#include<reg52.h>
#include<stdio.h>
#include"LCD1602.h"
#include<Ds1302.h>
#include<AT24c02.h>
#include<ADC0832.h>
sbit k0=P1^0;
sbit k1=P1^1;
sbit k2=P1^2;
sbit k3=P1^3;
bit flg=0;
uchar M_time[]={"Time"};
uchar M_Detect[]={"Detect"};
uchar M_Storage[]={"Storage"};
uchar stor[4];
void initial_lcd1602(void);
void delays(unit n)
while(n--);
void chang_h(void)
int g;
if(k0==0)
{for(g=0;g<20;){delays1(100);g++;}
if(k0==0)
{wr_data[4]=readtimeR[4]+1;
if(wr_data[4]>0x23)wr_data[4]=0x00;
if(k1==0)
if(k1==0)
{wr_data[4]=readtimeR[4]-1;
if(readtimeR[4]>0x00)wr_data[4]=0x00;
DS1302_init();
showdata();
Display_List_Char(1,0,lcd_time);
void chang_m(void)
int g;
if(k0==0)
if(k0==0)
{wr_data[5]=readtimeR[5]+1;
if(wr_data[5]>0x23)wr_data[5]=0x00;
if(k1==0)
if(k1==0)
{wr_data[5]=readtimeR[5]-1;
if(readtimeR[5]==0x00)wr_data[5]=0x00;
DS1302_init();
showdata();
void chang_s(void)
int g;
if(k0==0)
if(k0==0)
{wr_data[6]=readtimeR[6]+1;
if(wr_data[6]>0x23)wr_data[6]=0x00;
if(k1==0)
if(k1==0)
{wr_data[6]=readtimeR[6]-1;
if(readtimeR[6]==0x00)wr_data[6]=0x00;
DS1302_init();
showdata();
uchar i,dd;
unit g;
uchar show[4];
unsigned int data_temp=0;
initial_lcd1602();
DS1302_init();
delays1(100);
Display_List_Char(0,0,LCD_Code2);
for(g=0;g<100;){delays1(100);g++;}
if(k0==0|k1==0|k2==0|k3==0)
write_lcd_command(0x01);
Display_List_Char(0,0,M_time);
Display_List_Char(0,8,M_Detect);
Display_List_Char(1,0,M_Storage);
for(g=0;g<10;){delays1(100);g++;}
if(k0==0)
do
{if(k3==0) flg=1;
showdata();
Display_List_Char(0,0,lcd_dat+3);
if(k2==0)
{do
{Display_One_Char(1,10,'H');
if(k3==0)flg=1;
chang_h();
if(k2==0)
{do
Display_One_Char(1,10,'M');
if(k3==0)flg=1;
chang_m();
if(k2==0)
{do
Display_One_Char(1,10,'S');
if(k3==0)flg=1;
chang_s( );
}while(flg==0);
}while(flg==0);
}while(flg==0);flg=0;
for(g=0;g<500;){delays1(100);g++;}
if(k1==0)
do
if(k3==0)flg=1;
data_temp=ADconv();
stor[0]=data_temp;
xs_int(196*data_temp,1);
if(k2==0)
do
if(k3==0)flg=1;
for(i=0;i<3;)
i2c_writ(0x00+i,0x63+i);
i2c_writ(0x00+i,stor[0]);
i++;
_nop_();
i=0;
for(i=0;i<3;)
dd=i2c_read(0x00+i);
show[i]=dd;
i++;
Display_List_Char(1,0,show);
#include<reg52.h>
#include<stdio.h>
#include<string.h>
#define unit unsigned int
#define LCDPORT P0
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=p2^2;
uchar LCD_Code2[]="Welcome: ";
uchar LCD_Code[]="0123456789ABCDEF-.";
void lcd_delay(uchar delaytime)
while(delaytime)delaytime--;
vodi write_lcd_command(uchar write_command)
lcd_delay(40);
RS=0;
RW=0;
LCDPORT=write_command;
EN=1;
EN=0;
void write_lcd_data(uchar write_data)
lcd_delay(40);
RS=1;
RW=0;
LCDPORT=write_data;
EN=1;
EN=0;
void Display_One_Char(uchar x,uchar y,uchar dat)
switch(x)
case0:
write_lcd_command(0x80+y);
break;
case1:
write_lcd_command(0xc0+y);
break;
write_lcd_data(dat);
void Display_List_Char(uchar x,uchar y,uchar *str)
switch(x)
case0:
break;
case1:
break;
while(*str!='\0')
write_lcd_data(*str);
str++;
void xs_int(unsigned int shuju,bit t)
{unsigned char huancun[6]={0};
unsigned char biaozhi=0,i;
if (shuju<10)biaozhi=1;
else if(shuju<100)biaozhi=2;
else if(shuju<1000)biaozhi=3;
else if(shuju<10000)biaozhi=4;
else if(shuju<65535)biaozhi=5;
switch(biaozhi)
{case5:huancun[5]=shuju/10000;
case4:huancun[3]=shuju%10000/1000;
case3:huancun[2]=shuju%1000/100;
case2:huancun[1]=shuju%100/10;
case1:huancun[0]=shuju%10;
break;
default:break;
for(i=6;i>1;i--)
{if(i==5)Display_One_Char(1,10,'.');
else Display_One_Char(t,15-i,0x30+huancun[i-1]);
Display_One_Char(t,15,'V');
uchar i;
EN=0;
for(i=200;i>0;i--)
lcd_delay(248);
write_lcd_command(0x38);
for(i=4;i>0;i--)
lcd_delay(248);
for(i=4;i>0;i--)
lcd_delay(248);
write_lcd_command(0x0c);
for(i=4;i>0;i--)
lcd_delay(248);
write_lcd_command(0x06);
for(i=4;i>0;i--)
lcd_delay(248);
for(i=4;i>0;i--)
lcd_delay(248);
#include<reg52.h>
#include<intrins.h>
sbit CS=P3^1;
sbit CLK=P3^2;
sbit Do=P3^3;
sbit Di=P3^3;
unsigned char CH=0x02;
unsigned char ADconv(void)
{unsigned char i;
unsigned int data_f=0,data_c=0;
Di=1;
CS=1;
_nop_();
CS=0;
Di=1;
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
_nop_();
CLK=1;
Di=(bit)(0x02&CH);
_nop_();
CLK=0;
_nop_();
_nop_();
CLK=1;
Di=(bit)(0x01&CH);
_nop_();
_nop_();
CLK=0;
Di=1;CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
CLK=1;
for(i=8;i>0;i--)
data_f|=Do;
data_f<<=1;
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
for(i=8;i>0;i--)
data_c<<=1;
data_c|=Do;
_nop_();
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
CLK=0;
_nop_();
_nop_();
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
_nop_();
CLK=1;
_nop_();
CS=1;
_nop_();
_nop_();
return data_f;
#include<reg52.h>
#include<stdio.h>
sbitDS1302_CLK=P3^5;
sbitDS1302_IO=P3^6;
sbitDS1302_RST=P3^7;
uchar lcd_dat[]={"2013-12-30 1"}
uchar lcd_time[]={"15:12:30"}
uchar wr_data[8]={0x09,0x09,0x26,0x06,0x22,0x59,0x50};
uchar readtimeR[8];
void delays(unit n)
while(n--);
void sendbyte(uchar a)
uchar i,temp;
temp=a;
for(i=8;i>0;i--)
if(temp&0x01)
DS1302_IO=1;
DS1302_IO=0;
temp=temp>>1;
DS1302_CLK=1
delays(5);
DS1302_CLK=0
delays(5);
uchar readbyte(void)
uchar i,dat=0;
for(i=8;i>0;i--)
DS1302_IO=1;
dat>>=1;
if(DS1302_IO)
dat|=0x80;
DS1302_CLK=1;
delays(5);
DS1302_CLK=0;
return dat;
void writ_DS1302(uchar address,uchar dat)
DS1302_RST=0;
DELAYS(10);
DS1302_CLK=0;
DELAYS(10);
DS1302_RST=1;
DELAYS(5);
sendbyte(address);
delays(5);
sendbyte(dat);
DS1302_RST=0;
DS1302_CLK=0;
uchar red_DS1302(uchar address)
uchar timer;
DS1302_RST=0;
DELAYS(2);
DS1302_CLK=0;
DELAYS(2);
DS1302_RST=1;
sendbyte(address);
timer=readbyte();
DS1302_RST=0;
DS1302_CLK=0;
return timer;
void DS1302_init()
write_DS1302(0xbe,0x00);
write_DS1302(0x8e,0x00);
write_DS1302(0x8c,wr_data[0]);
write_DS1302(0x88,wr_data[1]);
write_DS1302(0x86,wr_data[2]);
write_DS1302(0x8A,wr_data[3]);
write_DS1302(0x84,wr_data[4]);
write_DS1302(0x82,wr_data[5]);
write_DS1302(0x80,wr_data[6]);
write_DS1302(0x8e,0x80);
void red_time(void)
readtimeR[0]=read_DS1302(0x8d);
readtimeR[1]=read_DS1302(0x89);
readtimeR[2]=read_DS1302(0x87);
readtimeR[3]=read_DS1302(0x8b);
readtimeR[4]=read_DS1302(0x85);
readtimeR[5]=read_DS1302(0x83);
readtimeR[6]=read_DS1302(0x81);
void showdata()
read_time();
lcd_dat[3]=(readtimeR[0]>>4)+0x30;
lcd_dat[4]=(readtimeR[0]&0x0f)+0x30;
lcd_dat[6]=(readtimeR[1]>>4)+0x30;
lcd_dat[7]=(readtimeR[1]&0x0f)+0x30;
lcd_dat[9]=(readtimeR[2]>>4)+0x30;
lcd_dat[10]=(readtimeR[2]&0x0f)+0x30;
lcd_dat[14]=(readtimeR[3]&0x0f)+0x30;
lcd_dat[0]=(readtimeR[4]>>4)+0x30;
lcd_dat[1]=(readtimeR[4]&0x0f)+0x30;
lcd_dat[3]=(readtimeR[5]>>4)+0x30;
lcd_dat[4]=(readtimeR[5]&0x0f)+0x30;
lcd_dat[6]=(readtimeR[6]>>4)+0x30;
lcd_dat[7]=(readtimeR[6]&0x0f)+0x30;
(463.06 KB, 下载次数: 104)
