1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 | #include <AT89X52.H> #include "KEY44.H" #include "7SEG.H" bit Flag; sbit LED = P3 ^ 0; unsigned char time; unsigned char NTime; void timer_init(void) { TMOD = 0x01; TH0 = (65536 - 10000) / 256; TL0 = (65536 - 10000) % 256; ET0 = 1; EA = 1; TR0 = 1; } void time_Stop(void) { TMOD = 0x00; TH0 = 0; TL0 = 0; ET0 = 0; EA = 0; TR0 = 0; } void main(void) { NTime = 0; while(1) { unsigned char key = Matrix_keyboard(); if(key == 1) { timer_init(); LED = 1; } if(key == 2) { time_Stop(); Flag = 0; NTime = 0; LED = 0; } if (Flag == 1) { Flag = 0; Seg_Show(NTime); NTime += 1; if(NTime == 99 + 1) { NTime = 0; } } } } void t_0(void) interrupt 1 using 0 { TR0 = 0; TH0 = (65536 - 10000) / 256; TL0 = (65536 - 10000) % 256; time++; if(time == 100) { time = 0; Flag = 1; } TR0 = 1; } /*---------------------------------------- File: 7SEG.h Date:Loser007 May 5, 2018 18:04 ----------------------------------------*/ #ifndef __7SEG_H__ #define __7SEG_H__ #pragma SAVE #pragma REGPARMS extern void Seg_Show(unsigned char Time); unsigned char code seg_cc[] = //Common cathode digital tube segment code { 0x3F, //0 0x06, //1 0x5B, //2 0x4F, //3 0x66, //4 0x6D, //5 0x7D, //6 0x07, //7 0x7F, //8 0x6F, //9 0x77, //A 0x7C, //B 0x39, //C 0x5E, //D 0x79, //E 0x71, //F }; /*---------------------------------------- Name: Seg_Show Features: Show time in 2 SEG Parameter: No Return: N0 Instructions:SEG I/0 From P1^0 to P1^7 & P2^0 to P2^7 Date:Loser007 May 5, 2018 10:40 ----------------------------------------*/ void Seg_Show(unsigned char Time) { P0 = seg_cc[Time / 10]; P2 = seg_cc[Time % 10]; } #endif /*---------------------------------------- File: key44.h Date:Loser007 May 5, 2018 12:59 ----------------------------------------*/ #ifndef __KEY44_H__ #define __KEY44_H__ #pragma SAVE #pragma REGPARMS extern char Matrix_keyboard(void); /*---------------------------------------- Name: Matrix_keyboard Features: Get a case from the 4*4 keyboard Parameter: No Return:Key code (char) Instructions:Keyboard I/0 From P1^0 to P1^7 Date:Loser007 May 5, 2018 10:40 ----------------------------------------*/ char Matrix_keyboard(void) { unsigned char Key = 0, X = 0, Y = 0; P1 = 0xF0; //11110000 X = P1 & 0xF0; //Get row (P1 XOR 11110000) Get Height if(X != 0xF0) { X = P1 ^ 0xF0; P1 = 0x0F; //00001111 Y = P1 & 0x0F; if(Y != 0x0F) { Y = P1 ^ 0x0F; //Get Column (P1 XOR 00001111) Get Low Key = X + Y; } } switch (Key) { // 1 case 0x81: return 0; //1000 0001 case 0x82: return 1; //1000 0010 case 0x84: return 2; //1000 0100 case 0x88: return 3; //1000 1000 // 2 case 0x41: return 4; //0100 0001 case 0x42: return 5; //0100 0010 case 0x44: return 6; //0100 0100 case 0x48: return 7; //0100 1000 // 3 case 0x21: return 8; //0010 0001 case 0x22: return 9; //0010 0010 case 0x24: return 10; //0010 0100 case 0x28: return 11; //0010 1000 //4 case 0x11: return 12; //0001 0001 case 0x12: return 13; //0001 0010 case 0x14: return 14; //0001 0100 case 0x18: return 15; //0001 1000 default: return 255; } } #endif |
20.18 KB, 下载次数: 26, 下载积分: 黑币 -5
代码,库,仿真
