W25Q16是一款16Mbit(8MB)Flash型存储器件,可用于声音、文本和数据的存储,典型的应用是构建中文字库。 W25Q16与SC95F8616开发板的连接关系为: CS--P10 DI--P13 CLK--P12 D0--P11 串口通信模块与SC95F8616开发板的连接关系为: TX--P21 RX--P20 软按键与开发板的连接关系为: K1 -- P06 K2 -- P07 OLED 屏与开发板的连接关系为: SDA P16 SCK P17
为便于OLED屏最终由存储模块中读取字模,这里先将OLED屏显示的字库,转存到存储模块内。 该字库的内容为: const unsignedchar Hzk[][32]={ //海 {0x10,0x60,0x02,0x0C,0xC0,0x10,0x08,0xF7,0x14,0x54,0x94,0x14,0xF4,0x04,0x00,0x00, 0x04,0x04,0x7C,0x03,0x00,0x01,0x1D,0x13,0x11,0x55,0x99,0x51,0x3F,0x11,0x01,0x00}, ... //临 {0x40,0x20,0x10,0x0C,0x23,0xC4,0x08,0x10,0x20,0xFE,0x02,0x22,0xDA,0x06,0x00,0x00, 0x00,0x01,0x05,0x09,0x11,0x69,0x05,0x03,0x00,0xFF,0x08,0x10,0x08,0x07,0x00,0x00}, };
键控进行转存的代码如下: - while(GPIO_ReadPin(GPIO0, GPIO_PIN_6));
- for(i=0;i<16;i++)
- Rec_DATA[i] = 0;
- printf("W25Q16 Erase \n\r");
- W25_SectorErase(0x000000);
- printf("W25Q16 Write \n\r");
- Z=0;
- for(i=0;i<10;i++)
- for(j=0;j<16;j++)
- Send_DATA[j]= Hzk[i][j];
- SPI_Flash_Write_NoCheck(Send_DATA,Z,16);
- Z=Z+16;
- for(j=0;j<16;j++)
- Send_DATA[j]= Hzk[i][j+16];
- Z=Z+16;
通过读取存储模块,对字库转存的审核代码如下:- Z=0;
- for(j=0;j<20;j++)
- SPI_Flash_Read(Rec_DATA,Z,16);
- for(i=0;i<16;i++)
- printf("%c",Rec_DATA[i]);
- Z=Z+16;
按K2 键后的审核数据
经对比,它与转存的数组内容是一致的,转存成功。
为对比用数组和存储模块的字库显示效果,相应的代码如下: - OLED_Init();
- OLED_Clear();
- OLED_ShowString(0,0,"SC95F8616",16);
- // 使用数组字库显示
- OLED_ShowCHinesey(0,2,0);
- OLED_ShowCHinesey(16,2,1);
- OLED_ShowCHinesey(32,2,2);
- OLED_ShowCHinesey(48,2,3);
- OLED_ShowCHinesey(64,2,4);
- OLED_ShowCHinesey(0,4,5);
- OLED_ShowCHinesey(16,4,6);
- OLED_ShowCHinesey(32,4,7);
- OLED_ShowCHinesey(48,4,8);
- OLED_ShowCHinesey(64,4,9);
- // 使用存储模块字库显示
- OLED_Clear();
- OLED_ShowString(0,0,"W25Q16_OLED",16);
- OLED_ShowCHinese(0,2,0);
- OLED_ShowCHinese(16,2,1);
- OLED_ShowCHinese(32,2,2);
- OLED_ShowCHinese(48,2,3);
- OLED_ShowCHinese(64,2,4);
- OLED_ShowCHinese(0,4,5);
- OLED_ShowCHinese(16,4,6);
- OLED_ShowCHinese(32,4,7);
- OLED_ShowCHinese(48,4,8);
- OLED_ShowCHinese(64,4,9);
使用的显示函数分别为OLED_ShowCHinesey 和OLED_ShowCHinese ,其内容分别如下:数组字库显示函数 voidOLED_ShowCHinesey(unsigned char x,unsigned char y,unsigned char no) - {
- unsigned char t;
- OLED_Set_Pos(x,y);
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[no][t],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[no][16+t],OLED_DATA);
存储模块字库显示函数- void OLED_ShowCHinese(unsigned char x,unsigned char y,unsigned char no)
- unsigned char t; //,adder=0
- uint32_t p=0;
- p=p+no*32;
- SPI_Flash_Read(Rec_DATA,p,16);
- for(t=0;t<16;t++)
- OLED_WR_Byte(Rec_DATA[t],OLED_DATA);
- printf("%c",Rec_DATA[t]);
- p=p+16;
- for(t=0;t<16;t++)
使用数组字库显示效果
读取存储模块显示效果
经对比,两种相差无异,完全可以用存储模块来替代原数组字库,进而能更多地显示中文内容。
