查看: 1495|回复: 0
单片机数码管秒表程序
ID:1013275 发表于 2022-4-18 13:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
制作一个数码管秒表,用两个led数码管显示,最小计时单位为100ms,范围为0.1-9.9s,按下第一个功能键后开始计时,第二次按下时停止
#include <reg51.h>
unsigned char code discode1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
unsigned char code discode2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char timer=0;
unsigned char second;
unsigned char key=0;
main()
        TMOD=0x01;
        ET0=1;
        EA=1;
        second=0;
        P0=discode1[second/10];
        P2=discode2[second%10];
                if((P3&0x01)==0x00)
                   key++;
                   switch(key)
                        case 1:
                                   TH0=0xee;
                                   TL0=0x00;
                                   TR0=1;
                                   break;
                        case 2:
                                TR0=0;
                                break;
                        case 3:
                                key=0;
                                second=0;
                                break;
                   while((P3&0x01)==0x00);
void int_T0() interrupt 1 using 0
        TR0=0;
        TH0=0xee;
        TL0=0X00;
        timer++;
         if(timer==20)
                 timer=0;
                second++;
        if(second==99)
                 TR0=0;
                second=0;
                key=2;
                TR0=1;
附件里面是仿真图,不含代码(自行生成hex文件)仅供参考,请自行测试,如有错误请告知: 制作LED数码管秒表.zip (40.65 KB, 下载次数: 13)
