查看: 3189|回复: 0
HX711压力传感器+51单片机程序
ID:872202 发表于 2021-1-2 15:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
数模转换元件为HX711
程序:
#include <reg51.h>
#include <intrins.h>
sbit HX711_DOUT=P2^1;
sbit HX711_SCK=P2^0;
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
long Weight_Shiwu = 0;
unsigned char flag = 0;
bit Flag_ERROR = 0;
void Delay_ms(unsigned int);
#define GapValue 400
sbit KEY1=P3^2;
sbit LCD1602_RS=P2^6;
sbit LCD1602_RW=P2^5;
sbit LCD1602_EN=P2^7;
unsigned char Num = 0;
bit Flag_Receive_OK = 0;
void Uart_Init(void);
void Send_Word(unsigned char *p);
void Get_Weight();
void Scan_Key();
void Get_Maopi();
void Send_ASCII(unsigned char c);
void LCD1602_delay_ms(unsigned int n);
void LCD1602_write_com(unsigned char com);
void LCD1602_write_data(unsigned char dat);
void LCD1602_write_word(unsigned char *s);
void Init_LCD1602();
void Delay__hx711_us(void);
unsigned long HX711_Read(void);
     Uart_Init();
    Send_Word("Welcome to use!\n");
        Init_LCD1602();
        LCD1602_write_com(0x80);
        LCD1602_write_word("  2021-1-4   ");
        Delay_ms(1000);                 //延时,等待传感器稳定
        Get_Maopi();                                //称毛皮重量
                EA = 0;
                Get_Weight();
                EA = 1;
                Scan_Key();
                if( Flag_ERROR == 1)
            Send_Word("ERROR\n");
                        LCD1602_write_com(0x80+0x40);
                        LCD1602_write_word("ERROR ");
            Send_ASCII(Weight_Shiwu/1000 + 0X30);
            Send_ASCII(Weight_Shiwu%1000/100 + 0X30);
            Send_ASCII(Weight_Shiwu%100/10 + 0X30);
            Send_ASCII(Weight_Shiwu%10 + 0X30);
            Send_Word(" MPa\n");
                        LCD1602_write_data(Weight_Shiwu/1000 + 0X30);
            LCD1602_write_data(Weight_Shiwu%1000/100 + 0X30);
            LCD1602_write_data(Weight_Shiwu%100/10 + 0X30);
            LCD1602_write_data(Weight_Shiwu%10 + 0X30);
                        LCD1602_write_word(" MPa");
//扫描按键
void Scan_Key()
        if(KEY1 == 0)
                Delay_ms(5);
                if(KEY1 == 0)
                        while(KEY1 == 0);
                        Get_Maopi();
void Get_Weight()
        Weight_Shiwu = HX711_Read();
                Weight_Shiwu = Weight_Shiwu - Weight_Maopi;
        if(Weight_Shiwu > 0)
                Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/GapValue);
                if(Weight_Shiwu > 5000)
                        Flag_ERROR = 1;
                        Flag_ERROR = 0;
                Weight_Shiwu = 0;
void Get_Maopi()
        Weight_Maopi = HX711_Read();
void Delay_ms(unsigned int n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
//写指令
LCD1602_RS = 0;
        LCD1602_delay_ms(1);
        LCD1602_EN = 1;
P0 = com;
        LCD1602_EN = 0;
//写数据
        LCD1602_RS = 1;
        P0 = dat;
        LCD1602_EN = 1;
        LCD1602_EN = 0;
//连续写字符
        while(*s>0)
                LCD1602_write_data(*s);
                s++;
void Init_LCD1602()
        LCD1602_EN = 0;
        LCD1602_RW = 0;                                                //设置为写状态
        LCD1602_write_com(0x38);                        //显示模式设定
        LCD1602_write_com(0x0c);                        //开关显示、光标有无设置、光标闪烁设置
        LCD1602_write_com(0x06);                        //写一个字符后指针加一
        LCD1602_write_com(0x01);                        //清屏指令
        SCON = 0X50;  //UART方式1;8位UART
        REN  = 0;     //不允许串行口接收数据
        PCON = 0x00;  //SMOD=0;波特率不加倍
        TMOD = 0x21;  //T1方式2,用于产生波特率
        TH1  = 0xFD;  //装初值
        TL1  = 0xFD;
        TR1  = 1;     //启动定时器1
        EA   = 1;     //打开全局中断控制
        ES   = 0;     //串行口中断
void Send_Word(unsigned char *p)                                //发送字符串
         while(*p)
                 SBUF=*(p++);
                while(TI==0)
                TI=0;
void Send_ASCII(unsigned char c)                                //发送一个字符
    TI=0;
    SBUF=c;
    while(TI==0);
    TI=0;
        _nop_();
        _nop_();
//读取HX711
unsigned long HX711_Read()
        unsigned long count;
        unsigned char i;
          HX711_DOUT=1;
        Delay__hx711_us();
          HX711_SCK=0;
          count=0;
        EA = 1;
          while(HX711_DOUT);
        EA = 0;
          for(i=0;i<24;i++)
                  HX711_SCK=1;
                  count=count<<1;
                HX711_SCK=0;
                  if(HX711_DOUT)
                        count++;
         HX711_SCK=1;
    count=count^0x800000;
        Delay__hx711_us();
        HX711_SCK=0;
        return(count);
收藏收藏1 分享淘帖 顶 踩
