //显示M
- DisplayOneChar(9, 0, ASCII[16]); //显示M
- DisplayOneChar(10, 0, ASCII[17]); //显示M
- DisplayOneChar(11, 0, ASCII[8]); //显示M
- else
- disbuff[0]=S%1000/100;
- disbuff[1]=S%1000%100/10;
- disbuff[2]=S%1000%10 %10;
- DisplayOneChar(0, 0, ASCII[disbuff[0]]);
- DisplayOneChar(2, 0, ASCII[disbuff[1]]);
- DisplayOneChar(3, 0, ASCII[disbuff[2]]);
- void zd0() interrupt 1 //T0中断用来计数器溢出,超过测距范围
- flag=1; //中断溢出标志
- void StartModule() //启动模块
- TX=1; //启动一次模块
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- TX=0;
- void delayms(unsigned int ms)
- unsigned char i=100,j;
- for(;ms;ms--)
- while(--i)
- j=10;
- while(--j);
- void qianjin()
- { z1_1 =1;
- z1_2 =0;
- y1_1 =1;
- y1_2 =0;
- void tingzhi()
- z1_1 =1;
- z1_2 =1;
- y1_1 =1;
- y1_2 =1;
- void zuozhuan()
- z1_1 =1;
- z1_2 =1;
- y1_1 =1;
- y1_2 =0;
- void youzhuan()
- z1_1 =1;
- z1_2 =0;
- y1_1 =1;
- y1_2 =1;
- void main(void)
- unsigned char TempCyc;
- Delay400Ms(); //启动等待,等LCM讲入工作状态
- LCMInit(); //LCM初始化
- for (TempCyc=0; TempCyc<10; TempCyc++)
- Delay400Ms(); //延时
- DisplayListChar(0, 1, Cls);
- while(1)
- TMOD=0x01; //设T0为方式1,GATE=1;
- TH0=0;
- TL0=0;
- ET0=1; //允许T0中断
- EA=1; //开启总中断
- while(1)
- StartModule();
- // DisplayOneChar(0, 1, ASCII[0]);
- while(!RX)
- if(z1==0&&y1==0&&buff==0)
- {qianjin();
- buff1=1;}
超声波LC1602显示.zip
(48.72 KB, 下载次数: 11)
