查看: 1782|回复: 0
TM1637驱动程序
ID:917238 发表于 2021-8-14 03:40 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include //包含52单片机头文件
#include "Delay.h"
sbit I2C_SCL = P2^1;   //定义模拟IIC总线的时钟线
sbit I2C_SDA = P2^0;   //定义模拟IIC总线的数据线
#define TM1637_BRIGHTNESS 7 // 0 - 7
void I2C_delay()
    nop_();
void I2C_start()
    I2C_SCL = 1;
    I2C_SDA = 1;
    I2C_delay();
    I2C_SDA = 0; // 时钟线设置为常态,低电平。
I2C 总线写1个字节
不包含应答位的检测
void I2C_write_byte(char byte_to_write)
    unsigned char i;
    for(i=0; i>= 1;
    return;
void I2C_check_ack()
    // I2C 检查应答位,实际未检查,只发送了应答位时钟,认为TM1637工作正常
    I2C_SCL = 0;
    I2C_delay();//在第八个时钟下降沿之后延时5us,开始判断ACK 信号
    while(I2C_SDA)
    I2C_SCL = 1;
    I2C_delay();
    I2C_SCL=0;
void I2C_send_ack()
    I2C_SDA = 0;
    I2C_delay();
    I2C_SCL = 1;
    I2C_delay();
    I2C_SCL = 0;
    I2C_delay();
    I2C_SDA = 1;
    I2C_delay();
void I2C_stop()
    I2C_SCL = 0;
    I2C_delay();
    I2C_SDA = 0;
    I2C_delay();
    I2C_SCL = 1;
    I2C_delay();
    I2C_SDA = 1;
// TM1637模块操作函数
void TM1637_write_command_byte(unsigned char command)
    I2C_start();
    I2C_write_byte(command);
    I2C_check_ack();
    I2C_stop();
// bright : 0 - 7
void TM1637_display_switch_and_bright(bit enable_display, unsigned char bright)
    TM1637_write_command_byte(0x80 + (enable_display ? 0x08 : 0x00) + bright);
void TM1637_write_display_bytes(unsigned char first_addr,
                                unsigned char bytes_to_write[],
                                unsigned char num_of_bytes)
    unsigned char i;
    I2C_start();
    I2C_write_byte(0x40);
    I2C_check_ack();
    I2C_stop();
    I2C_start();
    I2C_write_byte(0xC0 + first_addr);
    I2C_check_ack();
    for(i=0; i<num_of_bytes; i++)
        I2C_write_byte(bytes_to_write[i]);
        I2C_check_ack();
    I2C_stop();
// addr: 0 - 5
void TM1637_write_display_byte(unsigned char addr, unsigned char segments)
    I2C_start();
    I2C_write_byte(0x40 + addr);
    I2C_check_ack();
    I2C_stop();
    I2C_start();
    I2C_write_byte(0xC0 + addr);
    I2C_check_ack();
    I2C_write_byte(segments);
    I2C_check_ack();
    I2C_stop();
code unsigned char TM1637_SEG_TAB[] =
     0x3F // 00111111 0
    ,0x06 // 00000110 1
    ,0x5B // 01011011 2
    ,0x4F // 01001111 3
    ,0x66 // 01100110 4
    ,0x6d // 01101101 5
    ,0x7d // 01111101 6
    ,0x07 // 00000111 7
    ,0x7F // 01111111 8
    ,0x6F // 01101111 9
    ,0x77 // 01110111 A
    ,0x7C // 01111100 b
    ,0x39 // 00111001 C
    ,0x5E // 01011110 d
    ,0x79 // 01111001 E
    ,0x71 // 01110001 F
void TM1637_show_digit(unsigned char pos, unsigned char digit, bit with_dot)
    TM1637_write_display_byte(pos, TM1637_SEG_TAB[digit] | (with_dot ? 0x20 : 0x00));
void TM1637_init()
    unsigned char i;
    TM1637_display_switch_and_bright(1, TM1637_BRIGHTNESS);
    for(i=0; i<6; i++)
        TM1637_write_display_byte(i, 0xFF);
    Delay200ms();
    for(i=0; i<6; i++)
        TM1637_write_display_byte(i, 0x00);
    Delay200ms();
    for(i=0; i<6; i++)
    Delay200ms();
    for(i=0; i<6; i++)
    Delay200ms();
void TM1637()
    unsigned char seg;
    unsigned char i, j;
    TM1637_init();
        for(i=0; i<16; i++)
            for(j=0; j<6; j++)
                TM1637_show_digit(j, i, 0);
            Delay1s();
收藏收藏1 分享淘帖 顶 踩
