查看: 2822|回复: 5
求高手帮忙改一段代码
ID:217754 发表于 2017-10-3 03:05 | 显示全部楼层 |阅读模式
10黑币
帮忙改成按一下按键流水灯开始 ,再按一下中段并重新开始。不按不亮 每按一下只走一遍。不循环。谢谢!
#include<reg51.h>
#include<intrins.h>
sbit button = P3^0;
uchar press = 1;
uchar luishui = 0xfe;
void Delay(uchar z)
    uchar x, y;
    for(x = z; x > 0; x--)  for(y = 255; y > 0; y--);
    IT0 = 1;
    EX0 = 1;
    EA = 1;
    while(1) {
      if(press == 1)   P1 = 0xff;
      if(press == 0)  {
        P1 = luishui;
        luishui = _crol_(luishui, 1);
        Delay(200);
X0_INT()   interrupt 0
    press += 1; if(press == 2)  press = 0;
    Delay(10);
    while(button == 0);
最佳答案
查看完整内容
#include #include #define uchar unsigned char sbit button = P3^2;//外部中断P3^2和P3^3 int b=1; bit press = 1; uchar luishui = 0xfe; void Delay(uchar z) { uchar x, y; for(x = z; x > 0; x--) for(y = 255; y > 0; y--); } void main() { int i=0; IT0 = 1; EX0 = 1; EA = 1; while(press) P1=0xff; while(!press) { b=1; luishui=0xfe; for(i=0;i
ID:232524 发表于 2017-10-3 03:05 | 显示全部楼层
#include<reg51.h>
#include<intrins.h>
int b=1;
bit press = 1;
void Delay(uchar z)
    uchar x, y;
    int i=0;
    IT0 = 1;
    EX0 = 1;
    EA = 1;
        while(!press)
          b=1;
          luishui=0xfe;
          for(i=0;i<8;i++)
           if(!b)break;
           P1=luishui;
           Delay(200);
           luishui=_crol_(luishui,1);
         if(i==8)press=1;
void X0_INT()   interrupt 0
  b=0;
  press=0;
你看看是不是这样
ID:213173 发表于 2017-10-3 11:37 | 显示全部楼层
外部中断P3.2~P3.3
ID:213173 发表于 2017-10-3 13:42 | 显示全部楼层
#include<reg51.h>
#include<intrins.h>
sbit button = P3^2;
uchar press = 1;
void Delay(uchar z)
        uchar x, y;
        P3=0x0f;
        IT0 = 1;
        EX0 = 1;
        EA = 1;
                if(press == 1)
                        P1 = 0xff;
                if(press == 0)
                        P1 = luishui;
                        Delay(250);
                        if(P1 == 0x7f)
                                press = 1;
        press = 0;
//        if(press == 2)
//        press = 0;
//        Delay(10);
//        while(button == 0);
ID:149988 发表于 2017-10-5 07:07 | 显示全部楼层
RE: 求高手帮忙改一段代码
#include<reg51.h>             //51系列单片机头文件
#include<intrins.h>           //左右循环头文件
#define uint unsigned int     //宏定义
#define uchar unsigned char   //宏定义
void delayms(uint);           //声明子函数
uchar n;                      //定义一个变量,用来控制循环次数
uchar aa;                     //定义一个变量,用来给P1口赋值
void main()                   //主函数
        IT0=1;       //下降沿触发
        EX0=1;       //INT0中断允许
        IT1=1;       //下降沿触发
        EX1=1;       //INT1中断允许
        EA=1;        //总中断允许        //P1口赋初值11111110
  while(1){}                   //大循环
void delayms(uint X)       //延时子函数
        uint i,j;                //定义i,j
        for(i=X;i>0;i--)       //i=xms即延时约xms毫秒
        for(j=110;j>0;j--);
void  INT0_1(void) interrupt 0  using 1
        EX0=0;   //进入外部INT0中断关闭,防止误操作
        aa=0x01;
        P0=aa;                //先点亮一个发光管
        aa=_crol_(aa,1);      //将aa循环左移1位后再赋给aa
        delayms(500);         //调用延时500ms
        EX0=1;   //中断函数结束,外部INT0中断打开,中断生效
ID:217754 发表于 2017-10-5 22:43 | 显示全部楼层
wulin 发表于 2017-10-3 13:42
#include
#include
谢谢老师。明白了
