查看: 1968|回复: 1
舵机两足机器人开源Arduino代码
ID:567322 发表于 2019-6-19 22:08 | 显示全部楼层 |阅读模式
#include<IRremote.h>//包含红外库  关键点
#include "VarSpeedServo.h"  //包含 VarSpeedServo library
int RECV_PIN = A4;//端口声明
IRrecv irrecv(RECV_PIN);
decode_results results;//结构声明
int on = 0;//标志位
unsigned long last = millis();
long ir_run_car = 0x00FF629D;//按键CH
long ir_back_car = 0x00FFA857;//按键+
long ir_left_car = 0x00FF22DD;//按键<<
long ir_right_car = 0x00FFC23D;//按键>||
long ir_stop_car = 0x00FF02FD;//按键>>|
long ir_left_turn = 0x00ffE01F;//按键-
long ir_right_turn = 0x00FF906F;//按键EQ
VarSpeedServo RU;  //Right Upper
VarSpeedServo RL;  //Right Lower
VarSpeedServo LU;  //Left Upper
VarSpeedServo LL;  //Left Lower
int beep=A3;//定义蜂鸣器 数字A3 接口
int Echo = A1;  // Echo回声脚(P2.0)
int Trig =A0;  //  Trig 触发脚(P2.1)
int Distance = 0;
        //vel(min), delay_Forward(max) = (5, 2000)
const int vel = 50, vel_Back = 15, vel_turn= 15;                     //vel(mid), delay_Forward(mid) = (20, 750)
const int delay_Forward = 700, delay_Back = 750, delay_turn = 500;   //vel(max), delay_Forward(min)= (256, 50)
        //wonderful ---> (10, 700) (50, 500) (100, 100) (100, 300) (100, 500)
const int array_cal[4] = {90,90,90,90};   // Define the angular adjustment of servo (RU, RL, LU, LL )
const int delay_tim = 300;  //Delay 750ms
int RU_Degree = 0, LU_Degree = array_cal[2] + 5;
const int num1 = 6;
const int array_forward[num1][4] =
    {0,-40,0,-20},
    {30,-40,40,-20},
    {30,0,40,0},
    {0,20,0,40},
    {-30,20,-30,40},
    {-30,0,-30,0},
const int num2 = 6;
const int array_back[num2][4] ={
    {-40,0,-20,0},
    {-40,30,-20,30},
    {0,30,0,30},
    {40,0,50,0},
    {40,-30,50,-40},
    {0,-30,0,-40},
const int num3 = 5;          // 定义数组编号为5。
/* 当遇到障碍时,转过身来。每一步都需要5组数据。每组4个伺服系统的角度改变*/
const int array_left[num3][4] =
    {-40,0,-20,0},           // The left foot turns left at 20 degrees and the right foot turns left at 40 degrees.
    {-40,30,-20,30},         // The left foot raises and the right foot supports the ground to keep balance
    {0,30,0,30},
    {30,0,30,0},
    {0,0,0,0},
}; //定义5个数组,每个数组包含4个元素来存储伺服的当前角度值。
const int num4 = 5;
const int array_right[num4][4] =
  {40,0,50,0},
  {40,-30,50,-40},
  {0,-30,0,-40},
  {-30,0,-40,0},
  {0,0,0,0},
//#define INSTALL
//#define CALIBRATION
#define RUN
void Servo_Init()
    RU.attach(3);   // Connect the signal wire of the upper-right servo to pin 9
    RL.attach(5);   // Connect the signal wire of the lower-right servo to pin 10
    LU.attach(6);   // Connect the signal wire of the upper-left  servo to pin 11
    LL.attach(9);   // Connect the signal wire of the lower-left  servo to pin 12
void Adjust()                            // Avoid the servo's fast spinning in initialization
{                                        // RU,LU goes from array_cal[0] - 5 ,array_cal[2] + 5 degrees to array_cal[0],array_cal[2] degrees
    for(RU_Degree = array_cal[0] - 5; RU_Degree <= array_cal[0]; RU_Degree += 1) {
        RU.write(RU_Degree);             // in steps of 1 degree
        LU.write(LU_Degree--);           // tell servo to go to RU_Degreeition, LU_Degreeition in variable 'RU_Degree', 'LU_Degree'
        delay(15);                       // waits 15ms for the servo to reach the RU_Degreeition
void TooClose()
  digitalWrite(Trig, LOW);   // 给触发脚低电平2μs
  delayMicroseconds(2);
  digitalWrite(Trig, HIGH);  // 给触发脚高电平10μs,这里至少是10μs
  delayMicroseconds(10);
  digitalWrite(Trig, LOW);    // 持续给触发脚低电
  float Fdistance = pulseIn(Echo, HIGH);  // 读取高电平时间(单位:微秒)
  Fdistance= Fdistance/58;       //为什么除以58等于厘米,  Y米=(X秒*344)/2
  // X秒=( 2*Y米)/344 ==》X秒=0.0058*Y米 ==》厘米=微秒/58
  Serial.print("Distance:");      //输出距离(单位:厘米)
  Serial.println(Fdistance);         //显示距离
  Distance = Fdistance;
void Forward(unsigned int n_delay)
    for(int x=0; x<num1; x++) {
        RU.slowmove (array_cal[0] + array_forward[x][0] , vel);
        RL.slowmove (array_cal[1] + array_forward[x][1] , vel);
        LU.slowmove (array_cal[2] + array_forward[x][2] , vel);
        LL.slowmove (array_cal[3] + array_forward[x][3] , vel);
        delay(n_delay);  //delay_Forward :700
void stop()
        RU.slowmove (array_cal[0]  , vel);
        RL.slowmove (array_cal[1]  , vel);
        LU.slowmove (array_cal[2]  , vel);
        LL.slowmove (array_cal[3] , vel);
        delay(delay_tim);
void Backward(unsigned int n_delay)
  for(int y=0; y<num2; y++) {
      RU.slowmove (array_cal[0] + array_back[y][0] , vel_Back);
      RL.slowmove (array_cal[1] + array_back[y][1] , vel_Back);
      LU.slowmove (array_cal[2] + array_back[y][2] , vel_Back);
      LL.slowmove (array_cal[3] + array_back[y][3] , vel_Back);
      delay(n_delay); //delay_Forward:700
void left_turn(unsigned int n_delay)
     for(int z=0; z<2; z++)
       for(int y=0; y<num3; y++)
       RU.slowmove (array_cal[0] + array_left[y][0] , vel_Back);
       RL.slowmove (array_cal[1] + array_left[y][1] , vel_Back);
       LU.slowmove (array_cal[2] + array_left[y][2] , vel_Back);
       LL.slowmove (array_cal[3] + array_left[y][3] , vel_Back);
       delay(n_delay); //delay_Back:750
void right_turn(unsigned int n_delay)
     for(int y=0; y<num4; y++)
      RU.slowmove (array_cal[0] + array_right[y][0] , vel_Back);
      RL.slowmove (array_cal[1] + array_right[y][1] , vel_Back);
      LU.slowmove (array_cal[2] + array_right[y][2] , vel_Back);
      LL.slowmove (array_cal[3] + array_right[y][3] , vel_Back);
void n_Forward(unsigned char n_step,unsigned int n_delay)
  unsigned char z;
  for(z = 0;z < n_step; z++)
    Forward(n_delay);
void n_Backward(unsigned char n_step,unsigned int n_delay)
  unsigned char z;
    Backward(n_delay);
void n_left_turn(unsigned char n_step,unsigned int n_delay)
  unsigned char z;
    left_turn(n_delay);
void n_right_turn(unsigned char n_step,unsigned int n_delay)
  unsigned char z;
    right_turn(n_delay);
void setup()
#ifdef INSTALL
    Servo_Init();
    RU.slowmove (90 , vel);
    RL.slowmove (90 , vel);
    LU.slowmove (90 , vel);
    LL.slowmove (90 , vel);
    while(1);
#endif
#ifdef CALIBRATION
    Servo_Init();
    RU.slowmove (array_cal[0] , vel);  // Define the angle and speed of the upper-right servo.
    delay(2000);
    while(1);
#endif
#ifdef RUN
    Servo_Init();
    delay(2000);
#endif
  irrecv.enableIRIn();       // 开始启动红外遥控
  pinMode(Echo, INPUT);      // 定义超声波输入脚
  pinMode(Trig, OUTPUT);     // 定义超声波输出脚
  pinMode(beep,OUTPUT);     //蜂鸣器
void dump(decode_results *results)
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN)
    //Serial.println("Could not decode message");
    // brake();
void loop()
   if (irrecv.decode(&results)) //调用库函数:解码
    // If it's been at least 1/4 second since the last
    // IR received, toggle the relay
    if (millis() - last > 250) //确定接收到信号
      on = !on;//标志位置反
      digitalWrite(13, on ? HIGH : LOW);//板子上接收到信号闪烁一下led
      dump(&results);//解码红外信号
    if (results.value == ir_run_car )//按键CH
       n_Forward(4,250); //前进
    if (results.value == ir_back_car )//按键+
       n_Backward(2,650);//后退
    if (results.value == ir_left_car )//按键<<
       n_left_turn(1,650);//左转
    if (results.value == ir_right_car )//按键>||
       n_right_turn(1,650);//右转
    if (results.value == ir_stop_car )//按键>>|
       stop();//停车
    last = millis();
    irrecv.resume(); // Receive the next value
ID:1 发表于 2019-6-20 03:10 | 显示全部楼层
