51单片机开发板1602显示秒
- * 【作 者】: 清翔电子:03
- * 【外部晶振】: 11.0592mhz
- * 【主控芯片】: STC89C52
- * 【编译环境】: Keil μVisio3
- * 【程序功能】:
- * 【使用说明】: 液晶1脚接1602黑色排母的1脚 如果是无背光的液晶只有14个脚 排母右边空2个位
- 请把液晶对比度电位器顺时针调制10点钟方向,请勿多调超出极限位置会损坏电位器!
- * 说明:免费开源,不提供源代码分析.
- * 描述: *
- * 上电后液晶屏先显示信息,接着按下S2,定时开始,再次按下 *
- * S2暂停,第3次按下显示累积计时,第4次按下暂停计时,任何时候按下S3*
- * 计数清零。 *
- #include <reg51.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar KeyCount=0;
- sbit S2 = P3^0;
- sbit S3 = P3^1;
- sbit BEEP = P2^3; //蜂鸣器
- uchar code cdis1[ ] = {" STOPWATCH 0 "};
- uchar code cdis2[ ] = {" QX-MCS51 "};
- uchar code cdis3[ ] = {"TIME "};
- uchar code cdis4[ ] = {" BEGIN COUNT 1 "};
- uchar code cdis5[ ] = {" PAUSE COUNT 2 "};
- uchar code cdis6[ ] = {" BEGIN COUNT 3 "};
- uchar code cdis7[ ] = {" PAUSE COUNT 4 "};
- uchar code cdis8[ ] = {" "};
- sbit LCD_RS = P3^5;
- sbit LCD_RW = P3^6;
- sbit LCD_EN = P3^4;
- sbit dula=P2^6;
- sbit wela=P2^7;
- #define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
- uchar display[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- uchar display2[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- 延时函数
- void Delay(uint num)//延时函数
- while( --num );
- 蜂鸣器响一声
- void beep()
- unsigned char y;
- for (y=0;y<180;y++)
- BEEP=!BEEP; //BEEP取反
- Delay(70);
- BEEP=1; //关闭蜂鸣器
- 延时函数1
- void delay1(int ms)
- unsigned char n;
- while(ms--)
- for(n = 0; n<250; n++)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- *写指令数据到LCD *
- *RS=L,RW=L,E=高脉冲,D0-D7=指令码。 *
- void lcd_wcmd(uchar cmd)
- // while(lcd_busy());
- LCD_RS = 0;
- // LCD_RW = 0;
- LCD_EN = 0;
- _nop_();
- _nop_();
- P0 = cmd;
- delayNOP();
- LCD_EN = 1;
- delayNOP();
- LCD_EN = 0;
- Delay(10);
- *写显示数据到LCD *
- *RS=H,RW=L,E=高脉冲,D0-D7=数据。 *
- void lcd_wdat(uchar dat)
- LCD_RS = 1;
- // LCD_RW = 0;
- LCD_EN = 0;
- P0 = dat;
- delayNOP();
- LCD_EN = 1;
- delayNOP();
- LCD_EN = 0;
- Delay(10);
- * LCD初始化设定 *
- void lcd_init()
- LCD_RW = 0;
- dula=0;
- wela=0;
- delay1(15);
- lcd_wcmd(0x01); //清除LCD的显示内容
- lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
- delay1(5);
- lcd_wcmd(0x38);
- delay1(5);
- lcd_wcmd(0x38);
- delay1(5);
- lcd_wcmd(0x0c); //开显示,不显示光标
- delay1(5);
- delay1(5);
- * 设定显示位置 *
- void lcd_pos(uchar pos)
- lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
- 显示函数
- void play()
- uchar i;
- for(i=0;i<6;i++)
- display2[i]=display[i]+0x30;
- display2[7]=display[6]/10+0x30; //时单位数据处理
- display2[6]=display[6]%10+0x30;
- lcd_pos(0x45);
- lcd_wdat(display2[7]); //显示时
- lcd_wdat(display2[6]);
- lcd_wdat(0x3a); //显示':'
- lcd_wdat(display2[5]); //显示分
- lcd_wdat(display2[4]);
- lcd_wdat(display2[3]); //显示秒
- lcd_wdat(display2[2]);
- lcd_wdat(display2[1]); //显示毫秒
- lcd_wdat(display2[0]);
- 主函数
- main()
- uchar m;
- TMOD=0x01;
- TH0=0xdc; TL0=0x00; //50ms定时
- EA=1; ET0=1;
- lcd_init();
- lcd_pos(0x00); //设置显示位置为第一行
- for(m=0;m<16;m++)
- lcd_wdat(cdis1[m]); //显示字符
- lcd_pos(0x40); //设置显示位置为第二行
- for(m=0;m<16;m++)
- lcd_wdat(cdis2[m]); //显示字符
- delay1(60);
- delay1(100);
- for(m=0;m<16;m++)
- lcd_wdat(cdis3[m]);
- while(1)
- if(S2==0)
- KeyCount++; //计数
- beep();
- delay1(100);
- switch (KeyCount)
- case 1:
- TR0=1; //启动中断
- lcd_pos(0x00);
- for(m=0;m<16;m++)
- lcd_wdat(cdis4[m]);
- break;
- case 2:
- TR0=0; //停止中断
- lcd_pos(0x00);
- for(m=0;m<16;m++)
- lcd_wdat(cdis5[m]);
- break;
- case 3:
- TR0=1; //启动中断
- lcd_pos(0x00);
- for(m=0;m<16;m++)
- lcd_wdat(cdis6[m]);
- break;
- case 4:
- TR0=0; //停止中断
- lcd_pos(0x00);
- for(m=0;m<16;m++)
- lcd_wdat(cdis7[m]);
- break;
- default:
- TR0=0; //停止中断
- break;
- if(S3==0)
- TR0=0; //停止中断
- KeyCount=0;
- for(m=0;m<8;m++)
- display[m]=0x00; //计时单元清零
- for(m=0;m<16;m++)
- beep();
- delay1(100);
- play();
- * Time0中断函数 *
- void Time0(void) interrupt 1 using 0
- TH0=0xdc; //10ms定时
- TL0=0x00;
- display[0]++; //0.01S
- if(display[0]==10)
- display[0]=0;
- display[1]++; //0.1S
- if(display[1]==10)
- display[1]=0;
- display[2]++; //秒个位
- if(display[2]==10)
- display[2]=0;
- display[3]++; //秒十位
- if(display[3]==6)
- display[3]=0;
- display[4]++; //分个位
- if(display[4]==10)
- display[4]=0;
- display[5]++; //分十位
- if(display[5]==6)
- display[5]=0;
- display[6]++; //时
- if(display[6]==24)
- display[6]=0;
