移植官方例程F4到F1,基于stm32f103ze+mpu9250通过官方DMP库串口输出角度,感谢众多开源大佬
- #include "stm32f10x.h"
- #include "stdio.h"
- #include "UART1.h"
- #include "systick.h"
- // mpu9250 include files
- #include "sys.h"
- #include "mpu9250.h"
- #include "mpuiic.h"
- #include "inv_mpu.h"
- #include "inv_mpu_dmp_motion_driver.h"
- float Q0,Q1,Q2,Q3; // 欧拉角
- u32 status2=0;
- void printf_init() //printf初始化
- GPIO_InitTypeDef GPIO_InitStructure; //声明一个结构体变量,用来初始化GPIO
- NVIC_InitTypeDef NVIC_InitStrue;//定义中断相关结构体
- USART_InitTypeDef USART_InitStructure; //串口结构体定义
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1|RCC_APB2Periph_AFIO,ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;//TX
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3;//RX
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
- USART_InitStructure.USART_BaudRate=115200; //波特率设置为9600
- USART_InitStructure.USART_WordLength=USART_WordLength_8b;
- USART_InitStructure.USART_StopBits=USART_StopBits_1;
- USART_InitStructure.USART_Parity=USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
- USART_Init(USART2,&USART_InitStructure);
- USART_Cmd(USART2, ENABLE);
- USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//使能或者失能指定的USART中断 接收中断
- USART_ClearFlag(USART2,USART_FLAG_TC);//清除USARTx的待处理标志位
- NVIC_InitStrue.NVIC_IRQChannel=USART2_IRQn;//定义中断通道
- NVIC_InitStrue.NVIC_IRQChannelCmd=ENABLE;//开启中断通道
- NVIC_InitStrue.NVIC_IRQChannelPreemptionPriority=1;//设定抢占优先级为1
- NVIC_InitStrue.NVIC_IRQChannelSubPriority=1;//设定子优先级为1
- NVIC_Init(&NVIC_InitStrue);//中断初始化
- void USART2_IRQHandler(void)//编写中断处理函数
- u8 res;//无符号字符res
- if(USART_GetITStatus(USART2,USART_IT_RXNE))//接收数据进入中断,判断串口1接收缓存器非空使能为1与否
- res= USART_ReceiveData(USART2); //为1,则将串口1的数据给变量
- if(res==0x10)//等待
- USART_SendData(USART2,'1');
- while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==RESET);
- USART_SendData(USART2,'0');
- EXTI->IMR |= EXTI_Line0;//使能外部中断4
- EXTI->IMR |= EXTI_Line3;//使能外部中断4
- EXTI->IMR |= EXTI_Line4;//使能外部中断4
- EXTI->IMR |= EXTI_Line5;//使能外部中断4
- status2=0;
- else if(res==0x11)//小孩
- EXTI->IMR &= ~(EXTI_Line0);// 屏蔽外部中断0
- EXTI->IMR &= ~(EXTI_Line3);// 屏蔽外部中断3
- EXTI->IMR &= ~(EXTI_Line4);// 屏蔽外部中断4
- EXTI->IMR &= ~(EXTI_Line5);// 屏蔽外部中断5
- status2=1;
- else if(res==0x13)//校准
- mpu_dmp_init();
- if(mpu_dmp_init()==0)
- printf("13");
- while(mpu_dmp_init())
- mpu_dmp_init();
- printf("13");
- void Led_Configuration(void)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //PE5接
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //设为推挽输出模式
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOE, &GPIO_InitStructure); //初始化外设GPIO
- GPIO_SetBits(GPIOE,GPIO_Pin_5);
- int main(void)
- u8 status;
- float pitch_dmp,roll_dmp,yaw_dmp; // 欧拉角
- delay_ms(1000);
- delay_ms(1000);
- Initial_UART1(115200);
- Led_Configuration();
- printf_init();
- delay_ms(1000);
- // MPU9250姿态传感器初始化
- do{
- status = mpu_dmp_init();
- if(status)
- printf("Initialization--MPU9250 Error!!!\r\n");
- }while(status);
- printf("Initialization--MPU9250 OK!!!\r\n");
- while(1)
- { status= mpu_mpl_get_data(&pitch_dmp,&roll_dmp,&yaw_dmp);
- //status=mpu_dmp_get_data(&pitch_dmp,&roll_dmp,&yaw_dmp);
- if(!status)
- if(status2==1)
- { //printf("pitch:\t\t%8.2f\r\n roll:\t\t%8.2f\r\n yaw:\t\t%8.2f\r\n",pitch_dmp,roll_dmp,yaw_dmp);
- printf("%.3f|%.3f|%.3f|%.3f|%.1d\n",Q0,Q1,Q2,Q3,GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_2));//四元数
- //GPIO_WriteBit(GPIOE, GPIO_Pin_5, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOE, GPIO_Pin_5))); //引脚取反
- //delay_ms(10);
- else
- // printf("### Get Eulerian angle failed! ###\r\n");
- delay_ms(10);
- int fputc(int ch,FILE *p)
- USART_SendData(USART2,(u8)ch);
- return ch;
MPU9250.7z
(441.99 KB, 下载次数: 274)
