if(heavy1<100) {LED0=0;LED1=0;LED2=0;LED3=0;}
if((heavy1>=100)&&(heavy1<200)){LED0=1;LED1=0;LED2=0;LED3=0;}
if((heavy1>=200)&&(heavy1<300)){LED0=0;LED1=1;LED2=0;LED3=0;}
if((heavy1>=300)&&(heavy1<400)){LED0=0;LED1=0;LED2=1;LED3=0;}
if((heavy1>=400)&&(heavy1<500)){LED0=0;LED1=0;LED2=0;LED3=1;}
if(heavy1>=500) {LED0=1;LED1=1;LED2=1;LED3=1;}
这是我写的,看起来没什么问题啊,为什么编译通过?完整程序如下:
- #include <reg52.h>
- #include <stdio.h>
- #include <math.h>
- #include <intrins.h>
- #define KeyPort P1
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0
- sbit ADDO = P3^2;
- sbit ADSK = P3^3;
- unsigned int num;
- unsigned int dnf;
- float i;
- unsigned int priceV;
- sbit LED0 = P3^4;
- sbit LED1 = P3^5;
- sbit LED2 = P3^6;
- sbit LED3 = P3^7;
- LCD12864引脚接口
- sbit RS = P2^4;
- sbit RW = P2^5;
- sbit E = P2^6;
- sbit RES = P2^3;
- sbit PSB = P2^1;
- sbit PAUSE = P3^0;
- unsigned char temp[16];
- unsigned char lol[16];
- void DelayUs2x(unsigned char t)
- while(--t);
- void DelayMs(unsigned char t)
- while(t--)
- //大致延时1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 检测忙位
- void Check_Busy()
- RS=0;
- RW=1;
- E=1;
- DataPort=0xff;
- while((DataPort&0x80)==0x80);//忙则等待
- E=0;
- 写命令
- void Write_Cmd(unsigned char Cmd)
- Check_Busy();
- RS=0;
- RW=0;
- E=1;
- DataPort=Cmd;
- DelayUs2x(5);
- E=0;
- DelayUs2x(5);
- 写数据
- void Write_Data(unsigned char Data)
- Check_Busy();
- RS=1;
- RW=0;
- E=1;
- DataPort=Data;
- DelayUs2x(5);
- E=0;
- DelayUs2x(5);
- 液晶屏初始化
- void Init_ST7920()
- DelayMs(40); //大于40MS的延时程序
- PSB=1; //设置为8BIT并口工作模式
- DelayMs(1); //延时
- RES=0; //复位
- DelayMs(1); //延时
- RES=1; //复位置高
- DelayMs(10);
- Write_Cmd(0x30); //选择基本指令集
- DelayUs2x(50); //延时大于100us
- Write_Cmd(0x30); //选择8bit数据流
- DelayUs2x(20); //延时大于37us
- Write_Cmd(0x0c); //开显示(无游标、不反白)
- Write_Cmd(0x01); //清除显示,并且设定地址指针为00H
- DelayMs(15); //延时大于10ms
- Write_Cmd(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位,光标从右向左加1位移动
- 显示字符串
- x:横坐标值,范围0~8
- y:纵坐标值,范围1~4
- void LCD_PutString(unsigned char x,unsigned char y,unsigned char *s)
- switch(y)
- case 1: Write_Cmd(0x80+x);break;
- case 2: Write_Cmd(0x90+x);break;
- case 3: Write_Cmd(0x88+x);break;
- case 4: Write_Cmd(0x98+x);break;
- default:break;
- while(*s>0)
- Write_Data(*s);
- s++;
- DelayUs2x(50);
- 清屏
- void ClrScreen()
- Write_Cmd(0x01);
- DelayMs(15);
- 延时函数
- void delay(uchar z)
- uchar x;
- for(;z>0;z--)
- for(x=22;x>0;x--);
- unsigned long ReadCount(void)
- unsigned long Count; unsigned char i;
- ADSK=0; //使能AD(PD_SCK 置低)
- Count=0;
- while(ADDO); //AD转换未结束则等待,否则开始读取
- for (i=0;i<24;i++)
- ADSK=1; //PD_SCK 置 高 ( 发 送 脉 冲 )
- Count=Count<<1; //下降沿来时变量Count左移一位,右侧补零
- ADSK=0; //PD_SCK 置低
- if(ADDO) Count++;
- ADSK=1;
- Count=Count^0x800000;//第25个脉冲下降沿来时,转换数据
- ADSK=0;
- return(Count);
- 按键扫描函数,返回扫描键值
- unsigned char KeyScan(void) //键盘扫描函数,使用行列反转扫描法
- unsigned char cord_h,cord_l;//行列值中间变量
- KeyPort=0x0f; //行线输出全为0
- cord_h=KeyPort&0x0f; //读入列线值
- if(cord_h!=0x0f) //先检测有无按键按下
- DelayMs(10); //去抖
- if((KeyPort&0x0f)!=0x0f)
- KeyPort=cord_h|0xf0; //输出当前列线值
- cord_l=KeyPort&0xf0; //读入行线值
- while((KeyPort&0xf0)!=0xf0);//等待松开并输出
- return(cord_h+cord_l);//键盘最后组合码值
- }return(0xff); //返回该值
- 按键值处理函数,返回扫键值
- 可以根据需要改变返回值
- | 1 | 2 | 3 | + |
- | 4 | 5 | 6 | - |
- | 7 | 8 | 9 | * |
- | 0 | . | = | / |
- unsigned char KeyPro(void)
- switch(KeyScan())
- case 0x77:return 1 ;break;//1
- case 0x7b:return 2 ;break;//2
- case 0x7d:return 3 ;break;//3
- case 0xb7:return 4 ;break;//4
- case 0xbb:return 5 ;break;//5
- case 0xbd:return 6 ;break;//6
- case 0xd7:return 7 ;break;//7
- case 0xdb:return 8 ;break;//8
- case 0xdd:return 9 ;break;//9
- case 0xe7:return 10 ;break;//*
- case 0x7e:return 11;break;//A 设置单价
- case 0xbe:return 12 ;break;//B 去皮
- case 0xde:return 13 ;break;//C 附加功能
- case 0xee:return 14 ;break;//D 重置
- case 0xed:return 15 ;break;//#
- case 0xeb:return 16 ;break;//0
- default:return 0;break;
- 主程序
- main()
- int priceV;
- char v=0;
- unsigned long weight ;
- unsigned long heavy ;
- float heavy1 ;
- float poi;
- int d1,d2;
- int LED0=0;
- int LED1=0;
- int LED2=0;
- int LED3=0;
- ClrScreen();
- Init_ST7920(); //初始化
- heavy= ReadCount(); DelayMs(100);
- while (1)
- for( v=0;v<2;v++)
- { weight += ReadCount(); }
- weight =weight/3;
- heavy1= weight-heavy ;
- heavy1= (float)heavy1/1900;
- DelayMs(150); DelayMs(150);
- if(heavy1>10000)heavy1=0;
- d1 = weight / 1000; d2 = weight % 1000;
- num=KeyPro();
- poi=priceV*heavy1*10;
- LCD_PutString(0,1,"重量:");
- LCD_PutString(0,2,"单价:");
- LCD_PutString(0,3,"总价:");
- LCD_PutString(0,4,"共计:");
- LCD_PutString(7,2,"元");
- LCD_PutString(7,3,"元");
- LCD_PutString(7,4,"元");
- switch(num)
- case 1: priceV*=10; priceV+=1; break; // 1
- case 2: priceV*=10; priceV+=2; break; // 2
- case 3: priceV*=10; priceV+=3; break; // 3
- case 4: priceV*=10; priceV+=4; break; // 4
- case 5: priceV*=10; priceV+=5; break; // 5
- case 6: priceV*=10; priceV+=6; break; // 6
- case 7: priceV*=10; priceV+=7; break; // 7
- case 8: priceV*=10; priceV+=8; break; // 8
- case 9: priceV*=10; priceV+=9; break; // 9
- // case 10: priceV='.'; break; // 9
- case 11: heavy= ReadCount(); break;
- case 12: i+=poi; break;
- case 13: i=0; break;
- case 14: ClrScreen(); break;
- case 15: priceV=0; break; // 0
- case 16: priceV*=10; break;
- sprintf(temp,"%5.2fg " ,heavy1);
- LCD_PutString(3,1, temp);
- sprintf(lol,"%4d",priceV);
- LCD_PutString(3,2,lol);
- sprintf(lol,"%4.1f ",poi/10);
- LCD_PutString(3,3,lol);
- sprintf(lol,"%4.1f",i/10);
- LCD_PutString(3,4,lol);
- DelayMs(200);
- // sprintf(temp," %4d%-d ",d1,d2);
- // LCD_PutString(0,4, temp);
- DelayMs(200);
- //if(heavy1>503)
- // ClrScreen();
- // sprintf(lol,"警告警告警告警告");
- // LCD_PutString(0,1, lol);
- // LCD_PutString(0,2, lol);
- // LCD_PutString(0,3, lol);
- // LCD_PutString(0,4, lol);
- // DelayMs(200); DelayMs(200);
- // ClrScreen();
- // switch(heavy1)
- // case 100:led0=1;led1=0;led2=0;led3=0; break;
- // case 200:led0=0;led1=1;led2=0;led3=0; break;
- // case 300:led0=0;led1=0;led2=1;led3=0; break;
- // case 400:led0=0;led1=0;led2=0;led3=1; break;
- // case 500:led0=1;led1=1;led2=1;led3=1; break;
- if(heavy1<100) {LED0=0;LED1=0;LED2=0;LED3=0;}
- if((heavy1>=100)&&(heavy1<200)){LED0=1;LED1=0;LED2=0;LED3=0;}
- if((heavy1>=200)&&(heavy1<300)){LED0=0;LED1=1;LED2=0;LED3=0;}
- if((heavy1>=300)&&(heavy1<400)){LED0=0;LED1=0;LED2=1;LED3=0;}
- if((heavy1>=400)&&(heavy1<500)){LED0=0;LED1=0;LED2=0;LED3=1;}
- if(heavy1>=500) {LED0=1;LED1=1;LED2=1;LED3=1;}
