定时器时间可调,时间显示正常,但美中不足之处程序有点瑕疵,望高手指点
- #include<REG52.h>
- #include<24c02.h>
- #include<1602.h>
- sbit s1=P3^2;//光标移位
- sbit s2=P3^3;//加键
- sbit s3=P3^4;//减键
- sbit beep=P1^0;//蜂鸣器
- unsigned char count,s1num;
- unsigned char miao,shi,fen;
- void delayms(unsigned int time)
- unsigned int x,y;
- for(x=time;x>0;x--)
- for(y=110;y>0;y--);
- void di()
- beep=0;
- delayms(100);
- beep=1;
- void write_sfm(uchar add,uchar date)
- uchar shi,ge;
- shi=date/10;
- ge=date%10;
- write_Com(0x80+0x40+add);
- write_Date(0x30+shi);
- write_Date(0x30+ge);
- void InitTimer0(void)
- TMOD = 0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- void keyscan()
- if(s1==0)//0是高电平,开
- delayms(5);
- if(s1==0)
- s1num++;
- while(!s1);
- di();
- if(s1num==1)
- TR0=0;
- write_Com(0x80+0x40+10);
- write_Com(0x0f);
- if(s1num==2)
- write_Com(0x80+0x40+7);
- if(s1num==3)
- write_Com(0x80+0x40+4);
- if(s1num==4)
- s1num=0; //记录键清零
- write_Com(0x0c);
- TR0=1; //到第四次启动定时器开始走
- if(s1num!=0) //按完S1才能激活S2
- if(s2==0)
- delayms(5);
- if(s2==0)
- while(!s2);
- di();
- if(s1num==1)//按下每秒加1
- miao++;
- if(miao==60)
- miao=0;
- write_sfm(10,miao);//每调节一次送液晶显示一次
- write_Com(0x80+0x40+10);//显示输入地址
- write_add(1,miao);//调节完毕数据立即保存
- if(s1num==2)//按下每分加1
- fen++;
- if(fen==60)
- fen=0;
- write_sfm(7,fen);//每调节一次送液晶显示一次
- write_Com(0x80+0x40+7);//显示输入地址
- write_add(2,fen);//调节完毕数据立即保存
- if(s1num==3)//按下每时加1
- shi++;
- if(shi==24)
- shi=0;
- write_sfm(4,shi);//每调节一次送液晶显示一次
- write_Com(0x80+0x40+4);//显示输入地址
- write_add(3,shi);//调节完毕数据立即保存
- if(s3==0)
- delayms(5);
- if(s3==0)
- while(!s3);
- di();
- if(s1num==1)//按下每秒减1
- miao--;
- if(miao==-1)
- miao=59;
- if(s1num==2)//按下每分减1
- fen--;
- if(fen==-1)
- fen=59;
- if(s1num==3)//按下每时减1
- shi--;
- if(shi==-1)
- shi=23;
- void main()
- P0=0X00;
- dula=0;
- wela=0;
- init();
- lcdinit();
- InitTimer0();
- miao=read_add(1);
- fen=read_add(2);
- shi=read_add(3);
- LCD_Write_String(1,2,"2017-6-17-MON");
- LCD_Write_String(0,5,"16-26-00");
- while(1)
- keyscan();
- void timer0() interrupt 1
- count++;
- if(count==20)
- count=0;
- miao++;
- if(miao==60)
- miao=0;
- fen++;
- if(fen==60)
1602 24c02 定时器时间.zip
(57.67 KB, 下载次数: 46)
