基于arduino的计时器(包涵倒计时、暂停、重置),在proteus8中仿真通过。用了两组1673的时钟芯片。
Arduino代码如下:
- #include <SevenSegmentTM1637.h>
- #include <SevenSegmentExtended.h>
- volatile int minute;
- volatile int second;
- volatile int order;
- volatile int full;
- volatile int empty;
- volatile int setvalue;
- volatile int topvalue;
- boolean timerState=LOW;
- SevenSegmentExtended display(8,9);
- void setup(){
- pinMode(2, INPUT);
- minute = 0;
- second = 0;
- order = 0;
- full = 0;
- empty = 0;
- setvalue = 5;
- topvalue = 0;
- display.begin();
- order = 0;
- // 倒计时时sencond与minute从full开始计时,顺计时从empty开始计时
- if (order == 0) {
- empty = 0;
- full = 59;
- minute = setvalue;
- second = 0;
- topvalue = 0;
- } else {
- empty = 59;
- full = 0;
- minute = 0;
- // 设置为x分钟,加上秒钟走59,实际多走了一分钟,所以减一
- topvalue = setvalue - 1;
- attachInterrupt(digitalPinToInterrupt(2),interruptFun,LOW);
- void loop(){
- // 决定顺计时倒计时0为倒计时,1为顺计时
- // 设置计时的最大数值
- // 倒计时时topvalue=0时minute重置为setvalue
- // 顺计时topvalue=setvalue值时被重置
- // minute=0
- if(timerState)
- display.printTime(minute,second,true);
- delayMicroseconds(1);
- if (second == empty && minute == topvalue) {
- if (order == 0) {
- // 当minute达到设定的值则
- second = empty;
- } else {
- // 当minute达到设定的值则
- minute = full;
- second = full;
- } else if (second == empty) {
- if (order == 0) {
- second = 59;
- minute = minute - 1;
- } else {
- second = 0;
- minute = minute + 1;
- } else {
- if (order == 0) {
- second = second - 1;
- } else {
- second = second + 1;
- void interruptFun()
- timerState=!timerState;
- digitalWrite(5,timerState);
- // Inside the attached function, delay() won't work and the value returned by millis() will not increment.
- // delay(5000);
Proteus8.8版本的仿真图下载:
countDowntimer.zip
(31.11 KB, 下载次数: 51)
