4乘4矩阵键盘扫描
- #include "key.h"
- #include "delay.h"
- typedef struct
- GPIO_TypeDef* GPIOX;
- uint16_t GPIO_Pin;
- }KGPT[2][4]; //4*4
- KGPT KPIN={ //只需要在下面填写横竖行的IO口和管脚 IO口和管脚都可以随意定义 无需在一个IO口 管脚也无需按顺序
- {{GPIOG,GPIO_Pin_4} ,{GPIOG,GPIO_Pin_2}, {GPIOD,GPIO_Pin_14},{GPIOD,GPIO_Pin_12}},//row 横行
- {{GPIOD,GPIO_Pin_10},{GPIOD,GPIO_Pin_8}, {GPIOB,GPIO_Pin_14},{GPIOB,GPIO_Pin_12}} //col 竖行
- #define row 0
- #define col 1
- #define RCC_APB2_GPIOX RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOG//IO时钟
- #define MAX_Time 36000000 // 松手检测最大延时
- //按键初始化函数
- void KEY_Init(void)
- u8 i;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2_GPIOX,ENABLE);//使能PORTC时钟
- for(i=0;i<4;i++)
- GPIO_InitStructure.GPIO_Pin = KPIN[row][i].GPIO_Pin;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //设置成推挽输出
- GPIO_Init(KPIN[row][i].GPIOX, &GPIO_InitStructure);//初始化row
- GPIO_ResetBits(KPIN[row][i].GPIOX,KPIN[row][i].GPIO_Pin);
- for(i=0;i<4;i++)
- GPIO_InitStructure.GPIO_Pin = KPIN[col][i].GPIO_Pin;//PC5
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //设置成上拉输入
- GPIO_Init(KPIN[col][i].GPIOX, &GPIO_InitStructure);//初始化col
- u8 ReScan(GPIO_TypeDef* GPIOX,uint16_t colPin,u8 colIndex)
- u8 i;
- delay_ms(10);//消抖延时
- for(i = 0;i<4;i++){
- GPIO_SetBits(KPIN[row][i].GPIOX,KPIN[row][i].GPIO_Pin);//每个行置1
- if((GPIO_ReadInputDataBit(GPIOX, colPin) == 1)) //如果列也变了 行的值就知道了 为 i
- GPIO_ResetBits(KPIN[row][i].GPIOX,KPIN[row][i].GPIO_Pin); //行恢复 置0
- return colIndex+i*4+1;//返回的数据 为1-16 对应4x4键盘的16个键
- return 0;
- u8 KEY_Scan(void)
- u8 i,keyvalue;
- //u32 j=0;
- if(GPIO_ReadInputDataBit(KPIN[col][i].GPIOX,KPIN[col][i].GPIO_Pin) == 0)//检测列 列值为 i
- keyvalue = ReScan(KPIN[col][i].GPIOX,KPIN[col][i].GPIO_Pin,i);//检测行 取键值
- while(GPIO_ReadInputDataBit(KPIN[col][i].GPIOX,KPIN[col][i].GPIO_Pin) == 0);
- // while((GPIO_ReadInputDataBit(KPIN[col][i].GPIOX,KPIN[col][i].GPIO_Pin) == 0)&&(j<MAX_Time))j++;//松手检测
- return keyvalue;//返回键值
- return 0;
复制代码 |
