个人认为,AVR系列的串口使用还是比较容易出错,如果采用传统的查询方式太耗系统时间,而且现在关于AVR的教材大多给你的是查询发送方式,中断接收方式。
本例子是采用中断接收,中断发送方式。希望对大家有所帮助。
//ICC-AVR
// Target : M8
// Crystal: 4.0000Mhz
#include <iom8v.h>
#include <macros.h>
#define DISABLE_UARTTX() UCSRB&=~BIT(TXCIE)
#define ABLE_UARTTX() UCSRA|=BIT(TXC);UCSRB|=BIT(TXCIE)
unsigned char ucRecv;
unsigned char ucRecvOk;
unsigned char ucSendData[8]="Recv OK!";
unsigned char ucComSendCnt,ucComSendPtr;
void InitPort(void)
PORTB = 0xFF;
DDRB = 0x00;
PORTC = 0x7F; //m103 output only
DDRC = 0x00;
PORTD = 0xFE;
DDRD = 0x02;
//UART0 initialize
// desired baud rate: 2400
// actual: baud rate:2404 (0.2%)
void InitUart0(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = BIT(URSEL) | 0x06;
UBRRL = 0x67; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0x98;
#pragma interrupt_handler uart0_rx_isr:iv_USART0_RXC
void uart0_rx_isr(void)
unsigned char ucTmp;
//uart has received a character in UDR
ucTmp=UDR;
if (ucTmp=='A')
ucRecv=ucTmp;
ucRecvOk=0x01;
#pragma interrupt_handler uart0_tx_isr:iv_USART0_TXC
void uart0_tx_isr(void)
//character has been transmitted
if (ucComSendCnt!=0)
ucComSendPtr+=1;
UDR=ucSendData[ucComSendPtr];
ucComSendCnt-=1;
}else
//PORTB&=~BIT(PB_COM_LED); //串口指示灯灭
DISABLE_UARTTX();
//PORTB^=BIT(PB_COM_LED); //串口指示灯灭
//call this routine to initialize all peripherals
void InitMcu(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
InitPort();
InitUart0();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
unsigned char i;
InitMcu();
if (ucRecvOk==0x01)
CLI();
ucRecvOk=0;
SEI();
ucComSendCnt=7;
ucComSendPtr=0;
ABLE_UARTTX();
UDR=ucSendData[0];
