按下矩阵键盘中数字键,让点阵显示相应数字,按下字符F键,则把点阵清屏,再按数字键,点阵又显示相应数字。
单片机仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
单片机源程序:
- #include<reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- unsigned char code tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
- uchar code KEY_TABLE[]={ 0xee,0xde,0xbe,0x7e,
- 0xed,0xdd,0xbd,0x7d,
- 0xeb,0xdb,0xbb,0x7b,
- 0xe7,0xd7,0xb7,0x77};//键盘表
- uchar code M[16][8]=
- {0x0,0x3C,0x24,0x24,0x24,0x24,0x24,0x3C,},
- {0x0,0x8,0x8,0x8,0x8,0x8,0x8,0x8,},
- {0x0,0x3C,0x4,0x4,0x3C,0x20,0x20,0x3C,},
- {0x0,0x3C,0x4,0x4,0x3C,0x4,0x4,0x3C,},
- {0x0,0x24,0x24,0x34,0x3C,0x4,0x4,0x4,},
- {0x0,0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,},
- {0x0,0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,},
- {0x0,0x3C,0x4,0x4,0x4,0x4,0x4,0x4,},
- {0x0,0x3C,0x24,0x24,0x3C,0x24,0x24,0x3C,},
- {0x0,0x3C,0x24,0x24,0x3C,0x4,0x4,0x3C,},
- {0x0,0x3C,0x4,0x4,0x3C,0x24,0x24,0x3C,},
- {0x0,0x20,0x20,0x20,0x3C,0x24,0x24,0x3C,},
- {0x0,0x0,0x0,0x3C,0x20,0x20,0x20,0x3C,},
- {0x0,0x4,0x4,0x4,0x3C,0x24,0x24,0x3C,},
- {0x0,0x3C,0x24,0x24,0x3C,0x20,0x20,0x3C,},
- {0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,}
- //延时函数
- void delayms(unsigned int xms)
- unsigned int i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- unsigned char cnta,num;
- main()
- uchar temp,key,i;
- while(1)
- P3=0xf0;//置行为0,列为1,读列值。
- if(P3!=0xf0)//判断有,无键盘按下
- delayms(150);//消振
- if(P3!=0xf0)//如果if的值为真,这时可以确定有键盘按下
- temp=P3;//存储列读入的值
- P3=0x0f;//置列为0,行为1,读行值。
- key=temp|P3;//将行,列值综合,赋给key。
- for(i=0;i<16;i++)
- if(key==KEY_TABLE[i])//读键盘表,确定读入的按键值
- {num=i;break;}
- TMOD=0x01;
- TH0=(65536-4000)/256;
- TL0=(65536-4000)%256;
- TR0=1;
- ET0=1;
- EA=1;
- while(i!=num);
- void t0(void) interrupt 1 using 0
- P1=tab[cnta];
- P0=M[num][cnta];
- cnta++;
- if(cnta==8)
- cnta=0;
- //delayms(1000);
全部资料51hei下载地址:
矩阵键盘显示.zip
(64.05 KB, 下载次数: 52)
