#include<reg52.h>
uchar code table[16]={
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e
uchar num,temp,num;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
P2=0x0;
P0=0x0;
P1=0xfe;
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=temp&0xfe)
temp=P1;
switch(temp)
case 0xee:num=1;
break;
case 0xde:num=2;
break;
case 0xbe:num=3;
break;
case 0x7e:num=4;
break;
P2=0;
P0=table[num-1];
