#include <AT89X51.H>
unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
unsigned char disbuf[4]={0,0,0,0};
// 函数原形定义
void main (void); // 主函数
void LED4_Display (void); // LED显示
void LED_OUT(uchar X); // LED单字节串行移位函数
unsigned char code LED_0F[]; // LED字模表
sbit DIO = P1^0; //串行数据输入
sbit RCLK = P1^1; //时钟脉冲信号——上升沿有效
sbit SCLK = P1^2; //打入信号————上升沿有效
// 全局变量
uchar LED[8]; //用于LED的8位显示缓存
// 主程序
void main (void)
LED[0]=1;
LED[1]=2;
LED[2]=3;
LED4_Display ();
unsigned char code *led_table; // 查表指针
uchar i;
uchar j;
j=231; // *****
switch(j)
case 123: //显示第1位
led_table = LED_0F + LED[0];
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//显示第2位
led_table = LED_0F + LED[1];
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//显示第3位
led_table = LED_0F + LED[2];
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;break;
case 132: //显示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//显示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//显示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;break;
case 213: //显示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//显示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//显示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;break;
case 231: //显示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//显示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//显示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;break;
case 312: //显示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//显示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//显示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;break;
case 321: //显示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;
//显示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//显示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;break;
/* //显示第1位
i = *led_table;
LED_OUT(i);
LED_OUT(0x04);
RCLK = 0;
RCLK = 1;
//显示第2位
i = *led_table;
LED_OUT(i);
LED_OUT(0x02);
RCLK = 0;
RCLK = 1;
//显示第3位
i = *led_table;
LED_OUT(i);
LED_OUT(0x01);
RCLK = 0;
RCLK = 1;*/
uchar i;
for(i=8;i>=1;i--)
if (X&0x80) DIO=1; else DIO=0;
X<<=1;
SCLK = 0;
SCLK = 1;
unsigned char code LED_0F[] =
{// 0 1 2 3 4 5 6 7 8 9 A b C d E F -
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
