ADXL345怎么才能进入自动休眠 下面是我的程序,一直进不了休眠,大神帮我看看:
Single_Write_ADXL345(POWER_CTL,0x00);
Single_Write_ADXL345(INT_ENABLE,0x00);
Single_Write_ADXL345(BW_RATE,0x08); //0000 0110速率设定为6.25 参考pdf13页
Single_Write_ADXL345(DATA_FORMAT,0x2F); //测量范围,正负16g,13位模式 0X2b D5=1,中断设置为低电平有效
Single_Write_ADXL345(THRESH_ACT,0x01); //活动阀值(xy)1000MG 62.5mg/L
Single_Write_ADXL345(THRESH_INACT,0x03); // 静止阀值(xyz?)(根据实际调整) 时阈
Single_Write_ADXL345(TIME_INACT,0x03); //时阈 5s
// Single_Write_ADXL345(DUR,0xF0); //敲击检测时阈
Single_Write_ADXL345(ACT_INACT_CTL,0xEE); //0110 0110 直(交)流耦合 活动检测使能xy 静止检测使能XY
Single_Write_ADXL345(0x2F,0x10); //中断引脚映射INT_MAP , 活动中断配置到INT2,静止中断到INT1
Single_Write_ADXL345(0x2E,0x18); //中断使能 INT_ENABLLE
Single_Read_ADXL345(INT_SOURCE); //清零中断
Single_Write_ADXL345(POWER_CTL,0x34); //电源设置 休眠使能 0x38 0x08 0x34
Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根据测试传感器的状态写入pdf29页
Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根据测试传感器的状态写入pdf29页
Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根据测试传感器的状态写入pdf29页
中断发生后清除:
Single_Read_ADXL345(ACT_TAP_STATUS);
