单片机:STC15W204S-DIP16@6MHz
LCD : nokia5110LCD
时钟芯片:DS3231
论坛上做时钟的方案一大堆,但是用来做电池带动的却还没有。
我想到了一个办法,用STC的单片机掉电模式运行时钟,利用DS3231的1Hz来换醒读秒。
现在能跑起来了,消耗电流在0.5mA+-1mA上下。
不知道这样18650电池能跑多久。
但是程序上还欠调整时钟未做,不知道怎样做光标。
以前1602的话可以直接写光标反色的,这个5110lcd有人会做光标吗?求助
#include "reg51.h"
#include "intrins.h"
#define ulong unsigned long
sfr P4 = 0xC0; //1111,1111 端口4
sfr P5 = 0xC8; //xxxx,1111 端口5
sfr P6 = 0xE8; //0000,0000 端口6
sfr P7 = 0xF8; //0000,0000 端口7
sfr P0M0 = 0x94; //0000,0000 端口0模式寄存器0
sfr P0M1 = 0x93; //0000,0000 端口0模式寄存器1
sfr P1M0 = 0x92; //0000,0000 端口1模式寄存器0
sfr P1M1 = 0x91; //0000,0000 端口1模式寄存器1
sfr P2M0 = 0x96; //0000,0000 端口2模式寄存器0
sfr P2M1 = 0x95; //0000,0000 端口2模式寄存器1
sfr P3M0 = 0xB2; //0000,0000 端口3模式寄存器0
sfr P3M1 = 0xB1; //0000,0000 端口3模式寄存器1
sfr P5M0 = 0xCA; //0000,0000 端口5模式寄存器0
sfr P5M1 = 0xC9; //0000,0000 端口5模式寄存器1
sfr IE2 = 0xaf; //中断使能寄存器2
sfr AUXR = 0x8e; //辅助寄存器
sfr T2H = 0xD6; //定时器2高8位
sfr T2L = 0xD7; //定时器2低8位
sfr CLK_DIV = 0x97; //时钟分频寄存器
sbit LED = P1^2;
sbit P13 = P1^3;// SEL
sbit P14 = P1^4;// UP
sbit P15 = P1^5;// DN
sbit P30 = P3^0;
sbit P31 = P3^1;
sbit IIC_SDA = P5^5; // SDA-DS3231
sbit IIC_SCL = P5^4; // SCL-DS3231
sbit LCD5110_RES = P3^3; //LCD5110 复位,0复位
sbit LCD5110_CE = P3^6; //LCD5110 片选
sbit LCD5110_DC = P3^7; //LCD5110 1写数据,0写指令
sbit LCD5110_SDIN = P1^0; //LCD5110 数据
sbit LCD5110_SCLK = P1^1; //LCD5110 时钟
bit FLAG; //1:上升沿中断 0:下降沿中断
uchar sec, min, hour, day, date, month, year,Dtemp1,Dtemp2;
const unsigned char code F8x8[][8] =
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//0
{0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x00},//一
{0x00,0x24,0x24,0x24,0x24,0x24,0x24,0x00},//二
{0x00,0x49,0x49,0x49,0x49,0x49,0x49,0x00},//三
{0x00,0x7F,0x49,0x47,0x41,0x4F,0x49,0x7F},//四
{0x00,0x41,0x49,0x49,0x7F,0x49,0x79,0x40},//五
{0x00,0x44,0x74,0x05,0x06,0x14,0x64,0x40},//六
{0x00,0x7F,0x49,0x49,0x49,0x49,0x7F,0x00},//日
const unsigned char code F16x32[][64] =
{0x00,0x00,0x00,0x80,0xC0,0xE0,0x60,0x20,0x20,0x60,0xE0,0xC0,0x80,0x00,0x00,0x00,
0xE0,0xFC,0xFF,0xFF,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFC,0xE0,
0x7F,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x7F,
0x00,0x03,0x0F,0x1F,0x3F,0x78,0x60,0x40,0x40,0x60,0x70,0x3F,0x1F,0x0F,0x03,0x00},//0
{0x00,0x00,0x80,0x80,0x80,0x80,0x80,0xC0,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x40,0x40,0x40,0x60,0x7F,0x7F,0x7F,0x7F,0x60,0x40,0x40,0x40,0x00,0x00},//1
{0x00,0x80,0x80,0xC0,0x60,0x20,0x20,0x20,0x20,0x60,0xE0,0xC0,0xC0,0x80,0x00,0x00,
0x3E,0x3F,0x3F,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0xC1,0xFF,0xFF,0xFF,0x3E,0x00,
0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0x70,0x3C,0x1E,0x0F,0x07,0x03,0x00,0x00,0x00,
0x70,0x78,0x7C,0x6F,0x67,0x61,0x60,0x60,0x60,0x60,0x60,0x60,0x78,0x7E,0x1E,0x00},//2
{0x00,0x80,0xC0,0xC0,0x60,0x20,0x20,0x20,0x60,0xE0,0xC0,0xC0,0x80,0x00,0x00,0x00,
0x0F,0x0F,0x0F,0x0E,0x00,0x00,0x00,0x00,0x00,0xC1,0xFF,0xFF,0x7F,0x3E,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x02,0x07,0x07,0x1D,0xFC,0xF8,0xF0,0xC0,0x00,
0x0E,0x1F,0x3F,0x37,0x60,0x40,0x40,0x40,0x60,0x60,0x38,0x3F,0x1F,0x0F,0x07,0x00},//3
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xE0,0xE0,0xE0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xC0,0xE0,0x78,0x1E,0x07,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,
0x60,0xF8,0x9C,0x8F,0x83,0x80,0x80,0x80,0x80,0xFF,0xFF,0xFF,0xFF,0x80,0x80,0x80,
0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x7F,0x7F,0x7F,0x7F,0x40,0x40,0x40},//4
{0x00,0x00,0xE0,0xE0,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x00,
0x00,0xF0,0xFF,0x8F,0x80,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x80,0x80,0x00,0x00,0x00,
0x00,0x87,0x87,0x83,0x01,0x00,0x00,0x00,0x00,0x01,0x07,0xFF,0xFF,0xFE,0xF8,0x00,
0x0F,0x1F,0x3F,0x23,0x60,0x40,0x40,0x40,0x60,0x60,0x78,0x3F,0x1F,0x0F,0x03,0x00},//5
{0x00,0x00,0x00,0x80,0x80,0xC0,0xE0,0x60,0x20,0x20,0x20,0xE0,0xE0,0xC0,0x80,0x00,
0xC0,0xFC,0xFE,0xFF,0x0F,0x01,0x80,0x80,0x80,0x80,0x80,0x83,0x03,0x03,0x03,0x00,
0xFF,0xFF,0xFF,0xFF,0x0E,0x07,0x03,0x01,0x01,0x01,0x03,0x0F,0xFF,0xFF,0xFE,0xF8,
0x00,0x07,0x1F,0x3F,0x3E,0x70,0x60,0x40,0x40,0x40,0x60,0x78,0x3F,0x1F,0x0F,0x03},//6
{0x00,0xE0,0xE0,0xE0,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0xE0,0xE0,0x60,0x00,
0x07,0x07,0x01,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0x3C,0x0F,0x03,0x01,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xE0,0xFC,0xFF,0x0F,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x7F,0x7F,0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//7
{0x00,0x00,0x80,0xC0,0xC0,0xE0,0x60,0x20,0x20,0x20,0x60,0xE0,0xC0,0xC0,0x80,0x00,
0x00,0x3E,0x7F,0xFF,0xFF,0xE0,0xC0,0x80,0x00,0x00,0x00,0xC0,0xFF,0xFF,0x7F,0x1E,
0xC0,0xF0,0xF8,0xFC,0x1F,0x07,0x03,0x07,0x07,0x0F,0x1F,0x7F,0xFD,0xF8,0xF0,0xC0,
0x07,0x0F,0x1F,0x3F,0x38,0x60,0x60,0x40,0x40,0x40,0x60,0x70,0x3F,0x1F,0x0F,0x07},//8
{0x00,0x00,0x80,0xC0,0xE0,0x60,0x20,0x20,0x20,0x20,0x60,0xC0,0xC0,0x80,0x00,0x00,
0xFC,0xFF,0xFF,0xFF,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0xFF,0xFF,0xFE,0xF0,
0x01,0x07,0x0F,0x0F,0x1F,0x1C,0x18,0x18,0x18,0x1C,0x0E,0xC7,0xFF,0xFF,0xFF,0x3F,
0x00,0x1C,0x3C,0x7C,0x7C,0x40,0x40,0x40,0x60,0x70,0x3C,0x1F,0x0F,0x07,0x01,0x00},//9
const unsigned char code F6x8[][6] =
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // sp 0
{ 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 }, // ! 1
{ 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 }, // " 2
{ 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 }, // # 3
{ 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 }, // $ 4
{ 0x00, 0x62, 0x64, 0x08, 0x13, 0x23 }, // % 5
{ 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 }, // & 6
{ 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 }, // ' 7
{ 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 }, // ( 8
{ 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 }, // ) 9
{ 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 }, // * 10
{ 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 }, // + 11
{ 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00 }, // , 12
{ 0x00, 0x08, 0x08, 0x08, 0x08, 0x08 }, // - 13
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 }, // . 14
{ 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 }, // / 15
{ 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E }, // 0 16
{ 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 }, // 1 17
{ 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 }, // 2 18
{ 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 }, // 3 19
{ 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 }, // 4 20
{ 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 }, // 5 21
{ 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 }, // 6 22
{ 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 }, // 7 23
{ 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 }, // 8 24
{ 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E }, // 9 25
{ 0x00, 0x3C, 0x42, 0x42, 0x24, 0x01 }, // C"
void Delayms(uchar ms) //@6.000MHz
unsigned char i, j;
while(ms--){
i = 6;
j = 211;
do
while (--j);
} while (--i);}
void IIC_start(void)
{//IIC总线产生起始信号函数
IIC_SDA=1;//拉高数据线
IIC_SCL=1;//拉高时钟线
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
IIC_SDA=0;//在时钟线为高电平时,拉低数据线,产生起始信号。
IIC_SCL=0;//拉低时钟线
void IIC_stop(void)
{//IIC总线产生停止信号函数
IIC_SDA=0;//拉低数据线
IIC_SCL=1;//拉高时钟线。
IIC_SDA=1;//时钟时线为高电平时,拉高数据线,产生停止信号。
bit IIC_Tack(void)
{//接收应答信号函数
bit ack;//定义一个位变量,来暂存应答状态。
IIC_SDA=1;//释放数据总线,准备接收应答信号。
IIC_SCL=1;//拉高时钟线。
ack=IIC_SDA;//读取应答信号的状态。
IIC_SCL=0;//拉低时钟线。
return ack;//返回应答信号的状态,0表示应答,1表示非应答。
void IIC_write_byte(unsigned char Data)
{//向IIC总线写入一个字节的数据函数
unsigned char i;
for(i=0;i<8;i++)//有8位数据
IIC_SDA=Data&0x80;//写最高位的数据
IIC_SCL=1; //拉高时钟线,将数写入到设备中。
IIC_SCL=0;//拉低时钟线,允许改变数据线的状态
Data=Data<<1;//数据左移一位,把次高位放在最高位,为写入次高位做准备
unsigned char IIC_read_byte()
{//从IIC总线读取一个字节的数据函数
unsigned char i;
unsigned char Data; //定义一个缓冲寄存器。
IIC_SCL=1;//拉高时钟线,为读取下一位数据做准备。
Data=Data<<1;//将缓冲字节的数据左移一位,准备读取数据。
if(IIC_SDA)//如果数据线为高平电平。
Data=Data|0x01;//则给缓冲字节的最低位写1。
IIC_SCL=0;//拉低时钟线,为读取下一位数据做准备。
return Data;//返回读取的一个字节数据。
void IIC_single_byte_write(unsigned char Waddr,unsigned char Data)
{//向任意地址写入一个字节数据函数
IIC_start();//产生起始信号
IIC_write_byte(0xd0);//写入设备地址(写)
IIC_Tack();//等待设备的应答
IIC_write_byte(Waddr);//写入要操作的单元地址。
IIC_Tack();//等待设备的应答。
IIC_write_byte(Data);//写入数据。
IIC_stop();//产生停止符号。
unsigned char IIC_single_byte_read(unsigned char Waddr)
{//从任意地址读取一个字节数据函数
unsigned char Data;//定义一个缓冲寄存器。
IIC_write_byte(0xd1);//写入设备地址(写)
Data=IIC_read_byte();//写入数据。
//-------------------返回读取的数据--------------------
void DS3231_Init(void)
IIC_single_byte_write(0x0E,0x60);
IIC_single_byte_write(0x0F,0x80);
/*IIC_single_byte_write(0x01,B_BCD(28));//28
IIC_single_byte_write(0x02,B_BCD(22));//22
IIC_single_byte_write(0x03,B_BCD(7));//日
IIC_single_byte_write(0x04,B_BCD(19));//19
IIC_single_byte_write(0x05,B_BCD(3));//03
IIC_single_byte_write(0x06,B_BCD(17));//17 */
uchar BCD2HEX(uchar val) //BCD转换为Byte
return ((val>>4)*10)+(val&0x0f);
uchar B_BCD(uchar val)//Byte码转换为BCD码
return (((val%100)/10)<<4)|(val%10);
void Readtime()
uchar temp;
temp=IIC_single_byte_read(0x00);//秒
sec=(int)BCD2HEX(temp);
temp=IIC_single_byte_read(0x01);//分
min=BCD2HEX(temp);
temp=IIC_single_byte_read(0x02); //时
hour=BCD2HEX(temp);
day=IIC_single_byte_read(0x03);//星期
temp=IIC_single_byte_read(0x04); //日
date=BCD2HEX(temp);
temp=IIC_single_byte_read(0x05); //月
month=BCD2HEX(temp);
temp=IIC_single_byte_read(0x06); //年
year=BCD2HEX(temp);
//void Ttemp_read()
//IIC_single_byte_write(0x0E,0x20);
// Dtemp1=IIC_single_byte_read(0x11);//温度高位
//Dtemp2=IIC_single_byte_read(0x12);//温度低位+-0.25度变化
//Dtemp2=(Dtemp2>>6)*25;
void LCD_write_byte(unsigned char dt, unsigned char command)//LCD5110写入数据
unsigned char i;
LCD5110_CE=0; // 关闭LCD
LCD5110_DC=command; // 0是写命令,1是写数据
for(i=0;i<8;i++)
if(dt&0x80)
LCD5110_SDIN=1;
LCD5110_SDIN=0;
dt=dt<<1; //dt为暂存数据
LCD5110_SCLK=0;
LCD5110_SCLK=1;
LCD5110_DC=1;
LCD5110_CE=1;
LCD5110_SDIN=1;
void LCD_write_byteone()//LCD5110写入数据
LCD5110_DC=1; // 0是写命令,1是写数据
LCD5110_SDIN=1;
LCD5110_SCLK=0;
LCD5110_SCLK=1;
LCD5110_DC=1;
LCD5110_CE=1;
LCD5110_SDIN=1;
void LCD_clear(void) //5110LCD清屏
unsigned int i;
LCD_write_byte(0x0c, 0);
LCD_write_byte(0x80, 0);
for (i=0; i<504; i++)
LCD_write_byte(0, 1);
void LCD_set_XY(unsigned char X, unsigned char Y) //x 左右共0~83列可移,Y由上至下共0~5行可移
LCD_write_byte(0x40 | Y, 0); // column Y+=64
LCD_write_byte(0x80 | X, 0); // row X+=128
void LCD_init(void) //5110LCD初始化LCD_init
LCD5110_RES=0; // 产生一个让LCD复位的低电平脉冲
Delayms(10);
LCD5110_RES=1;
LCD5110_CE = 0; // 关闭LCD
Delayms(10);
LCD5110_CE = 1;// 使能LCD
Delayms(10);
LCD_write_byte(0x21, 0); // 使用扩展命令设置LCD模式
LCD_write_byte(0xBC, 0); // 设置偏置电压//不同的屏须要微调此参数B9~C9
LCD_write_byte(0x06, 0); // 温度校正
LCD_write_byte(0x13, 0); // 1:48
LCD_write_byte(0x20, 0); // 使用基本命令
LCD_clear(); // 清屏
LCD_write_byte(0x0C, 0); // 设定显示模式,正常显示
void LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char ch)
unsigned char i;
LCD_set_XY(x,y);
for(i=0;i<6;i++){ LCD_write_byte(F6x8[ch],1); }
void LCD_P16x32Str(unsigned char x,unsigned char y,unsigned char ch)
unsigned char i;
LCD_set_XY(x,y);
for(i=0;i<16;i++){ LCD_write_byte( F16x32[ch],1); }
LCD_set_XY(x,y+1);
for(i=16;i<32;i++){ LCD_write_byte( F16x32[ch],1); }
LCD_set_XY(x,y+2);
for(i=32;i<48;i++){ LCD_write_byte( F16x32[ch],1); }
LCD_set_XY(x,y+3);
for(i=48;i<64;i++){ LCD_write_byte( F16x32[ch],1); }
void LCD_P8x8Str(unsigned char x,unsigned char y,unsigned char ch)
unsigned char i;
LCD_set_XY(x,y);
for(i=0;i<8;i++){ LCD_write_byte(F8x8[ch],1); }
bit seet=0;
uchar a1,a2,a3;
uchar key1,tt,tt2,tt3,
P1M0 =P1M1 = 0x00;
P3M0 =P3M1 = 0x00;
P5M0 =P5M1 = 0x00;
DS3231_Init();
LCD_init();
IT0 = 1; //设置INT0的中断类型为下降沿唤醒
EX0 = 1; //使能INT0中断
EA = 1;
Readtime();
LCD_P6x8Str(6,0,16+2); //2
LCD_P6x8Str(12,0,16+0); //0
LCD_P6x8Str(18,0,16+year/10);//1
LCD_P6x8Str(24,0,16+year%10);//7
LCD_P6x8Str(30,0,13); //-
LCD_P6x8Str(36,0,16+month/10);//0
LCD_P6x8Str(42,0,16+month%10);//3
LCD_P6x8Str(48,0,13); //-
LCD_P6x8Str(54,0,16+date/10); //1
LCD_P6x8Str(60,0,16+date%10); //9
LCD_P8x8Str(72,0,day);
LCD_P16x32Str(2,1,hour/10);//时十位
LCD_P16x32Str(20,1,hour%10);//时个位
LCD_set_XY(40,2),LCD_write_byte(0x20,1);
LCD_set_XY(41,2),LCD_write_byte(0x70,1);
LCD_set_XY(42,2),LCD_write_byte(0x70,1);
LCD_set_XY(43,2),LCD_write_byte(0x20,1);
LCD_set_XY(40,4),LCD_write_byte(0x02,1);
LCD_set_XY(41,4),LCD_write_byte(0x07,1);
LCD_set_XY(42,4),LCD_write_byte(0x07,1);
LCD_set_XY(43,4),LCD_write_byte(0x02,1);
LCD_P16x32Str(48,1,min/10);//分十位
LCD_P16x32Str(66,1,min%10);//分个位
if(!P13){ while(!P13);
a1=a2=a3=0;
LED = 0;
goto MEN;
time: Readtime();
LCD_set_XY(sec,5);
LCD_write_byte(0x00,1);
LCD_write_byte(0x40,1);
if(sec==00)//一分钟刷新一次分显示
//Ttemp_read();
//LCD_P6x8Str(48,5,16+Dtemp1/10);
//LCD_P6x8Str(54,5,16+Dtemp1%10);
//LCD_P6x8Str(60,5,14); //.
//LCD_P6x8Str(66,5,16+Dtemp2/10);
//LCD_P6x8Str(72,5,16+Dtemp2%10);
//LCD_P6x8Str(78,5,26);
if(min==0)//一小时刷新一次时显示
if(hour==0)//24小时刷新一次年、月、日显示
PCON |= 0x02;
MEN :
if(!P13)//SEL
Delayms(10);
if(!P13)
key1++;
a1=a2=a3=0;
if(key1==7){key1=0;}
while(!P13);
switch(key1)
case 1: {LCD_set_XY(48,5); //分指针
for(tt=0;tt<33;tt++){LCD_write_byteone();}
a1++;
if(a1>250)
a1=0;
a2++;
if(a2>250)
Readtime();
LCD_set_XY(sec,5);
LCD_P8x8Str(72,0,day); //星期几
LCD_set_XY(40,2),LCD_write_byte(0x20,1);//
LCD_set_XY(41,2),LCD_write_byte(0x70,1);//
LCD_set_XY(42,2),LCD_write_byte(0x70,1);//
LCD_set_XY(43,2),LCD_write_byte(0x20,1);//
LCD_set_XY(40,4),LCD_write_byte(0x02,1);//
LCD_set_XY(41,4),LCD_write_byte(0x07,1);//
LCD_set_XY(42,4),LCD_write_byte(0x07,1);//
LCD_set_XY(43,4),LCD_write_byte(0x02,1);//
a2=0;
a3++;
if(a3>250)
a3=0;
LED =1;
goto time;
void exint0() interrupt 0 //INT0中断入口
FLAG = INT0; //保存INT0口的状态, INT0=0(下降沿); INT0=1(上升沿)
