LCD1602显示 步进电机控制器速度方向圈数可调
*K1-启动与停止步进电机运行;K2-设定步进电机运行圈数 (1-20圈)
*K3-设定步进电机转动方向;K4-设定步进电机运行速度
*步进电机的转速控制分16档,数字越小,转速越快。
*7.5度步进电机;周期7.5×4=30度,电机转动一圈需12个周
P1.0-P1.3接输入ULN2003,2003输出再接步进电机
p3.7接小喇叭提供按键音
*p1.4-p1.7接端口按
程序:
- #include <reg51.h> //51芯片管脚定义头文件
- #include <intrins.h> //内部包含延时函数 _nop_();
- #define uchar unsigned char
- #define uint unsigned int
- #define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
- uchar code FFW[8]={0xf1,0xf3,0xf2,0xf6,0xf4,0xfc,0xf8,0xf9};
- uchar code REV[8]={0xf9,0xf8,0xfc,0xf4,0xf6,0xf2,0xf3,0xf1};
- sbit K1 = P1^4; //运行与停止
- sbit K2 = P1^5; //设定圈数
- sbit K3 = P1^6; //方向转换
- sbit K4 = P1^7; //速率调整
- sbit BEEP = P3^7; //蜂鸣器
- sbit LCD_RS = P2^0;
- sbit LCD_RW = P2^1;
- sbit LCD_EN = P2^2;
- bit on_off=0; //运行与停止标志
- bit direction=1; //方向标志
- bit rate_dr=1; //速率标志
- bit snum_dr=1; //圈数标志
- uchar code cdis1[ ] = {" STEPPING MOTOR "};
- uchar code cdis2[ ] = {"CONTROL PROCESS"};
- uchar code cdis3[ ] = {" STOP "};
- uchar code cdis4[ ] = {"NUM: RATE: "};
- uchar code cdis5[ ] = {" RUNNING "};
- uchar m,v=0,q=0;
- uchar number=0,number1=0;
- uchar snum=5,snum1=5; //预设定圈数
- uchar rate=8; //预设定速率
- uchar data_temp,data_temp1,data_temp2;
- /* 延时t毫秒
- /* 11.0592MHz时钟,延时约1ms
- void delay(uint t)
- uchar k;
- while(t--)
- for(k=0; k<125; k++)
- void delayB(uchar x) //x*0.14MS
- uchar i;
- while(x--)
- for (i=0; i<13; i++)
- void beep()
- uchar j;
- for (j=0;j<100;j++)
- delayB(4);
- BEEP=!BEEP; //BEEP取反
- BEEP=1; //关闭蜂鸣器
- delay(170);
- /*检查LCD忙状态
- /*lcd_busy为1时,忙,等待。为0时,闲,可写指令与数据。
- bit lcd_busy()
- bit result;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_EN = 1;
- delayNOP();
- result = (bit)(P0&0x80);
- LCD_EN = 0;
- return(result);
- /*写指令数据到LCD
- /*RS=L,RW=L,E=高脉冲,D0-D7=指令码。
- void lcd_wcmd(uchar cmd)
- while(lcd_busy());
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_EN = 0;
- _nop_();
- _nop_();
- P0 = cmd;
- delayNOP();
- LCD_EN = 1;
- delayNOP();
- LCD_EN = 0;
- /*写显示数据到LCD
- /*RS=H,RW=L,E=高脉冲,D0-D7=数据。
- void lcd_wdat(uchar dat)
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_EN = 0;
- P0 = dat;
- delayNOP();
- LCD_EN = 1;
- delayNOP();
- LCD_EN = 0;
- /* LCD初始化设定
- void lcd_init()
- delay(30);
- lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
- delay(5);
- lcd_wcmd(0x38);
- delay(5);
- lcd_wcmd(0x38);
- delay(5);
- lcd_wcmd(0x0c); //显示开,关光标
- delay(5);
- lcd_wcmd(0x06); //移动光标
- delay(5);
- lcd_wcmd(0x01); //清除LCD的显示内容
- delay(5);
- /* 设定显示位置
- void lcd_pos(uchar pos)
- lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
- /* LCD1602初始显示子程序
- void LCD_init_DIS()
- delay(10); //延时
- lcd_init(); //初始化LCD
- lcd_pos(0); //设置显示位置为第一行的第1个字符
- m = 0;
- while(cdis1[m] != '\0')
- { //显示字符
- lcd_wdat(cdis1[m]);
- m++;
- lcd_pos(0x40); //设置显示位置为第二行第1个字符
- m = 0;
- while(cdis2[m] != '\0')
- lcd_wdat(cdis2[m]); //显示字符
- m++;
- delay(3000); //延时
- m = 0;
- while(cdis3[m] != '\0')
- { //显示字符
- lcd_wdat(cdis3[m]);
- m++;
- m = 0;
- while(cdis4[m] != '\0')
- lcd_wdat(cdis4[m]); //显示字符
- m++;
- for(m=0;m<2;m++)
- lcd_pos(0x0c+m); //显示方向符号
- lcd_wdat(0x3e);
- /*数据转换子程序
- void data_conv()
- data_temp1=data_temp/10; //高位
- if(data_temp1==0)
- {data_temp1=0x20;} //高位为0不显示
- else
- {data_temp1=data_temp1+0x30;}
- data_temp2=data_temp%10; //低位
- data_temp2=data_temp2+0x30;
- /*数据显示子程序
- void data_dis()
- data_temp = snum; //显示圈数
- data_conv();
- lcd_pos(0x44);
- lcd_wdat(data_temp1);
- lcd_pos(0x45);
- lcd_wdat(data_temp2);
- data_temp = rate; //显示速率
- data_conv();
- lcd_pos(0x4d);
- lcd_pos(0x4e);
- /* 显示运行方向符号
- void motor_DR()
- if(direction==1) //正转方向标志
- { for(m=0;m<2;m++)
- lcd_wdat(0x3e);
- else
- { for(m=0;m<2;m++) //反转方向标志
- lcd_wdat(0x3c);
- /* 显示运行状态
- void motor_RUN()
- if(on_off==1)
- { TR0=1;
- m = 0;
- while(cdis5[m] != '\0')
- { lcd_wdat(cdis5[m]); //RUNNING
- m++; }
- motor_DR(); //
- else
- { TR0=0; P1 =0xf0;
- m = 0;
- { lcd_wdat(cdis3[m]); //STOP
- m++; }
- motor_DR(); //
- snum=snum1; //
- number1=0; //清圈数计数器
- * 主程序
- main()
- LCD_init_DIS();
- TMOD = 0x01; //T0定时方式1
- TL0 = 0x33;
- TH0 = 0xf5;
- EA = 1;
- ET0 = 1;
- P1 = 0xf0;
- while(1)
- if(K1==0)
- beep();
- while(K1==0); //等待键释放
- on_off=~on_off;
- motor_RUN();
- } //K1 end
- if(K2==0)
- beep();
- if(snum_dr==1)
- { snum++;
- snum1=snum;
- if(snum==0x14)
- { snum_dr=~snum_dr;}
- else
- {snum--;
- snum1=snum;
- if(snum==0x01)
- { snum_dr=~snum_dr; }
- } //K2 end
- if(K3==0)
- beep();
- direction=~direction;
- motor_DR();
- }//K3 end
- if(K4==0)
- beep();
- if(rate_dr==1)
- { rate++;
- if(rate==0x10)
- { rate_dr=~rate_dr;}
- else
- rate--;
- if(rate==0x01)
- { rate_dr=~rate_dr; }
- } //K4 end
- if(number1==snum1) //与设定圈数是否相等
- { number1=0;
- on_off=0;
- TR0=0;
- snum=snum1;
- P1 =0xf0;
- motor_RUN();
- data_dis();
- } // while(1) end
- } //main end
- /* 定时器 0 中断
- void motor_onoff() interrupt 1
- TL0 = 0x33;
- TH0 = 0xf5;
- q++;
- if(q < rate)
- { return; }
- else
- { q=0;
- number++; //脉冲计数
- if(number==96) //96个脉冲电机转一圈
- { snum--;
- number=0;
- number1++; } //电机转动圈数
- if(direction==1) //方向标志
- { if(v<8)
- {P1 = FFW[v];v++;} //取数据,正转
- if(v==8)
- { v=0; }
- else
- { if(v<8)
- {P1 = REV[v];v++;} //取数据,反转
- if(v==8)
- { v=0; }
