关于STM32F103C8T6最小系统配置测试
- /#include "stm32f10x.h"
- unsigned char *P_RXD;//接收数据指针
- unsigned int Num_RXD=0;//要打印字节区位码的字节数
- unsigned char TxBuffer[64]={0,2,3,};//串口发送缓冲区
- unsigned char RxBuffer[64]; //串口接收缓冲区
- unsigned char Key0=0;
- unsigned char Key0_Value=0;
- unsigned char Key0_State=0;
- unsigned char LED0_State=0;
- unsigned char t;
- unsigned char JG;//数据比较结果
- void Key_Delay (void)
- unsigned int i;
- for(i=0;i<0xfff;i++);
- void Time_Delay (void)
- unsigned int i;
- unsigned int j;
- for(j=0;j<0xFFFF;j++);
- /** @addtogroup Template_Project
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- //void Delay(int nCount);
- * @brief Main program.
- * @param None
- * @retval : None
- int main(void)
- /* Setup STM32 system (clock, PLL and Flash configuration) */
- SystemInit();
- RCC_Configuration();
- NVIC_Configuration();
- GPIO_Configuration();
- SysTick_init(); //延时初始化
- SPI2_Init(); //初始化SPI硬件口
- P_RXD=RxBuffer;//接收指针指向接收缓冲区
- USART_Configuration(); //USART1配置
- TIM2_Config(); //定时器初始化
- OLED_Init(); //初始化OLED
- OLED_ShowString(1,0, "0.96' OLED TEST");
- OLED_ShowString(1,16,"mcudev.taobao ");
- OLED_ShowString(1,32,"2014-06-16");
- OLED_ShowString(1,48,"ASCII: ");
- OLED_ShowString(63,48,"CODE: ");
- unsigned char i;
- for(i=0;i<32;i++)TxBuffer[i]=i;
- I2CWriteByte(0,TxBuffer,32); //写入长度
- I2CReadByte(0,RxBuffer,32);
- JG=Compare_Mem (TxBuffer,RxBuffer,32);
- if(JG==0)//对Eeprom进行读写判断;
- OLED_ShowString(1,32,"Eeprom--OK ");
- else
- OLED_ShowString(1,32,"Eeprom--Error ");
- /* Infinite loop */
- while (1)
- OLED_ShowChar(48,48,t,16,1);// OLED_Refresh_Gram();
- t++;
- if(t>'~')t=' ';
- OLED_ShowNum(103,48,t,3,16);//
- if(Key0_State==0xff)
- LED0_State=!LED0_State;
- delay_ms(300);
- Key0_State=0;
- if(LED0_State==0)
- LED0_ON();//LED亮
- delay_ms(200);
- LED0_OFF();//LED灭
- delay_ms(200);
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval : None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
STM32_OLED(C8T6).7z
(177.42 KB, 下载次数: 26)
