#include <reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
#include "intrins.h"
#define u8 unsigned char
#define u16 unsigned int
uchar yushe_wendu=50; //温度预设值
uchar yushe_yanwu=100; //光照预设值
uchar yushe_tianranqi=100; //天然气预设值
uint wendu; //温度值全局变量
uchar yanwu; //用于读取ADC数据
uchar tianranqi; //用于读取ADC数据
uint times = 0; //变量times,计数,用于液晶切换显示
uchar shezhi_flag = 0; //变量标志位,用于切换显示设置天然气预设值
uchar Mode=0; //=1是设置温度阀值 =2是设置光照阀值 =0是正常监控模式
uint Buzzer=0;
uint count = 0;
sbit Led_Yellow =P2^4; //黄灯
sbit speaker =P2^0; //蜂鸣器
sbit cg=P2^3; //总开关
sbit c1_k=P1^1; //窗帘1开关
sbit c2_k=P1^4; //窗帘2开关
void delay_ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<110;j++);
sbit LCDRS = P2^7;
sbit LCDEN = P2^6;
sbit D0 = P0^0;
sbit D1 = P0^1;
sbit D2 = P0^2;
sbit D3 = P0^3;
sbit D4 = P0^4;
sbit D5 = P0^5;
sbit D6 = P0^6;
sbit D7 = P0^7;
void LCDdelay(uint z) //该延时大约100us(不精确,液晶操作的延时不要求很精确)
uint x,y;
for(x=z;x>0;x--)
for(y=10;y>0;y--);
void LCD_WriteData(u8 dat)
if(dat&0x01)D0=1;else D0=0;
if(dat&0x02)D1=1;else D1=0;
if(dat&0x04)D2=1;else D2=0;
if(dat&0x08)D3=1;else D3=0;
if(dat&0x10)D4=1;else D4=0;
if(dat&0x20)D5=1;else D5=0;
if(dat&0x40)D6=1;else D6=0;
if(dat&0x80)D7=1;else D7=0;
void write_com(uchar com)
LCDRS=0;
LCD_WriteData(com);
LCDdelay(5);
LCDEN=1;
LCDdelay(5);
LCDEN=0;
void write_data(uchar date)
LCDRS=1;
LCD_WriteData(date);
LCDdelay(5);
LCDEN=1;
LCDdelay(5);
LCDEN=0;
void SelectPosition(unsigned char x,unsigned char y)
if (x == 0)
write_com(0x80 + y); //表示第一行
write_com(0xC0 + y); //表示第二行
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
SelectPosition(x,y) ;
while (*s)
write_data( *s);
s ++;
void LCD_Write_Char(u8 x,u8 y,u16 s,u8 l)
if(l>=5)
write_data(0x30+s/10000%10); //万位
if(l>=4)
write_data(0x30+s/1000%10); //千位
if(l>=3)
write_data(0x30+s/100%10); //百位
if(l>=2)
write_data(0x30+s/10%10); //十位
if(l>=1)
write_data(0x30+s%10); //个位
void Init1602()
uchar i=0;
write_com(0x38);//屏幕初始化
write_com(0x0c);//打开显示 无光标 无光标闪烁
write_com(0x06);//当读或写一个字符是指针后一一位
write_com(0x01);//清屏
void Display_1602(yushe_wendu,yushe_yanwu,c,temp)
//显示预设温度
LCD_Write_Char(0,6,yushe_wendu,2) ;
//显示预设光照
LCD_Write_Char(0,13,yushe_yanwu,3) ;
//时时温度
LCD_Write_Char(1,6,c/10,2) ;
write_data('.');
LCD_Write_Char(1,9,c%10,1) ;
//时时光照
LCD_Write_Char(1,13,temp,3) ;
ADC0832相关函数
sbit ADCS =P1^5; //ADC0832 片选
sbit ADCLK =P1^2; //ADC0832 时钟
sbit ADDI =P1^3; //ADC0832 数据输入 /*因为单片机的管脚是双向的,且ADC0832的数据输入输出不同时进行,
sbit ADDO =P1^3; //ADC0832 数据输出 /*为节省单片机引脚,简化电路所以输入输出连接在同一个引脚上
// 函数: unsigned int Adc0832(unsigned char channel)
// 应用: temp=Adc0832(0);
// 描述: 读取0通道的AD值
// 参数: channel:通道0和通道1选择
// 返回: 选取通道的AD值
// 版本: VER1.0
// 日期: 2015-05-29
// 备注:
uchar i=0;
uchar j;
uint dat=0;
uchar ndat=0;
uchar Vot=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=1;
_nop_();
_nop_();
ADCS=0;//拉低CS端
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿1
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=channel&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿2
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=(channel>>1)&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿3
ADDI=1;//控制命令结束
_nop_();
_nop_();
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;//收数据
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次时钟脉冲
_nop_();
_nop_();
dat<<=1;
if(i==7)dat|=ADDO;
for(i=0;i<8;i++)
j=0;
j=j|ADDO;//收数据
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次时钟脉冲
_nop_();
_nop_();
j=j<<7;
ndat=ndat|j;
if(i<7)ndat>>=1;
ADCS=1;//拉低CS端
ADCLK=0;//拉低CLK端
ADDO=1;//拉高数据端,回到初始状态
dat<<=8;
dat|=ndat;
return(dat); //return ad data
DS18B20相关函数
sbit DQ = P1^0; //ds18b20的数据引脚
/*****延时子程序:该延时主要用于ds18b20延时*****/
void Delay_DS18B20(int num)
while(num--) ;
/*****初始化DS18B20*****/
void Init_DS18B20(void)
unsigned char x=0;
DQ = 1; //DQ复位
Delay_DS18B20(8); //稍做延时
DQ = 0; //单片机将DQ拉低
Delay_DS18B20(80); //精确延时,大于480us
DQ = 1; //拉高总线
Delay_DS18B20(14);
x = DQ; //稍做延时后,如果x=0则初始化成功,x=1则初始化失败
Delay_DS18B20(20);
/*****读一个字节*****/
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 给脉冲信号
dat>>=1;
DQ = 1; // 给脉冲信号
if(DQ)
dat|=0x80;
Delay_DS18B20(4);
return(dat);
/*****写一个字节*****/
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
Delay_DS18B20(5);
DQ = 1;
dat>>=1;
/*****读取温度*****/
unsigned int ReadTemperature(void)
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0x44); //启动温度转换
Init_DS18B20();
WriteOneChar(0xBE); //读取温度寄存器
a=ReadOneChar(); //读低8位
b=ReadOneChar(); //读高8位
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5; //放大10倍输出并四舍五入
return(t);
/*****校准温度*****/
u16 check_wendu(void)
u16 c;
c=ReadTemperature()-5; //获取温度值并减去DS18B20的温漂误差
if(c<1) c=0;
if(c>=900) c=0;
return c;
按键检测相关函数
//按键
sbit Key1=P1^6; //设置键
sbit Key2=P1^7; //加按键
sbit Key3=P3^2; //减按键
#define KEY_SET 1 //设置
#define KEY_ADD 2 //加
#define KEY_MINUS 3 //减
// 函数: u8 Key_Scan()
// 应用: temp=u8 Key_Scan();
// 描述: 按键扫描并返回按下的键值
// 参数: NONE
// 返回: 按下的键值
// 版本: VER1.0
// 日期: 2015-05-29
// 备注: 该函数带松手检测,按下键返回一次键值后返回0,直至第二次按键按下
u8 Key_Scan()
static u8 key_up=1;//按键按松开标志
if(key_up&&(Key1==0||Key2==0||Key3==0))
delay_ms(10);//去抖动
key_up=0;
if(Key1==0) return 1;
else if(Key2==0)return 2;
else if(Key3==0)return 3;
else if(Key1==1&&Key2==1&&Key3==1)
key_up=1;
return 0;// 无按键按下
/*************定时器0初始化程序***************/
void time_init()
TMOD=0X01; //定时器0、工作方式1
TH0=(65536-10000)/256;
TL0=(65536-10000)%256;
EA=1; //开总中断
ET0=1; //开定时器0中断
TR0=1; //允许定时器0定时
/*************定时器0中断服务程序***************/
void time0_int() interrupt 1
TH0 = (65536-1000)/256;
TL0 = (65536-1000)%256; // 50ms 12M
count++;
if(count>80)
count = 0;
wendu=check_wendu(); //读取温度值
yanwu=Adc0832(0); //读取光照值
tianranqi=Adc0832(1); //读取天然气值
if((wendu>=(yushe_wendu*10))||(tianranqi>yushe_tianranqi)) //温度大于等于预设温度值时(为什么是大于预设值*10:因为我们要显示的温度是有小数点后一位,是一个3位数,25.9°C时实际读的数是259,所以判断预设值时将预设值*10)
speaker=0; //打开蜂鸣器报警
Led_Yellow=0; //打开温度报警灯
else //温度值小于预设值时
speaker=1;
Led_Yellow=1; //关闭报警灯
if(yanwu>=yushe_yanwu+20) //光照值大于等于预设值时
cg = 0;
c1_k = 1;
c2_k = 0;
delay_ms(50);
c1_k = 0;
c2_k = 0;
if(yanwu<=yushe_yanwu-20) //光照值大于等于预设值时
cg = 0;
c1_k = 0;
c2_k = 1;
delay_ms(50);
c1_k = 0;
c2_k = 0;
void main (void)
u8 key;
cg = 1;
c1_k = 0;
c2_k = 0;
speaker = 1;
Led_Yellow = 1;
wendu=check_wendu(); //初始化时调用温度读取函数 防止开机85°C
time_init();
Init1602(); //调用初始化显示函数
while (1) //主循环
key=Key_Scan(); //按键扫描
if(key==KEY_SET)
Mode++;
switch(Mode) //判断模式的值
case 0: //监控模式
times++; //计数
if( times >= 500 ) //大于500,清零
times = 0;
if( times <= 300 ) //小于300,显示光强、温度信息
if( times == 1 )
LCD_Write_String(0,0,"SET T:00 L:000"); //开机界面
LCD_Write_String(1,0,"NOW T:00.0 L:000");
Display_1602(yushe_wendu,yushe_yanwu,wendu,yanwu); //显示预设温度,预设光照,温度值,光照值
break;
else //大于300,显示天然气信息
if( times == 301 )
LCD_Write_String(0,0,"SET yanwu:00 "); //开机界面
LCD_Write_String(1,0,"NOW yanwu:00.0 ");
// Display_1602(yushe_wendu,yushe_yanwu,wendu,yanwu); //显示预设温度,预设光照,温度值,光照值
LCD_Write_Char(0,10,yushe_tianranqi,3) ;//显示预设光照
LCD_Write_Char(1,10,tianranqi,3) ;//显示预设光照
write_com( 0x80+0x40+10);
write_data( tianranqi/100+0x30);
write_data( tianranqi%100/10+0x30);
write_data( tianranqi%10+0x30);
write_data( ' ');
break;
case 1://预设温度模式
SelectPosition(0,5) ; //指定位置
write_com(0x0d); //阴影闪烁
if(key==KEY_ADD) //加键按下
yushe_wendu++; //预设温度值(阀值)加1
if(yushe_wendu>=99) //当阀值加到大于等于99时
yushe_wendu=99; //阀值固定为99
LCD_Write_Char(0,6,yushe_wendu,2) ;//显示预设温度
if(key==KEY_MINUS) //减键按下
if(yushe_wendu<=1) //当温度上限值减小到1时
yushe_wendu=1; //固定为1
yushe_wendu--; //预设温度值减一,最小为0
break; //执行后跳出switch
case 2: //预设光照模式
SelectPosition(0,12) ; //指定位置
write_com(0x0d); //打开显示 无光标 光标闪烁
if(yushe_yanwu>=255) //当阀值加到大于等于255时
yushe_yanwu=254; //阀值固定为254
yushe_yanwu++; //预设光照值(阀值)加1,最大为255
LCD_Write_Char(0,13,yushe_yanwu,3) ;//显示预设光照
if(yushe_yanwu<=1) //当光照上限值减小到1时
yushe_yanwu=1; //固定为1
yushe_yanwu--; //预设温度值减一,最小为0
break;
case 3: //预设天然气设置
if( shezhi_flag == 0 )
LCD_Write_String(0,0,"SET yanwu: "); //界面
LCD_Write_String(1,0,"NOW yanwu: ");
shezhi_flag = 1;
LCD_Write_Char(0,10,yushe_tianranqi,3) ;//显示天然气设置
LCD_Write_Char(1,10,tianranqi,3) ;//显示预设天然气设置
write_data( ' ');
SelectPosition(0,9) ; //指定位置
if(yushe_tianranqi>=255) //当阀值加到大于等于255时
yushe_tianranqi=254; //阀值固定为254
yushe_tianranqi++; //预设天然气设置(阀值)加1,最大为255
LCD_Write_Char(0,10,yushe_tianranqi,3) ;//显示预设天然气设置
if(yushe_tianranqi<=1) //当天然气设置上限值减小到1时
yushe_tianranqi=1; //固定为1
yushe_tianranqi--; //预设温度值减一,最小为0
break;
default :
Mode=0; //恢复正常模式
shezhi_flag = 0;
times = 0;
break;
