查看: 1477|回复: 0
STM32F103RC智能家居LD3320语音控制代码
ID:338597 发表于 2019-10-22 16:03 | 显示全部楼层 |阅读模式
#include "sys.h"
void All_Init(void);
void Board_text(unsigned int Code_Val);
int main()
        All_Init();  //全部初始化
        printf("\r\n您请说(^_^)\r\n");
                IWDG_Feed();         //喂狗
                LD3320_Subject();    //运行LD3320程序
                Board_text(nAsrRes); //LD3320识别到后会运行的程序
void All_Init(void)
        NVIC_Configuration();  //设置NVIC中断分组
        delay_init();     //延时初始化
        uart_init(9600);  //串口初始化
        LD3320_init();          //LD3320初始化
        IWDG_Init(7,625); //看门狗初始化.喂狗8S一次
//识别到后会运行的程序
        if(LD3320_Identified_Flag_bit == LD_ASR_FOUNDOK )
                LD3320_Identified_Flag_bit=LD_ASR_NONE;
                switch(Code_Val)  //对结果执行相关操作
                        case CODE_Hello:
                                printf("你好!");
                        break;
                        case CODE_ZWD_ON:
                                printf("主卧灯已开");
                        break;
                        case CODE_ZWD_OFF:
                                printf("主卧灯已关");
                        break;
                        case CODE_CWD_ON:
                                printf("次卧灯已开");
                        break;
                        case CODE_CWD_OFF:
                                printf("次卧灯已关");
                        break;
                        case CODE_CF_ON:
                                printf("厨房灯已开");
                        break;
                        case CODE_CF_OFF:
                                printf("厨房灯已关");
                        break;
                        case CODE_KT_ON:
                                printf("客厅灯已开");
                        break;
                        case CODE_KT_OFF:
                                printf("客厅灯已关");
                        break;
                        case CODE_FC_ON:
                                printf("风扇已开");
                        break;
                        case CODE_FC_OFF:
                                printf("风扇已关");
                        break;
                        case CODE_Self_intr:
                        break;
                        case CODE_name:
                        break;
                        case CODE_ALL_ON:
                                printf("全开");
                        break;
                        case CODE_ALL_OFF:
                                printf("全关");
                        break;
                        case CODE_GRMS:
                                printf("单人模式开,普通模式关闭");
                        break;
                        case CODE_PTMS:
                                printf("普通模式开,单人模式关闭");
                        break;
                        case CODE_WSDJM:
                                printf("温湿度");
                        break;
                        case CODE_GDJM:
                                printf("光度");
                        break;
                        default:break;
STM32F103RC智能家居LD3320语音控制.7z
189.75 KB, 下载次数: 36, 下载积分: 黑币 -5
