- /* --- STC MCU International Limited -------------------------------*/
- /* --- STC 1T Series MCU RC Demo -----------------------------------*/
- /* --- Mobile: (86)13922805190 -------------------------------------*/
- /* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
- /* --- Tel: 86-0513-55012928,55012929,55012966 ---------------------*/
- /* --- Web: www.GXWMCU.com -----------------------------------------*/
- /* --- QQ: 800003751 ----------------------------------------------*/
- /* If you want to use the program or the program referenced in the */
- /* article, please specify in which data and procedures from STC */
- #ifndef _STC15Fxxxx_H
- #define _STC15Fxxxx_H
- #include <intrins.h>
- /* BYTE Registers */
- sfr P0 = 0x80;
- sfr SP = 0x81;
- sfr DPL = 0x82;
- sfr DPH = 0x83;
- sfr S4CON = 0x84;
- sfr S4BUF = 0x85;
- sfr PCON = 0x87;
- sfr TCON = 0x88;
- sfr TMOD = 0x89;
- sfr TL0 = 0x8A;
- sfr TL1 = 0x8B;
- sfr TH0 = 0x8C;
- sfr TH1 = 0x8D;
- sfr AUXR = 0x8E;
- sfr WAKE_CLKO = 0x8F;
- sfr INT_CLKO = 0x8F;
- sfr AUXR2 = 0x8F;
- sfr RL_TL0 = 0x8A;
- sfr RL_TL1 = 0x8B;
- sfr RL_TH0 = 0x8C;
- sfr RL_TH1 = 0x8D;
- sfr P1 = 0x90;
- sfr P1M1 = 0x91; //P1M1.n,P1M0.n =00--->Standard, 01--->push-pull 实际上1T的都一样
- sfr P1M0 = 0x92; // =10--->pure input, 11--->open drain
- sfr P0M1 = 0x93; //P0M1.n,P0M0.n =00--->Standard, 01--->push-pull
- sfr P0M0 = 0x94; // =10--->pure input, 11--->open drain
- sfr P2M1 = 0x95; //P2M1.n,P2M0.n =00--->Standard, 01--->push-pull
- sfr P2M0 = 0x96; // =10--->pure input, 11--->open drain
- sfr CLK_DIV = 0x97;
- sfr PCON2 = 0x97;
- sfr SCON = 0x98;
- sfr SBUF = 0x99;
- sfr S2CON = 0x9A; //
- sfr S2BUF = 0x9B; //
- sfr P1ASF = 0x9D; //只写,模拟输入(AD或LVD)选择
- sfr P2 = 0xA0;
- sfr BUS_SPEED = 0xA1;
- sfr AUXR1 = 0xA2;
- sfr P_SW1 = 0xA2;
- sfr IE = 0xA8;
- sfr SADDR = 0xA9;
- sfr WKTCL = 0xAA; //唤醒定时器低字节
- sfr WKTCH = 0xAB; //唤醒定时器高字节
- sfr S3CON = 0xAC;
- sfr S3BUF = 0xAD;
- sfr IE2 = 0xAF; //STC12C5A60S2系列
- sfr P3 = 0xB0;
- sfr P3M1 = 0xB1; //P3M1.n,P3M0.n =00--->Standard, 01--->push-pull
- sfr P3M0 = 0xB2; // =10--->pure input, 11--->open drain
- sfr P4M1 = 0xB3; //P4M1.n,P4M0.n =00--->Standard, 01--->push-pull
- sfr P4M0 = 0xB4; // =10--->pure input, 11--->open drain
- sfr IP2 = 0xB5; //STC12C5A60S2系列
- sfr IPH2 = 0xB6; //STC12C5A60S2系列
- sfr IPH = 0xB7;
- sfr IP = 0xB8;
- sfr SADEN = 0xB9;
- sfr P_SW2 = 0xBA;
- sfr ADC_CONTR = 0xBC; //带AD系列
- sfr ADC_RES = 0xBD; //带AD系列
- sfr ADC_RESL = 0xBE; //带AD系列
- sfr P4 = 0xC0;
- sfr WDT_CONTR = 0xC1;
- sfr IAP_DATA = 0xC2;
- sfr IAP_ADDRH = 0xC3;
- sfr IAP_ADDRL = 0xC4;
- sfr IAP_CMD = 0xC5;
- sfr IAP_TRIG = 0xC6;
- sfr IAP_CONTR = 0xC7;
- sfr ISP_DATA = 0xC2;
- sfr ISP_ADDRH = 0xC3;
- sfr ISP_ADDRL = 0xC4;
- sfr ISP_CMD = 0xC5;
- sfr ISP_TRIG = 0xC6;
- sfr ISP_CONTR = 0xC7;
- sfr P5 = 0xC8; //
- sfr P5M1 = 0xC9; // P5M1.n,P5M0.n =00--->Standard, 01--->push-pull
- sfr P5M0 = 0xCA; // =10--->pure input, 11--->open drain
- sfr P6M1 = 0xCB; // P5M1.n,P5M0.n =00--->Standard, 01--->push-pull
- sfr P6M0 = 0xCC; // =10--->pure input, 11--->open drain
- sfr SPSTAT = 0xCD; //
- sfr SPCTL = 0xCE; //
- sfr SPDAT = 0xCF; //
- sfr PSW = 0xD0;
- sfr T4T3M = 0xD1;
- sfr T4H = 0xD2;
- sfr T4L = 0xD3;
- sfr T3H = 0xD4;
- sfr T3L = 0xD5;
- sfr T2H = 0xD6;
- sfr T2L = 0xD7;
- sfr TH4 = 0xD2;
- sfr TL4 = 0xD3;
- sfr TH3 = 0xD4;
- sfr TL3 = 0xD5;
- sfr TH2 = 0xD6;
- sfr TL2 = 0xD7;
- sfr RL_T4H = 0xD2;
- sfr RL_T4L = 0xD3;
- sfr RL_T3H = 0xD4;
- sfr RL_T3L = 0xD5;
- sfr RL_T2H = 0xD6;
- sfr RL_T2L = 0xD7;
- sfr CCON = 0xD8; //
- sfr CMOD = 0xD9; //
- sfr CCAPM0 = 0xDA; //PCA模块0的工作模式寄存器。
- sfr CCAPM1 = 0xDB; //PCA模块1的工作模式寄存器。
- sfr CCAPM2 = 0xDC; //PCA模块2的工作模式寄存器。
- sfr ACC = 0xE0;
- sfr P7M1 = 0xE1;
- sfr P7M0 = 0xE2;
- sfr CMPCR1 = 0xE6;
- sfr CMPCR2 = 0xE7;
- sfr P6 = 0xE8;
- sfr CL = 0xE9; //
- sfr CCAP0L = 0xEA; //PCA模块0的捕捉/比较寄存器低8位。
- sfr CCAP1L = 0xEB; //PCA模块1的捕捉/比较寄存器低8位。
- sfr CCAP2L = 0xEC; //PCA模块2的捕捉/比较寄存器低8位。
- sfr B = 0xF0;
- sfr PWMCFG = 0xF1; //PWM配置寄存器
- sfr PCA_PWM0 = 0xF2; //PCA模块0 PWM寄存器。
- sfr PCA_PWM1 = 0xF3; //PCA模块1 PWM寄存器。
- sfr PCA_PWM2 = 0xF4; //PCA模块2 PWM寄存器。
- sfr PWMCR = 0xF5; //PWM控制寄存器
- sfr PWMIF = 0xF6; //PWM中断标志寄存器
- sfr PWMFDCR = 0xF7; //PWM外部异常控制寄存器
- sfr P7 = 0xF8;
- sfr CH = 0xF9;
- sfr CCAP0H = 0xFA; //PCA模块0的捕捉/比较寄存器高8位。
- sfr CCAP1H = 0xFB; //PCA模块1的捕捉/比较寄存器高8位。
- sfr CCAP2H = 0xFC; //PCA模块2的捕捉/比较寄存器高8位。
- #define PWMCH 0xFFF0 /* PWM计数器高字节 */
- #define PWMCL 0xFFF1 /* PWM计数器低字节 */
- #define PWMCKS 0xFFF2 /* PWM时钟选择 */
- #define PWM2T1H 0xFF00 /* PWM2T1计数高字节 */
- #define PWM2T1L 0xFF01 /* PWM2T1计数低字节 */
- #define PWM2T2H 0xFF02 /* PWM2T2计数高字节 */
- #define PWM2T2L 0xFF03 /* PWM2T2计数低字节 */
- #define PWM2CR 0xFF04 /* PWM2控制 */
- #define PWM3T1H 0xFF10 /* PWM3T1计数高字节 */
- #define PWM3T1L 0xFF11 /* PWM3T1计数低字节 */
- #define PWM3T2H 0xFF12 /* PWM3T2计数高字节 */
- #define PWM3T2L 0xFF13 /* PWM3T2计数低字节 */
- #define PWM3CR 0xFF14 /* PWM3控制 */
- #define PWM4T1H 0xFF20 /* PWM4T1计数高字节 */
- #define PWM4T1L 0xFF21 /* PWM4T1计数低字节 */
- #define PWM4T2H 0xFF22 /* PWM4T2计数高字节 */
- #define PWM4T2L 0xFF23 /* PWM4T2计数低字节 */
- #define PWM4CR 0xFF24 /* PWM4控制 */
- #define PWM5T1H 0xFF30 /* PWM5T1计数高字节 */
- #define PWM5T1L 0xFF31 /* PWM5T1计数低字节 */
- #define PWM5T2H 0xFF32 /* PWM5T2计数高字节 */
- #define PWM5T2L 0xFF33 /* PWM5T2计数低字节 */
- #define PWM5CR 0xFF34 /* PWM5控制 */
- #define PWM6T1H 0xFF40 /* PWM6T1计数高字节 */
- #define PWM6T1L 0xFF41 /* PWM6T1计数低字节 */
- #define PWM6T2H 0xFF42 /* PWM6T2计数高字节 */
- #define PWM6T2L 0xFF43 /* PWM6T2计数低字节 */
- #define PWM6CR 0xFF44 /* PWM6控制 */
- #define PWM7T1H 0xFF50 /* PWM7T1计数高字节 */
- #define PWM7T1L 0xFF51 /* PWM7T1计数低字节 */
- #define PWM7T2H 0xFF52 /* PWM7T2计数高字节 */
- #define PWM7T2L 0xFF53 /* PWM7T2计数低字节 */
- #define PWM7CR 0xFF54 /* PWM7控制 */
- #define PWM2_ID 0
- #define PWM3_ID 1
- #define PWM4_ID 2
- #define PWM5_ID 3
- #define PWM6_ID 4
- #define PWM7_ID 5
- #define PwmClk_1T 0
- #define PwmClk_2T 1
- #define PwmClk_3T 2
- #define PwmClk_4T 3
- #define PwmClk_5T 4
- #define PwmClk_6T 5
- #define PwmClk_7T 6
- #define PwmClk_8T 7
- #define PwmClk_9T 8
- #define PwmClk_10T 9
- #define PwmClk_11T 10
- #define PwmClk_12T 11
- #define PwmClk_13T 12
- #define PwmClk_14T 13
- #define PwmClk_15T 14
- #define PwmClk_16T 15
- #define PwmClk_T2 16
- // 7 6 5 4 3 2 1 0 Reset Value
- //PWMnCR: PWMn控制 - - - - PWMn_PS EPWMnI ECnT2SI ECnT1SI 0000,0000
- #define PWMn_PS_1 0x00 /* PWM管脚选择位 */
- #define PWMn_PS_2 0x08 /* PWM管脚选择位 */
- #define EPWMnI_Enable 0x04 /* 允许PWM中断 */
- #define ECnT2SI_Enable 0x02 /* 允许T2翻转时中断 */
- #define ECnT1SI_Enable 0x01 /* 允许T1翻转时中断 */
- #define PWM2_P37 0x00
- #define PWM2_P27 0x08
- #define PWM3_P21 0x00
- #define PWM3_P45 0x08
- #define PWM4_P22 0x00
- #define PWM4_P44 0x08
- #define PWM5_P23 0x00
- #define PWM5_P42 0x08
- #define PWM6_P16 0x00
- #define PWM6_P07 0x08
- #define PWM7_P17 0x00
- #define PWM7_P06 0x08
- #define EAXSFR() P_SW2 |= 0x80 /* MOVX A,@DPTR/MOVX @DPTR,A指令的操作对象为扩展SFR(XSFR) */
- #define EAXRAM() P_SW2 &= ~0x80 /* MOVX A,@DPTR/MOVX @DPTR,A指令的操作对象为扩展RAM(XRAM) */
- #define C2INI 0x01 /* PWM输出端口的初始电平为高电平 */
- #define C3INI 0x02
- #define C4INI 0x04
- #define C5INI 0x08
- #define C6INI 0x10
- #define C7INI 0x20
- #define CBTADC 0x40 /* PWM计数器归零时自动触发ADC转换。(注:前提条件是PWM和ADC必须被使能,即ENPWM==1,且ADCON==1) */
- #define ENPWM 0x80 /* 使能PWM波形发生器,PWM计数器开始计数 */
- #define ECBI 0x40 /* 使能PWM计数器归零中断 */
- #define ENC7O 0x20 /* 相应PWM通道的端口设置为PWM输出口,受PWM波形发生器控制 */
- #define ENC6O 0x10
- #define ENC5O 0x08
- #define ENC4O 0x04
- #define ENC3O 0x02
- #define ENC2O 0x01
- #define PWM_Enable() PWMCR |= 0x80 /* 使能PWM波形发生器,PWM计数器开始计数 */
- #define PWM_Disable() PWMCR &= ~0x80 /* 关闭PWM波形发生器 */
- #define CBIF 0x40 /* PWM计数器归零中断标志位 */
- #define C7IF 0x20
- #define C6IF 0x10 /* 第n通道的PWM中断标志位 */
- #define C5IF 0x08
- #define C4IF 0x04
- #define C3IF 0x02
- #define C2IF 0x01
- #define ENFD 0x20 /* 使能PWM的外部异常检测功 */
- #define FLTFLIO 0x10 /* 发生WM外部异常时,PWM的输出口立即被设置为高阻输入模式。(注:只有ENCnO==1所对应的端口才会被强制悬空) */
- #define EFDI 0x08 /* 使能PWM异常检测中断 */
- #define FDCMP 0x04 /* 当比较器的输出由低变高时,触发PWM异常 */
- #define FDIO 0x02 /* 当P2.4的电平由低变高时,触发PWM异常 */
- #define FDIF 0x01 /* 当发生PWM异常(比较器的输出由低变高或者P2.4的电平由低变高)时,硬件自动将此位置1, 并置位中断标志.需要软件清零 */
- #define PWM_FaultDetect_Enable() PWMFDCR |= 0x20 /* 使能PWM的外部异常检测功能 */
- #define PWM_FaultDetect_Disable() PWMFDCR &= ~0x20 /* 禁止PWM的外部异常检测功能 */
- /* BIT Registers */
- /* PSW */
- sbit CY = PSW^7;
- sbit AC = PSW^6;
- sbit F0 = PSW^5;
- sbit RS1 = PSW^4;
- sbit RS0 = PSW^3;
- sbit OV = PSW^2;
- sbit F1 = PSW^1;
- sbit P = PSW^0;
- /* TCON */
- sbit TF1 = TCON^7; //定时器1溢出中断标志位
- sbit TR1 = TCON^6; //定时器1运行控制位
- sbit TF0 = TCON^5; //定时器0溢出中断标志位
- sbit TR0 = TCON^4; //定时器0运行控制位
- sbit IE1 = TCON^3; //外中断1标志位
- sbit IT1 = TCON^2; //外中断1信号方式控制位,1:下降沿中断,0:上升下降均中断。
- sbit IE0 = TCON^1; //外中断0标志位
- sbit IT0 = TCON^0; //外中断0信号方式控制位,1:下降沿中断,0:上升下降均中断。
- /* P0 */
- sbit P00 = P0^0;
- sbit P01 = P0^1;
- sbit P02 = P0^2;
- sbit P03 = P0^3;
- sbit P04 = P0^4;
- sbit P05 = P0^5;
- sbit P06 = P0^6;
- sbit P07 = P0^7;
- /* P1 */
- sbit P10 = P1^0;
- sbit P11 = P1^1;
- sbit P12 = P1^2;
- sbit P13 = P1^3;
- sbit P14 = P1^4;
- sbit P15 = P1^5;
- sbit P16 = P1^6;
- sbit P17 = P1^7;
- sbit RXD2 = P1^0;
- sbit TXD2 = P1^1;
- sbit CCP1 = P1^0;
- sbit CCP0 = P1^1;
- sbit SPI_SS = P1^2;
- sbit SPI_MOSI = P1^3;
- sbit SPI_MISO = P1^4;
- sbit SPI_SCLK = P1^5;
- sbit SPI_SS_2 = P2^4;
- sbit SPI_MOSI_2 = P2^3;
- sbit SPI_MISO_2 = P2^2;
- sbit SPI_SCLK_2 = P2^1;
- sbit SPI_SS_3 = P5^4;
- sbit SPI_MOSI_3 = P4^0;
- sbit SPI_MISO_3 = P4^1;
- sbit SPI_SCLK_3 = P4^3;
- /* P2 */
- sbit P20 = P2^0;
- sbit P21 = P2^1;
- sbit P22 = P2^2;
- sbit P23 = P2^3;
- sbit P24 = P2^4;
- sbit P25 = P2^5;
- sbit P26 = P2^6;
- sbit P27 = P2^7;
- /* P3 */
- sbit P30 = P3^0;
- sbit P31 = P3^1;
- sbit P32 = P3^2;
- sbit P33 = P3^3;
- sbit P34 = P3^4;
- sbit P35 = P3^5;
- sbit P36 = P3^6;
- sbit P37 = P3^7;
- sbit RXD = P3^0;
- sbit TXD = P3^1;
- sbit INT0 = P3^2;
- sbit INT1 = P3^3;
- sbit T0 = P3^4;
- sbit T1 = P3^5;
- sbit WR = P3^6;
- sbit RD = P3^7;
- sbit CCP2 = P3^7;
- sbit CLKOUT0 = P3^5;
- sbit CLKOUT1 = P3^4;
- /* P4 */
- sbit P40 = P4^0;
- sbit P41 = P4^1;
- sbit P42 = P4^2;
- sbit P43 = P4^3;
- sbit P44 = P4^4;
- sbit P45 = P4^5;
- sbit P46 = P4^6;
- sbit P47 = P4^7;
- /* P5 */
- sbit P50 = P5^0;
- sbit P51 = P5^1;
- sbit P52 = P5^2;
- sbit P53 = P5^3;
- sbit P54 = P5^4;
- sbit P55 = P5^5;
- sbit P56 = P5^6;
- sbit P57 = P5^7;
- /* P6 */
- sbit P60 = P6^0;
- sbit P61 = P6^1;
- sbit P62 = P6^2;
- sbit P63 = P6^3;
- sbit P64 = P6^4;
- sbit P65 = P6^5;
- sbit P66 = P6^6;
- sbit P67 = P6^7;
- /* P7 */
- sbit P70 = P7^0;
- sbit P71 = P7^1;
- sbit P72 = P7^2;
- sbit P73 = P7^3;
- sbit P74 = P7^4;
- sbit P75 = P7^5;
- sbit P76 = P7^6;
- sbit P77 = P7^7;
- /* SCON */
- sbit SM0 = SCON^7; //SM0/FE SM0 SM1 = 00 ~ 11: 方式0~3
- sbit SM1 = SCON^6; //
- sbit SM2 = SCON^5; //多机通讯
- sbit REN = SCON^4; //接收允许
- sbit TB8 = SCON^3; //发送数据第8位
- sbit RB8 = SCON^2; //接收数据第8位
- sbit TI = SCON^1; //发送中断标志位
- sbit RI = SCON^0; //接收中断标志位
- /* IE */
- sbit EA = IE^7; //中断允许总控制位
- sbit ELVD = IE^6; //低压监测中断允许位
- sbit EADC = IE^5; //ADC 中断 允许位
- sbit ES = IE^4; //串行中断 允许控制位
- sbit ET1 = IE^3; //定时中断1允许控制位
- sbit EX1 = IE^2; //外部中断1允许控制位
- sbit ET0 = IE^1; //定时中断0允许控制位
- sbit EX0 = IE^0; //外部中断0允许控制位
- sbit ACC0 = ACC^0;
- sbit ACC1 = ACC^1;
- sbit ACC2 = ACC^2;
- sbit ACC3 = ACC^3;
- sbit ACC4 = ACC^4;
- sbit ACC5 = ACC^5;
- sbit ACC6 = ACC^6;
- sbit ACC7 = ACC^7;
- sbit B0 = B^0;
- sbit B1 = B^1;
- sbit B2 = B^2;
- sbit B3 = B^3;
- sbit B4 = B^4;
- sbit B5 = B^5;
- sbit B6 = B^6;
- sbit B7 = B^7;
- //sfr IE2 = 0xAF; - - - - - - ESPI ES2 0000,0000B //Auxiliary Interrupt
- #define SPI_INT_ENABLE() IE2 |= 2 /* 允许SPI中断 */
- #define SPI_INT_DISABLE() IE2 &= ~2 /* 允许SPI中断 */
- #define UART2_INT_ENABLE() IE2 |= 1 /* 允许串口2中断 */
- #define UART2_INT_DISABLE() IE2 &= ~1 /* 允许串口2中断 */
- //sfr IP = 0xB8; //中断优先级低位 PPCA PLVD PADC PS PT1 PX1 PT0 PX0 0000,0000
- sbit PPCA = IP^7; //PCA 模块中断优先级
- sbit PLVD = IP^6; //低压监测中断优先级
- sbit PADC = IP^5; //ADC 中断优先级
- sbit PS = IP^4; //串行中断0优先级设定位
- sbit PT1 = IP^3; //定时中断1优先级设定位
- sbit PX1 = IP^2; //外部中断1优先级设定位
- sbit PT0 = IP^1; //定时中断0优先级设定位
- sbit PX0 = IP^0; //外部中断0优先级设定位
- //sfr IPH = 0xB7; //中断优先级高位 PPCAH PLVDH PADCH PSH PT1H PX1H PT0H PX0H 0000,0000
- //sfr IP2 = 0xB5; // - - - - - - PSPI PS2 xxxx,xx00
- //sfr IPH2 = 0xB6; // - - - - - - PSPIH PS2H xxxx,xx00
- #define PPCAH 0x80
- #define PLVDH 0x40
- #define PADCH 0x20
- #define PSH 0x10
- #define PT1H 0x08
- #define PX1H 0x04
- #define PT0H 0x02
- #define PX0H 0x01
- #define PCA_InterruptFirst() PPCA = 1
- #define LVD_InterruptFirst() PLVD = 1
- #define ADC_InterruptFirst() PADC = 1
- #define UART1_InterruptFirst() PS = 1
- #define Timer1_InterruptFirst() PT1 = 1
- #define INT1_InterruptFirst() PX1 = 1
- #define Timer0_InterruptFirst() PT0 = 1
- #define INT0_InterruptFirst() PX0 = 1
- //sfr CMPCR1 = 0xE6; CMPEN CMPIF PIE NIE PIS NIS CMPOE CMPRES 00000000B
- #define CMPEN 0x80 //1: 允许比较器, 0: 禁止,关闭比较器电源
- #define CMPIF 0x40 //比较器中断标志, 包括上升沿或下降沿中断, 软件清0
- #define PIE 0x20 //1: 比较结果由0变1, 产生上升沿中断
- #define NIE 0x10 //1: 比较结果由1变0, 产生下降沿中断
- #define PIS 0x08 //输入正极性选择, 0: 选择内部P5.5做正输入, 1: 由ADCIS[2:0]所选择的ADC输入端做正输入.
- #define NIS 0x04 //输入负极性选择, 0: 选择内部BandGap电压BGv做负输入, 1: 选择外部P5.4做输入.
- #define CMPOE 0x02 //1: 允许比较结果输出到P1.2, 0: 禁止.
- #define CMPRES 0x01 //比较结果, 1: CMP+电平高于CMP-, 0: CMP+电平低于CMP-, 只读
- //sfr CMPCR2 = 0xE7; INVCMPO DISFLT LCDTY[5:0] 00001001B
- #define INVCMPO 0x80 //1: 比较器输出取反, 0: 不取反
- #define DISFLT 0x40 //1: 关闭0.1uF滤波, 0: 允许
- #define LCDTY 0x00 //0~63, 比较结果变化延时周期数
- //sfr SCON = 0x98; SM0 SM1 SM2 REN TB8 RB8 TI RI 00000000B //S1 Control
- #define S1_DoubleRate() PCON |= 0x80
- #define S1_SHIFT() SCON &= 0x3f
- #define S1_8bit() SCON = (SCON & 0x3f) | 0x40
- #define S1_9bit() SCON = (SCON & 0x3f) | 0xc0
- #define S1_RX_Enable() SCON |= 0x10
- #define S1_RX_Disable() SCON &= ~0x10
- #define TI1 TI /* 判断TI1是否发送完成 */
- #define RI1 RI /* 判断RI1是否接收完成 */
- #define SET_TI1() TI = 1 /* 设置TI1(引起中断) */
- #define CLR_TI1() TI = 0 /* 清除TI1 */
- #define CLR_RI1() RI = 0 /* 清除RI1 */
- #define S1TB8_SET() TB8 = 1 /* 设置TB8 */
- #define S1TB8_CLR() TB8 = 0 /* 清除TB8 */
- #define S1_Int_Enable() ES = 1 /* 串口1允许中断 */
- #define S1_Int_Disable() ES = 0 /* 串口1禁止中断 */
- #define S1_BRT_UseTimer1() AUXR &= ~1
- #define S1_BRT_UseTimer2() AUXR |= 1
- #define S1_USE_P30P31() P_SW1 &= ~0xc0 //UART1 使用P30 P31口 默认
- #define S1_USE_P36P37() P_SW1 = (P_SW1 & ~0xc0) | 0x40 //UART1 使用P36 P37口
- #define S1_USE_P16P17() P_SW1 = (P_SW1 & ~0xc0) | 0x80 //UART1 使用P16 P17口
- #define S1_TXD_RXD_SHORT() PCON2 |= (1<<4) //将TXD与RXD连接中继输出
- #define S1_TXD_RXD_OPEN() PCON2 &= ~(1<<4) //将TXD与RXD连接中继断开 默认
- //sfr S2CON = 0x9A; S2SM0 - S2SM2 S2REN S2TB8 S2RB8 S2TI S2RI 00000000B //S2 Control
- #define S2_MODE0() S2CON &= ~(1<<7) /* 串口2模式0,8位UART,波特率 = 定时器2的溢出率 / 4 */
- #define S2_MODE1() S2CON |= (1<<7) /* 串口2模式1,9位UART,波特率 = 定时器2的溢出率 / 4 */
- #define S2_8bit() S2CON &= ~(1<<7) /* 串口2模式0,8位UART,波特率 = 定时器2的溢出率 / 4 */
- #define S2_9bit() S2CON |= (1<<7) /* 串口2模式1,9位UART,波特率 = 定时器2的溢出率 / 4 */
- #define S2_RX_Enable() S2CON |= (1<<4) /* 允许串2接收 */
- #define S2_RX_Disable() S2CON &= ~(1<<4) /* 禁止串2接收 */
- #define TI2 (S2CON & 2) != 0 /* 判断TI2是否发送完成 */
- #define RI2 (S2CON & 1) != 0 /* 判断RI2是否接收完成 */
- #define SET_TI2() S2CON |= (1<<1) /* 设置TI2(引起中断) */
- #define CLR_TI2() S2CON &= ~(1<<1) /* 清除TI2 */
- #define CLR_RI2() S2CON &= ~1 /* 清除RI2 */
- #define S2TB8_SET() S2CON |= (1<<3) /* 设置TB8 */
- #define S2TB8_CLR() S2CON &= ~(1<<3) /* 清除TB8 */
- #define S2_Int_Enable() IE2 |= 1 /* 串口2允许中断 */
- #define S2_Int_Disable() IE2 &= ~1 /* 串口2禁止中断 */
- #define S2_USE_P10P11() P_SW2 &= ~1 /* UART2 使用P1口 默认 */
- #define S2_USE_P46P47() P_SW2 |= 1 /* UART2 使用P4口 */
- //sfr S3CON = 0xAC; S3SM0 S3ST3 S3SM2 S3REN S3TB8 S3RB8 S3TI S3RI 00000000B //S3 Control
- #define S3_MODE0() S3CON &= ~(1<<7) /* 串口3模式0,8位UART,波特率 = 定时器的溢出率 / 4 */
- #define S3_MODE1() S3CON |= (1<<7) /* 串口3模式1,9位UART,波特率 = 定时器的溢出率 / 4 */
- #define S3_8bit() S3CON &= ~(1<<7) /* 串口3模式0,8位UART,波特率 = 定时器的溢出率 / 4 */
- #define S3_9bit() S3CON |= (1<<7) /* 串口3模式1,9位UART,波特率 = 定时器的溢出率 / 4 */
- #define S3_RX_Enable() S3CON |= (1<<4) /* 允许串3接收 */
- #define S3_RX_Disable() S3CON &= ~(1<<4) /* 禁止串3接收 */
- #define TI3 (S3CON & 2) != 0 /* 判断TI3是否发送完成 */
- #define RI3 (S3CON & 1) != 0 /* 判断RI3是否接收完成 */
- #define SET_TI3() S3CON |= (1<<1) /* 设置TI3(引起中断) */
- #define CLR_TI3() S3CON &= ~(1<<1) /* 清除TI3 */
- #define CLR_RI3() S3CON &= ~1 /* 清除RI3 */
- #define S3TB8_SET() S3CON |= (1<<3) /* 设置TB8 */
- #define S3TB8_CLR() S3CON &= ~(1<<3) /* 清除TB8 */
- #define S3_Int_Enable() IE2 |= (1<<3) /* 串口3允许中断 */
- #define S3_Int_Disable() IE2 &= ~(1<<3) /* 串口3禁止中断 */
- #define S3_BRT_UseTimer3() S3CON |= (1<<6) /* BRT select Timer3 */
- #define S3_BRT_UseTimer2() S3CON &= ~(1<<6) /* BRT select Timer2 */
- #define S3_USE_P00P01() P_SW2 &= ~2 /* UART3 使用P0口 默认 */
- #define S3_USE_P50P51() P_SW2 |= 2 /* UART3 使用P5口 */
- //sfr S4CON = 0x84; S4SM0 S4ST4 S4SM2 S4REN S4TB8 S4RB8 S4TI S4RI 00000000B //S4 Control
- #define S4_MODE0() S4CON &= ~(1<<7) /* 串口4模式0,8位UART,波特率 = 定时器的溢出率 / 4 */
- #define S4_MODE1() S4CON |= (1<<7) /* 串口4模式1,9位UART,波特率 = 定时器的溢出率 / 4 */
- #define S4_8bit() S4CON &= ~(1<<7) /* 串口4模式0,8位UART,波特率 = 定时器的溢出率 / 4 */
- #define S4_9bit() S4CON |= (1<<7) /* 串口4模式1,9位UART,波特率 = 定时器的溢出率 / 4 */
- #define S4_RX_Enable() S4CON |= (1<<4) /* 允许串4接收 */
- #define S4_RX_Disable() S4CON &= ~(1<<4) /* 禁止串4接收 */
- #define TI4 (S4CON & 2) != 0 /* 判断TI3是否发送完成 */
- #define RI4 (S4CON & 1) != 0 /* 判断RI3是否接收完成 */
- #define SET_TI4() S4CON |= 2 /* 设置TI3(引起中断) */
- #define CLR_TI4() S4CON &= ~2 /* 清除TI3 */
- #define CLR_RI4() S4CON &= ~1 /* 清除RI3 */
- #define S4TB8_SET() S4CON |= 8 /* 设置TB8 */
- #define S4TB8_CLR() S4CON &= ~8 /* 清除TB8 */
- #define S4_Int_Enable() IE2 |= (1<<4) /* 串口4允许中断 */
- #define S4_Int_Disable() IE2 &= ~(1<<4) /* 串口4禁止中断 */
- #define S4_BRT_UseTimer4() S4CON |= (1<<6) /* BRT select Timer4 */
- #define S4_BRT_UseTimer2() S4CON &= ~(1<<6) /* BRT select Timer2 */
- #define S4_USE_P02P03() P_SW2 &= ~4 /* UART4 使用P0口 默认 */
- #define S4_USE_P52P53() P_SW2 |= 4 /* UART4 使用P5口 */
- //sfr AUXR = 0x8E; T0x12 T1x12 UART_M0x6 T2R T2_C/T T2x12 EXTRAM S1ST2 0000,0000 //Auxiliary Register
- #define ExternalRAM_enable() AUXR |= 2 /* 允许外部XRAM,禁止使用内部1024RAM */
- #define InternalRAM_enable() AUXR &= ~2 /* 禁止外部XRAM,允许使用内部1024RAM */
- #define S1_M0x6() AUXR |= (1<<5) /* UART Mode0 Speed is 6x Standard */
- #define S1_M0x1() AUXR &= ~(1<<5) /* default, UART Mode0 Speed is Standard */
- #define Timer0_16bitAutoReload() TMOD &= ~0x03 /* 16位自动重装 */
- #define Timer0_16bit() TMOD = (TMOD & ~0x03) | 0x01 /* 16位 */
- #define Timer0_8bitAutoReload() TMOD = (TMOD & ~0x03) | 0x02 /* 8位自动重装 */
- #define Timer0_16bitAutoRL_NoMask() TMOD |= 0x03 /* 16位自动重装不可屏蔽中断 */
- #define Timer0_Run() TR0 = 1 /* 允许定时器0计数 */
- #define Timer0_Stop() TR0 = 0 /* 禁止定时器0计数 */
- #define Timer0_Gate_INT0_P32() TMOD |= (1<<3) /* 时器0由外部INT0高电平允许定时计数 */
- #define Timer0_AsTimer() TMOD &= ~(1<<2) /* 时器0用做定时器 */
- #define Timer0_AsCounter() TMOD |= (1<<2) /* 时器0用做计数器 */
- #define Timer0_AsCounterP34() TMOD |= (1<<2) /* 时器0用做计数器 */
- #define Timer0_1T() AUXR |= (1<<7) /* Timer0 clodk = fo */
- #define Timer0_12T() AUXR &= ~(1<<7) /* Timer0 clodk = fo/12 12分频, default */
- #define Timer0_CLKO_Enable() AUXR2 |= 1 /* 允许 T0 溢出脉冲在T0(P3.5)脚输出,Fck0 = 1/2 T0 溢出率,T0可以1T或12T。 */
- #define Timer0_CLKO_Disable() AUXR2 &= ~1
- #define Timer0_CLKO_Enable_P34() AUXR2 |= 1 /* 允许 T0 溢出脉冲在T0(P3.5)脚输出,Fck0 = 1/2 T0 溢出率,T0可以1T或12T。 */
- #define Timer0_CLKO_Disable_P34() AUXR2 &= ~1
- #define Timer0_InterruptEnable() ET0 = 1 /* 允许Timer1中断.*/
- #define Timer0_InterruptDisable() ET0 = 0 /* 禁止Timer1中断.*/
- #define T0_Load(n) TH0 = (n) / 256, TL0 = (n) % 256
- #define T0_Load_us_1T(n) Timer0_AsTimer(),Timer0_1T(), Timer0_16bitAutoReload(),TH0=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)/256, TL0=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)%256
- #define T0_Load_us_12T(n) Timer0_AsTimer(),Timer0_12T(),Timer0_16bitAutoReload(),TH0=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)/256,TL0=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)%256
- #define T0_Frequency_1T_P35(n) ET0=0,Timer0_AsTimer(),Timer0_1T(),Timer0_16bitAutoReload(),TH0=(65536-(n/2+MAIN_Fosc/2)/(n))/256,TL0=(65536-(n/2+MAIN_Fosc/2)/(n))%256,AUXR2 |= bit0,TR0=1 /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define T0_Frequency_12T_P35(n) ET0=0,Timer0_AsTimer(),Timer0_12T(),Timer0_16bitAutoReload(),TH0=(65536-(n/2+MAIN_Fosc/24)/(n))/256,TL0=(65536-(n/2+MAIN_Fosc/24)/(n))%256,AUXR2 |= bit0,TR0=1 /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define Timer1_16bitAutoReload() TMOD &= ~0x30 /* 16位自动重装 */
- #define Timer1_16bit() TMOD = (TMOD & ~0x30) | 0x10 /* 16位 */
- #define Timer1_8bitAutoReload() TMOD = (TMOD & ~0x30) | 0x20 /* 8位自动重装 */
- #define Timer1_Run() TR1 = 1 /* 允许定时器1计数 */
- #define Timer1_Stop() TR1 = 0 /* 禁止定时器1计数 */
- #define Timer1_Gate_INT1_P33() TMOD |= (1<<7) /* 时器1由外部INT1高电平允许定时计数 */
- #define Timer1_AsTimer() TMOD &= ~(1<<6) /* 时器1用做定时器 */
- #define Timer1_AsCounter() TMOD |= (1<<6) /* 时器1用做计数器 */
- #define Timer1_AsCounterP35() TMOD |= (1<<6) /* 时器1用做计数器 */
- #define Timer1_1T() AUXR |= (1<<6) /* Timer1 clodk = fo */
- #define Timer1_12T() AUXR &= ~(1<<6) /* Timer1 clodk = fo/12 12分频, default */
- #define Timer1_CLKO_Enable() AUXR2 |= 2 /* 允许 T1 溢出脉冲在T1(P3.4)脚输出,Fck1 = 1/2 T1 溢出率,T1可以1T或12T。 */
- #define Timer1_CLKO_Disable() AUXR2 &= ~2
- #define Timer1_CLKO_Enable_P35() AUXR2 |= 2 /* 允许 T1 溢出脉冲在T1(P3.4)脚输出,Fck1 = 1/2 T1 溢出率,T1可以1T或12T。 */
- #define Timer1_CLKO_Disable_P35() AUXR2 &= ~2
- #define Timer1_InterruptEnable() ET1 = 1 /* 允许Timer1中断. */
- #define Timer1_InterruptDisable() ET1 = 0 /* 禁止Timer1中断. */
- #define T1_Load(n) TH1 = (n) / 256, TL1 = (n) % 256
- #define T1_Load_us_1T(n) Timer1_AsTimer(),Timer1_1T(), Timer1_16bitAutoReload(),TH1=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)/256, TL1=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)%256
- #define T1_Load_us_12T(n) Timer1_AsTimer(),Timer1_12T(),Timer1_16bitAutoReload(),TH1=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)/256,TL1=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)%256
- #define T1_Frequency_1T_P34(n) ET1=0,Timer1_AsTimer(),Timer1_1T(),Timer1_16bitAutoReload(),TH1=(65536-(n/2+MAIN_Fosc/2)/(n))/256,TL1=(65536-(n/2+MAIN_Fosc/2)/(n))%256,AUXR2 |= bit1,TR1=1 /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define T1_Frequency_12T_P34(n) ET1=0,Timer1_AsTimer(),Timer1_12T(),Timer1_16bitAutoReload(),TH1=(65536-(n/2+MAIN_Fosc/24)/(n))/256,TL1=(65536-(n/2+MAIN_Fosc/24)/(n))%256,AUXR2 |= bit1,TR1=1 /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define Timer2_Run() AUXR |= (1<<4) /* 允许定时器2计数 */
- #define Timer2_Stop() AUXR &= ~(1<<4) /* 禁止定时器2计数 */
- #define Timer2_AsTimer() AUXR &= ~(1<<3) /* 时器2用做定时器 */
- #define Timer2_AsCounter() AUXR |= (1<<3) /* 时器2用做计数器 */
- #define Timer2_AsCounterP31() AUXR |= (1<<3) /* 时器2用做计数器 */
- #define Timer2_1T() AUXR |= (1<<2) /* Timer0 clock = fo */
- #define Timer2_12T() AUXR &= ~(1<<2) /* Timer0 clock = fo/12 12分频, default */
- #define Timer2_CLKO_Enable() AUXR2 |= 4 /* 允许 T2 溢出脉冲在T1(P3.0)脚输出,Fck2 = 1/2 T2 溢出率,T2可以1T或12T。 */
- #define Timer2_CLKO_Disable() AUXR2 &= ~4
- #define Timer2_CLKO_Enable_P30() AUXR2 |= 4 /* 允许 T2 溢出脉冲在T1(P3.0)脚输出,Fck2 = 1/2 T2 溢出率,T2可以1T或12T。 */
- #define Timer2_CLKO_Disable_P30() AUXR2 &= ~4
- #define Timer2_InterruptEnable() IE2 |= (1<<2) /* 允许Timer2中断. */
- #define Timer2_InterruptDisable() IE2 &= ~(1<<2) /* 禁止Timer2中断. */
- #define T2_Load(n) TH2 = (n) / 256, TL2 = (n) % 256
- #define T2_Load_us_1T(n) Timer2_AsTimer(),Timer2_1T(), TH2=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)/256, TL2=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)%256
- #define T2_Load_us_12T(n) Timer2_AsTimer(),Timer2_12T(),TH2=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)/256,TL2=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)%256
- #define T2_Frequency_1T_P30(n) Timer2_InterruptDisable(),Timer2_AsTimer(),Timer2_1T(), TH2=(65536-(n/2+MAIN_Fosc/2)/(n))/256, TL2=(65536-(n/2+MAIN_Fosc/2)/(n))%256, Timer2_CLKO_Enable_P30(),Timer2_Run() /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define T2_Frequency_12T_P30(n) Timer2_InterruptDisable(),Timer2_AsTimer(),Timer2_12T(),TH2=(65536-(n/2+MAIN_Fosc/24)/(n))/256,TL2=(65536-(n/2+MAIN_Fosc/24)/(n))%256,Timer2_CLKO_Enable_P30(),Timer2_Run() /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define Timer3_Run() T4T3M |= (1<<3) /* 允许定时器3计数 */
- #define Timer3_Stop() T4T3M &= ~(1<<3) /* 禁止定时器3计数 */
- #define Timer3_AsTimer() T4T3M &= ~(1<<2) /* 时器3用做定时器 */
- #define Timer3_AsCounter() T4T3M |= (1<<2) /* 时器3用做计数器, P0.5为外部脉冲 */
- #define Timer3_AsCounterP05() T4T3M |= (1<<2) /* 时器3用做计数器, P0.5为外部脉冲 */
- #define Timer3_1T() T4T3M |= (1<<1) /* 1T模式 */
- #define Timer3_12T() T4T3M &= ~(1<<1) /* 12T模式, default */
- #define Timer3_CLKO_Enable() T4T3M |= 1 /* 允许T3溢出脉冲在T3(P0.4)脚输出,Fck = 1/2 T2 溢出率,T2可以1T或12T。 */
- #define Timer3_CLKO_Disable() T4T3M &= ~1 /* 禁止T3溢出脉冲在T3(P0.4)脚输出 */
- #define Timer3_CLKO_Enable_P04() T4T3M |= 1 /* 允许T3溢出脉冲在T3(P0.4)脚输出,Fck = 1/2 T2 溢出率,T2可以1T或12T。 */
- #define Timer3_CLKO_Disable_P04() T4T3M &= ~1 /* 禁止T3溢出脉冲在T3(P0.4)脚输出 */
- #define Timer3_InterruptEnable() IE2 |= (1<<5) /* 允许Timer3中断. */
- #define Timer3_InterruptDisable() IE2 &= ~(1<<5) /* 禁止Timer3中断. */
- #define T3_Load(n) TH3 = (n) / 256, TL3 = (n) % 256
- #define T3_Load_us_1T(n) Timer3_AsTimer(),Timer3_1T(), TH3=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)/256, TL3=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)%256
- #define T3_Load_us_12T(n) Timer3_AsTimer(),Timer3_12T(),TH3=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)/256,TL3=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)%256
- #define T3_Frequency_1T_P04(n) Timer3_InterruptDisable(),Timer3_AsTimer(),Timer3_1T(), TH3=(65536-(n/2+MAIN_Fosc/2)/(n))/256, TL3=(65536-(n/2+MAIN_Fosc/2)/(n))%256, Timer3_CLKO_P04_Enable,Timer3_Run() /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define T3_Frequency_12T_P04(n) Timer3_InterruptDisable(),Timer3_AsTimer(),Timer3_12T(),TH3=(65536-(n/2+MAIN_Fosc/24)/(n))/256,TL3=(65536-(n/2+MAIN_Fosc/24)/(n))%256,Timer3_CLKO_P04_Enable,Timer3_Run() /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define Timer4_Run() T4T3M |= (1<<7) /* 允许定时器4计数 */
- #define Timer4_Stop() T4T3M &= ~(1<<7) /* 禁止定时器4计数 */
- #define Timer4_AsTimer() T4T3M &= ~(1<<6) /* 时器4用做定时器 */
- #define Timer4_AsCounter() T4T3M |= (1<<6) /* 时器4用做计数器, P0.7为外部脉冲 */
- #define Timer4_AsCounterP07() T4T3M |= (1<<6) /* 时器4用做计数器, P0.7为外部脉冲 */
- #define Timer4_1T() T4T3M |= (1<<5) /* 1T模式 */
- #define Timer4_12T() T4T3M &= ~(1<<5) /* 12T模式, default */
- #define Timer4_CLKO_Enable() T4T3M |= (1<<4) /* 允许T4溢出脉冲在T4(P0.6)脚输出,Fck = 1/2 T2 溢出率,T2可以1T或12T。 */
- #define Timer4_CLKO_Disable() T4T3M &= ~(1<<4) /* 禁止T4溢出脉冲在T4(P0.6)脚输出 */
- #define Timer4_CLKO_Enable_P06() T4T3M |= (1<<4) /* 允许T4溢出脉冲在T4(P0.6)脚输出,Fck = 1/2 T2 溢出率,T2可以1T或12T。 */
- #define Timer4_CLKO_Disable_P06() T4T3M &= ~(1<<4) /* 禁止T4溢出脉冲在T4(P0.6)脚输出 */
- #define Timer4_InterruptEnable() IE2 |= (1<<6) /* 允许Timer4中断. */
- #define Timer4_InterruptDisable() IE2 &= ~(1<<6) /* 禁止Timer4中断. */
- #define T4_Load(n) TH4 = (n) / 256, TL4 = (n) % 256
- #define T4_Load_us_1T(n) Timer4_AsTimer(),Timer4_1T(), TH4=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)/256, TL4=(65536-((MAIN_Fosc/1000)*(n)+500)/1000)%256
- #define T4_Load_us_12T(n) Timer4_AsTimer(),Timer4_12T(),TH4=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)/256,TL4=(65536-((MAIN_Fosc/12000)*(n)+500)/1000)%256
- #define T4_Frequency_1T_P06(n) Timer4_InterruptDisable(),Timer4_AsTimer(),Timer4_1T(), TH4=(65536-(n/2+MAIN_Fosc/2)/(n))/256, TL4=(65536-(n/2+MAIN_Fosc/2)/(n))%256, Timer4_CLKO_P06_Enable(),Timer4_Run() /* fx=fosc/(2*M)/n, M=1 or M=12 */
- #define T4_Frequency_12T_P06(n) Timer4_InterruptDisable(),Timer4_AsTimer(),Timer4_12T(),TH4=(65536-(n/2+MAIN_Fosc/24)/(n))/256,TL4=(65536-(n/2+MAIN_Fosc/24)/(n))%256,Timer4_CLKO_P06_Enable(),Timer4_Run() /* fx=fosc/(2*M)/n, M=1 or M=12 */
- //sfr WDT_CONTR = 0xC1; //Watch-Dog-Timer Control register
- // WDT_FLAG - EN_WDT CLR_WDT IDLE_WDT PS2 PS1 PS0 xx00,0000
- #define D_WDT_FLAG (1<<7)
- #define D_EN_WDT (1<<5)
- #define D_CLR_WDT (1<<4) /* auto clear */
- #define D_IDLE_WDT (1<<3) /* WDT counter when Idle */
- #define D_WDT_SCALE_2 0
- #define D_WDT_SCALE_4 1
- #define D_WDT_SCALE_8 2 /* T=393216*N/fo */
- #define D_WDT_SCALE_16 3
- #define D_WDT_SCALE_32 4
- #define D_WDT_SCALE_64 5
- #define D_WDT_SCALE_128 6
- #define D_WDT_SCALE_256 7
- #define WDT_reset(n) WDT_CONTR = D_EN_WDT + D_CLR_WDT + D_IDLE_WDT + (n) /* 初始化WDT,喂狗 */
- //sfr PCON = 0x87; SMOD SMOD0 LVDF POF GF1 GF0 PD IDL 0001,0000 //Power Control
- //SMOD //串口双倍速
- //SMOD0
- #define LVDF (1<<5) /* P4.6低压检测标志 */
- //POF
- //GF1
- //GF0
- //#define D_PD 2 /* set 1, power down mode */
- //#define D_IDLE 1 /* set 1, idle mode */
- #define MCU_IDLE() PCON |= 1 /* MCU 进入 IDLE 模式 */
- #define MCU_POWER_DOWN() PCON |= 2 /* MCU 进入 睡眠 模式 */
- //sfr ISP_CMD = 0xC5;
- #define ISP_STANDBY() ISP_CMD = 0 /* ISP空闲命令(禁止)*/
- #define ISP_READ() ISP_CMD = 1 /* ISP读出命令 */
- #define ISP_WRITE() ISP_CMD = 2 /* ISP写入命令 */
- #define ISP_ERASE() ISP_CMD = 3 /* ISP擦除命令 */
- //sfr ISP_TRIG = 0xC6;
- #define ISP_TRIG() ISP_TRIG = 0x5A, ISP_TRIG = 0xA5 /* ISP触发命令 */
- //sfr IAP_CONTR = 0xC7; IAPEN SWBS SWRST CFAIL - WT2 WT1 WT0 0000,x000 //IAP Control Register
- #define ISP_EN (1<<7)
- #define ISP_SWBS (1<<6)
- #define ISP_SWRST (1<<5)
- #define ISP_CMD_FAIL (1<<4)
- #define ISP_WAIT_1MHZ 7
- #define ISP_WAIT_2MHZ 6
- #define ISP_WAIT_3MHZ 5
- #define ISP_WAIT_6MHZ 4
- #define ISP_WAIT_12MHZ 3
- #define ISP_WAIT_20MHZ 2
- #define ISP_WAIT_24MHZ 1
- #define ISP_WAIT_30MHZ 0
- #if (MAIN_Fosc >= 24000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_30MHZ
- #elif (MAIN_Fosc >= 20000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_24MHZ
- #elif (MAIN_Fosc >= 12000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_20MHZ
- #elif (MAIN_Fosc >= 6000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_12MHZ
- #elif (MAIN_Fosc >= 3000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_6MHZ
- #elif (MAIN_Fosc >= 2000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_3MHZ
- #elif (MAIN_Fosc >= 1000000L)
- #define ISP_WAIT_FREQUENCY ISP_WAIT_2MHZ
- #else
- #define ISP_WAIT_FREQUENCY ISP_WAIT_1MHZ
- #endif
- /* ADC Register */
- //sfr ADC_CONTR = 0xBC; ADC_POWER SPEED1 SPEED0 ADC_FLAG ADC_START CHS2 CHS1 CHS0 0000,0000 /* AD 转换控制寄存器 */
- //sfr ADC_RES = 0xBD; ADCV.9 ADCV.8 ADCV.7 ADCV.6 ADCV.5 ADCV.4 ADCV.3 ADCV.2 0000,0000 /* A/D 转换结果高8位 */
- //sfr ADC_RESL = 0xBE; ADCV.1 ADCV.0 0000,0000 /* A/D 转换结果低2位 */
- //sfr ADC_CONTR = 0xBC; //直接用MOV操作,不要用与或
- //sfr SPCTL = 0xCE; SPI控制寄存器
- // SSIG SPEN DORD MSTR CPOL CPHA SPR1 SPR0 0x00
- #define SPI_SSIG_None() SPCTL |= (1<<7) /* 1: 忽略SS脚 */
- #define SPI_SSIG_Enable() SPCTL &= ~(1<<7) /* 0: SS脚用于决定主从机 */
- #define SPI_Enable() SPCTL |= (1<<6) /* 1: 允许SPI */
- #define SPI_Disable() SPCTL &= ~(1<<6) /* 0: 禁止SPI */
- #define SPI_LSB_First() SPCTL |= (1<<5) /* 1: LSB先发 */
- #define SPI_MSB_First() SPCTL &= ~(1<<5) /* 0: MSB先发 */
- #define SPI_Master() SPCTL |= (1<<4) /* 1: 设为主机 */
- #define SPI_Slave() SPCTL &= ~(1<<4) /* 0: 设为从机 */
- #define SPI_SCLK_NormalH() SPCTL |= (1<<3) /* 1: 空闲时SCLK为高电平 */
- #define SPI_SCLK_NormalL() SPCTL &= ~(1<<3) /* 0: 空闲时SCLK为低电平 */
- #define SPI_PhaseH() SPCTL |= (1<<2) /* 1: */
- #define SPI_PhaseL() SPCTL &= ~(1<<2) /* 0: */
- #define SPI_Speed(n) SPCTL = (SPCTL & ~3) | (n) /*设置速度, 0 -- fosc/4, 1 -- fosc/16, 2 -- fosc/64, 3 -- fosc/128 */
- //sfr SPDAT = 0xCF; //SPI Data Register 0000,0000
- //sfr SPSTAT = 0xCD; //SPI状态寄存器
- // SPIF WCOL - - - - - -
- #define SPIF 0x80 /* SPI传输完成标志。写入1清0。*/
- #define WCOL 0x40 /* SPI写冲突标志。写入1清0。 */
- #define SPI_USE_P12P13P14P15() AUXR1 &= ~0x0c /* 将SPI切换到P12(SS) P13(MOSI) P14(MISO) P15(SCLK)(上电默认)。*/
- #define SPI_USE_P24P23P22P21() AUXR1 = (AUXR1 & ~0x0c) | 0x04 /* 将SPI切换到P24(SS) P23(MOSI) P22(MISO) P21(SCLK)。*/
- #define SPI_USE_P54P40P41P43() AUXR1 = (AUXR1 & ~0x0c) | 0x08 /* 将SPI切换到P54(SS) P40(MOSI) P41(MISO) P43(SCLK)。*/
- ;PCA_PWMn: 7 6 5 4 3 2 1 0
- ; EBSn_1 EBSn_0 - - - - EPCnH EPCnL
- ;B5-B2: 保留
- ;B1(EPCnH): 在PWM模式下,与CCAPnH组成9位数。
- ;B0(EPCnL): 在PWM模式下,与CCAPnL组成9位数。
- #define PWM0_NORMAL() PCA_PWM0 &= ~3 /* PWM0正常输出(默认) */
- #define PWM0_OUT_0() PCA_PWM0 |= 3 /* PWM0一直输出0 */
- #define PWM0_OUT_1() PCA_PWM0 &= ~3, CCAP0H = 0 /* PWM0一直输出1 */
- #define PWM1_NORMAL() PCA_PWM1 &= ~3 /* PWM1正常输出(默认) */
- #define PWM1_OUT_0() PCA_PWM1 |= 3 /* PWM1一直输出0 */
- #define PWM1_OUT_1() PCA_PWM1 &= ~3, CCAP1H = 0 /* PWM1一直输出1 */
- #define PWM2_NORMAL() PCA_PWM2 &= ~3 /* PWM2正常输出(默认) */
- #define PWM2_OUT_0() PCA_PWM2 |= 3 /* PWM2一直输出0 */
- #define PWM2_OUT_1() PCA_PWM2 &= ~3, CCAP2H = 0 /* PWM2一直输出1 */
- //sfr CCON = 0xD8; CF CR - - - CCF2 CCF1 CCF0 00xx,xx00 //PCA 控制寄存器。
- sbit CCF0 = CCON^0; /* PCA 模块0中断标志,由硬件置位,必须由软件清0。 */
- sbit CCF1 = CCON^1; /* PCA 模块1中断标志,由硬件置位,必须由软件清0。 */
- sbit CCF2 = CCON^2; /* PCA 模块2中断标志,由硬件置位,必须由软件清0。 */
- sbit CR = CCON^6; /* 1: 允许PCA计数器计数,必须由软件清0。*/
- sbit CF = CCON^7; /* PCA计数器溢出(CH,CL由FFFFH变为0000H)标志。PCA计数器溢出后由硬件置位,必须由软件清0。*/
- //sfr CMOD = 0xD9; CIDL - - - CPS2 CPS1 CPS0 ECF 0xxx,0000 //PCA 工作模式寄存器。
- #define PCA_IDLE_OFF() CMOD |= (1<<7) /* IDLE状态PCA停止计数。 */
- #define PCA_IDLE_ON() CMOD &= ~(1<<7) /* IDLE状态PCA继续计数。 */
- #define PCA_CLK_12T() CMOD &= ~0x0E /* PCA计数脉冲选择 fosc/12 */
- #define PCA_CLK_2T() CMOD = (CMOD & ~0x0E) + 2 /* PCA计数脉冲选择 fosc/2 */
- #define PCA_CLK_T0() CMOD = (CMOD & ~0x0E) + 4 /* PCA计数脉冲选择Timer0中断,Timer0可通过AUXR寄存器设置成工作在12T或1T模式。 */
- #define PCA_CLK_ECI() CMOD = (CMOD & ~0x0E) + 6 /* PCA计数脉冲选择从ECI/P3.4脚输入的外部时钟,最大 fosc/2。 */
- #define PCA_CLK_1T() CMOD = (CMOD & ~0x0E) + 8 /* PCA计数脉冲选择 Fosc */
- #define PCA_CLK_4T() CMOD = (CMOD & ~0x0E) + 10 /* PCA计数脉冲选择 Fosc/4 */
- #define PCA_CLK_6T() CMOD = (CMOD & ~0x0E) + 12 /* PCA计数脉冲选择 Fosc/6 */
- #define PCA_CLK_8T() CMOD = (CMOD & ~0x0E) + 14 /* PCA计数脉冲选择 Fosc/8 */
- #define PCA_INT_ENABLE() CMOD |= 1 /* PCA计数器溢出中断允许位,1---允许CF(CCON.7)产生中断。 */
- #define PCA_INT_DISABLE() CMOD &= ~1 /* PCA计数器溢出中断禁止。 */
- //sfr AUXR1 = 0xA2; S1_S1 S1_S0 CCP_S1 CCP_S0 SPI_S1 SPI_S0 - DPS 0100,0000 //Auxiliary Register 1
- #define PCA_USE_P12P11P10P37() AUXR1 &= ~0x30 /* 将PCA/PWM切换到P12(ECI) P11(CCP0) P10(CCP1) P37(CCP2)(上电默认)。 */
- #define PCA_USE_P34P35P36P37() AUXR1 = (AUXR1 & ~0x30) | 0x10 /* 将PCA/PWM切换到P34(ECI) P35(CCP0) P36(CCP1) P37(CCP2)。 */
- #define PCA_USE_P24P25P26P27() AUXR1 = (AUXR1 & ~0x30) | 0x20 /* 将PCA/PWM切换到P24(ECI) P25(CCP0) P26(CCP1) P27(CCP2)。 */
- #define DPS_SEL1() AUXR1 |= 1 /* 1:选择DPTR1。 */
- #define DPS_SEL0() AUXR1 &= ~1 /* 0:选择DPTR0(上电默认)。 */
- /* 7 6 5 4 3 2 1 0 Reset Value
- //sfr CCAPM0 = 0xDA; PWM 寄存器 - ECOM0 CAPP0 CAPN0 MAT0 TOG0 PWM0 ECCF0 x000,0000 //PCA 模块0
- //sfr CCAPM1 = 0xDB; PWM 寄存器 - ECOM1 CAPP1 CAPN1 MAT1 TOG1 PWM1 ECCF1 x000,0000 //PCA 模块1
- //sfr CCAPM2 = 0xDC; PWM 寄存器 - ECOM2 CAPP2 CAPN2 MAT2 TOG2 PWM2 ECCF2 x000,0000 //PCA 模块2
- ;ECOMn = 1: 允许比较功能。
- ;CAPPn = 1: 允许上升沿触发捕捉功能。
- ;CAPNn = 1: 允许下降沿触发捕捉功能。
- ;MATn = 1: 当匹配情况发生时,允许CCON中的CCFn置位。
- ;TOGn = 1: 当匹配情况发生时,CEXn将翻转。(CEX0/PCA0/PWM0/P3.7,CEX1/PCA1/PWM1/P3.5)
- ;PWMn = 1: 将CEXn设置为PWM输出。
- ;ECCFn = 1: 允许CCON中的CCFn触发中断。
- ;ECOMn CAPPn CAPNn MATn TOGn PWMn ECCFn
- ; 0 0 0 0 0 0 0 00H 未启用任何功能。
- ; x 1 0 0 0 0 x 20H 16位CEXn上升沿触发捕捉功能。
- ; x 0 1 0 0 0 x 10H 16位CEXn下降沿触发捕捉功能。
- ; x 1 1 0 0 0 x 30H 16位CEXn/PCAn边沿(上、下沿)触发捕捉功能。
- ; 1 0 0 1 0 0 x 48H 16位软件定时器。
- ; 1 0 0 1 1 0 x 4CH 16位高速脉冲输出。
- ; 1 0 0 0 0 1 0 42H 8位PWM。无中断
- ; 1 1 0 0 0 1 1 63H 8位PWM。低变高可产生中断
- ; 1 0 1 0 0 1 1 53H 8位PWM。高变低可产生中断
- ; 1 1 1 0 0 1 1 73H 8位PWM。低变高或高变低均可产生中断
- #define PCA0_none() CCAPM0 = 0
- #define PCA0_PWM(nbit) CCAPM0 = 0x42,PCA_PWM0 = (PCA_PWM0 & 0x0c) | ((8-nbit)<<6)
- #define PCA0_PWM_rise_int(nbit) CCAPM0 = 0x63,PCA_PWM0 = (PCA_PWM0 & 0x0c) | ((8-nbit)<<6)
- #define PCA0_PWM_fall_int(nbit) CCAPM0 = 0x53,PCA_PWM0 = (PCA_PWM0 & 0x0c) | ((8-nbit)<<6)
- #define PCA0_PWM_edge_int(nbit) CCAPM0 = 0x73,PCA_PWM0 = (PCA_PWM0 & 0x0c) | ((8-nbit)<<6)
- #define PCA0_capture_rise() CCAPM0 = (0x20 + 1)
- #define PCA0_capture_fall() CCAPM0 = (0x10 + 1)
- #define PCA0_capture_edge() CCAPM0 = (0x30 + 1)
- #define PCA0_16bit_Timer() CCAPM0 = (0x48 + 1)
- #define PCA0_High_Pulse() CCAPM0 = (0x4C + 1)
- #define PCA1_none() CCAPM1 = 0
- #define PCA1_PWM(nbit) CCAPM1 = 0x42,PCA_PWM1 = (PCA_PWM1 & 0x0c) | ((8-nbit)<<6)
- #define PCA1_PWM_rise_int(nbit) CCAPM1 = 0x63,PCA_PWM1 = (PCA_PWM1 & 0x0c) | ((8-nbit)<<6)
- #define PCA1_PWM_fall_int(nbit) CCAPM1 = 0x53,PCA_PWM1 = (PCA_PWM1 & 0x0c) | ((8-nbit)<<6)
- #define PCA1_PWM_edge_int(nbit) CCAPM1 = 0x73,PCA_PWM1 = (PCA_PWM1 & 0x0c) | ((8-nbit)<<6)
- #define PCA1_capture_rise() CCAPM1 = (0x20 + 1)
- #define PCA1_capture_fall() CCAPM1 = (0x10 + 1)
- #define PCA1_capture_edge() CCAPM1 = (0x30 + 1)
- #define PCA1_16bit_Timer() CCAPM1 = (0x48 + 1)
- #define PCA1_High_Pulse() CCAPM1 = (0x4C + 1)
- #define PCA2_none() CCAPM2 = 0
- #define PCA2_PWM(nbit) CCAPM2 = 0x42,PCA_PWM2 = (PCA_PWM2 & 0x0c) | ((8-nbit)<<6)
- #define PCA2_PWM_rise_int(nbit) CCAPM2 = 0x63,PCA_PWM2 = (PCA_PWM2 & 0x0c) | ((8-nbit)<<6)
- #define PCA2_PWM_fall_int(nbit) CCAPM2 = 0x53,PCA_PWM2 = (PCA_PWM2 & 0x0c) | ((8-nbit)<<6)
- #define PCA2_PWM_edge_int(nbit) CCAPM2 = 0x73,PCA_PWM2 = (PCA_PWM2 & 0x0c) | ((8-nbit)<<6)
- #define PCA2_capture_rise() CCAPM2 = (0x20 + 1)
- #define PCA2_capture_fall() CCAPM2 = (0x10 + 1)
- #define PCA2_capture_edge() CCAPM2 = (0x30 + 1)
- #define PCA2_16bit_Timer() CCAPM2 = (0x48 + 1)
- #define PCA2_High_Pulse() CCAPM2 = (0x4C + 1)
- /* Above is STC additional SFR or change */
- typedef unsigned char u8;
- typedef unsigned int u16;
- typedef unsigned long u32;
- #define NOP1() _nop_()
- #define NOP2() NOP1(),NOP1()
- #define NOP3() NOP2(),NOP1()
- #define NOP4() NOP3(),NOP1()
- #define NOP5() NOP4(),NOP1()
- #define NOP6() NOP5(),NOP1()
- #define NOP7() NOP6(),NOP1()
- #define NOP8() NOP7(),NOP1()
- #define NOP9() NOP8(),NOP1()
- #define NOP10() NOP9(),NOP1()
- #define NOP11() NOP10(),NOP1()
- #define NOP12() NOP11(),NOP1()
- #define NOP13() NOP12(),NOP1()
- #define NOP14() NOP13(),NOP1()
- #define NOP15() NOP14(),NOP1()
- #define NOP16() NOP15(),NOP1()
- #define NOP17() NOP16(),NOP1()
- #define NOP18() NOP17(),NOP1()
- #define NOP19() NOP18(),NOP1()
- #define NOP20() NOP19(),NOP1()
- #define NOP21() NOP20(),NOP1()
- #define NOP22() NOP21(),NOP1()
- #define NOP23() NOP22(),NOP1()
- #define NOP24() NOP23(),NOP1()
- #define NOP25() NOP24(),NOP1()
- #define NOP26() NOP25(),NOP1()
- #define NOP27() NOP26(),NOP1()
- #define NOP28() NOP27(),NOP1()
- #define NOP29() NOP28(),NOP1()
- #define NOP30() NOP29(),NOP1()
- #define NOP31() NOP30(),NOP1()
- #define NOP32() NOP31(),NOP1()
- #define NOP33() NOP32(),NOP1()
- #define NOP34() NOP33(),NOP1()
- #define NOP35() NOP34(),NOP1()
- #define NOP36() NOP35(),NOP1()
- #define NOP37() NOP36(),NOP1()
- #define NOP38() NOP37(),NOP1()
- #define NOP39() NOP38(),NOP1()
- #define NOP40() NOP39(),NOP1()
- #define NOP(N) NOP##N()
- #define P0n_standard(bitn) P0M1 &= ~(bitn), P0M0 &= ~(bitn) /* 00 */
- #define P0n_push_pull(bitn) P0M1 &= ~(bitn), P0M0 |= (bitn) /* 01 */
- #define P0n_pure_input(bitn) P0M1 |= (bitn), P0M0 &= ~(bitn) /* 10 */
- #define P0n_open_drain(bitn) P0M1 |= (bitn), P0M0 |= (bitn) /* 11 */
- #define P1n_standard(bitn) P1M1 &= ~(bitn), P1M0 &= ~(bitn)
- #define P1n_push_pull(bitn) P1M1 &= ~(bitn), P1M0 |= (bitn)
- #define P1n_pure_input(bitn) P1M1 |= (bitn), P1M0 &= ~(bitn)
- #define P1n_open_drain(bitn) P1M1 |= (bitn), P1M0 |= (bitn)
- #define P2n_standard(bitn) P2M1 &= ~(bitn), P2M0 &= ~(bitn)
- #define P2n_push_pull(bitn) P2M1 &= ~(bitn), P2M0 |= (bitn)
- #define P2n_pure_input(bitn) P2M1 |= (bitn), P2M0 &= ~(bitn)
- #define P2n_open_drain(bitn) P2M1 |= (bitn), P2M0 |= (bitn)
- #define P3n_standard(bitn) P3M1 &= ~(bitn), P3M0 &= ~(bitn)
- #define P3n_push_pull(bitn) P3M1 &= ~(bitn), P3M0 |= (bitn)
- #define P3n_pure_input(bitn) P3M1 |= (bitn), P3M0 &= ~(bitn)
- #define P3n_open_drain(bitn) P3M1 |= (bitn), P3M0 |= (bitn)
- #define P4n_standard(bitn) P4M1 &= ~(bitn), P4M0 &= ~(bitn)
- #define P4n_push_pull(bitn) P4M1 &= ~(bitn), P4M0 |= (bitn)
- #define P4n_pure_input(bitn) P4M1 |= (bitn), P4M0 &= ~(bitn)
- #define P4n_open_drain(bitn) P4M1 |= (bitn), P4M0 |= (bitn)
- #define P5n_standard(bitn) P5M1 &= ~(bitn), P5M0 &= ~(bitn)
- #define P5n_push_pull(bitn) P5M1 &= ~(bitn), P5M0 |= (bitn)
- #define P5n_pure_input(bitn) P5M1 |= (bitn), P5M0 &= ~(bitn)
- #define P5n_open_drain(bitn) P5M1 |= (bitn), P5M0 |= (bitn)
- #define P6n_standard(bitn) P6M1 &= ~(bitn), P6M0 &= ~(bitn)
- #define P6n_push_pull(bitn) P6M1 &= ~(bitn), P6M0 |= (bitn)
- #define P6n_pure_input(bitn) P6M1 |= (bitn), P6M0 &= ~(bitn)
- #define P6n_open_drain(bitn) P6M1 |= (bitn), P6M0 |= (bitn)
- #define P7n_standard(bitn) P7M1 &= ~(bitn), P7M0 &= ~(bitn)
- #define P7n_push_pull(bitn) P7M1 &= ~(bitn), P7M0 |= (bitn)
- #define P7n_pure_input(bitn) P7M1 |= (bitn), P7M0 &= ~(bitn)
- #define P7n_open_drain(bitn) P7M1 |= (bitn), P7M0 |= (bitn)
- //sfr INT_CLKO = 0x8F; //附加的 SFR WAKE_CLKO (地址:0x8F)
- 7 6 5 4 3 2 1 0 Reset Value
- - EX4 EX3 EX2 - T2CLKO T1CLKO T0CLKO 0000,0000B
- b6 - EX4 : 外中断INT4允许
- b5 - EX3 : 外中断INT3允许
- b4 - EX2 : 外中断INT2允许
- b2 - T1CLKO : 允许 T2 溢出脉冲在P3.0脚输出,Fck1 = 1/2 T1 溢出率
- b1 - T1CLKO : 允许 T1 溢出脉冲在P3.4脚输出,Fck1 = 1/2 T1 溢出率
- b0 - T0CLKO : 允许 T0 溢出脉冲在P3.5脚输出,Fck0 = 1/2 T0 溢出率
- #define LVD_InterruptEnable() ELVD = 1
- #define LVD_InterruptDisable() ELVD = 0
- //sfr WKTCL = 0xAA; //STC11F\10和STC15系列 唤醒定时器低字节
- //sfr WKTCH = 0xAB; //STC11F\10和STC15系列 唤醒定时器高字节
- // B7 B6 B5 B4 B3 B2 B1 B0 B7 B6 B5 B4 B3 B2 B1 B0
- // WKTEN S11 S10 S9 S8 S7 S6 S5 S4 S3 S2 S1 S0 n * 560us
- #define WakeTimerDisable() WKTCH &= 0x7f /* WKTEN = 0 禁止睡眠唤醒定时器 */
- #define WakeTimerSet(scale) WKTCL = (scale) % 256,WKTCH = (scale) / 256 | 0x80 /* WKTEN = 1 允许睡眠唤醒定时器 */
- //sfr CLK_DIV = 0x97; //Clock Divder 系统时钟分频 - - - - - CLKS2 CLKS1 CLKS0 xxxx,x000
- #define SYSTEM_CLK_1T() CLK_DIV &= ~0x07 //default
- #define SYSTEM_CLK_2T() CLK_DIV = (CLK_DIV & ~0x07) | 1
- #define SYSTEM_CLK_4T() CLK_DIV = (CLK_DIV & ~0x07) | 2
- #define SYSTEM_CLK_8T() CLK_DIV = (CLK_DIV & ~0x07) | 3
- #define SYSTEM_CLK_16T() CLK_DIV = (CLK_DIV & ~0x07) | 4
- #define SYSTEM_CLK_32T() CLK_DIV = (CLK_DIV & ~0x07) | 5
- #define SYSTEM_CLK_64T() CLK_DIV = (CLK_DIV & ~0x07) | 6
- #define SYSTEM_CLK_128T() CLK_DIV = CLK_DIV | 7
- #define MCLKO_P54_None() CLK_DIV &= ~0xc0 /* 主时钟不输出 */
- #define MCLKO_P54_DIV1() CLK_DIV = (CLK_DIV & ~0xc0) | 0x40 /* 主时钟不分频输出 */
- #define MCLKO_P54_DIV2() CLK_DIV = (CLK_DIV & ~0xc0) | 0x80 /* 主时钟2分频输出 */
- #define MCLKO_P54_DIV4() CLK_DIV = CLK_DIV | 0xc0 /* 主时钟4分频输出 */
- #define MCLKO_P34_None() CLK_DIV &= ~0xc0 /* 主时钟不输出 */
- #define MCLKO_P34_DIV1() CLK_DIV = (CLK_DIV & ~0xc0) | 0x40 /* 主时钟不分频输出 */
- #define MCLKO_P34_DIV2() CLK_DIV = (CLK_DIV & ~0xc0) | 0x80 /* 主时钟2分频输出 */
- #define MCLKO_P34_DIV4() CLK_DIV = CLK_DIV | 0xc0 /* 主时钟4分频输出 */
- //sfr BUS_SPEED = 0xA1; //Stretch register - - - - - - EXRTS1 EXRTSS0 xxxx,xx10
- #define BUS_SPEED_1T() BUS_SPEED = 0
- #define BUS_SPEED_2T() BUS_SPEED = 1
- #define BUS_SPEED_4T() BUS_SPEED = 2
- #define BUS_SPEED_8T() BUS_SPEED = 3
- /* interrupt vector */
- #define INT0_VECTOR 0
- #define TIMER0_VECTOR 1
- #define INT1_VECTOR 2
- #define TIMER1_VECTOR 3
- #define UART1_VECTOR 4
- #define ADC_VECTOR 5
- #define LVD_VECTOR 6
- #define PCA_VECTOR 7
- #define UART2_VECTOR 8
- #define SPI_VECTOR 9
- #define INT2_VECTOR 10
- #define INT3_VECTOR 11
- #define TIMER2_VECTOR 12
- #define INT4_VECTOR 16
- #define UART3_VECTOR 17
- #define UART4_VECTOR 18
- #define TIMER3_VECTOR 19
- #define TIMER4_VECTOR 20
- #define CMP_VECTOR 21
- #define PWM_VECTOR 22
- #define PWMFD_VECTOR 23
- #define TRUE 1
- #define FALSE 0
- #define PolityLow 0 //低优先级中断
- #define PolityHigh 1 //高优先级中断
- #define MCLKO_None 0
- #define MCLKO_DIV1 1
- #define MCLKO_DIV2 2
- #define MCLKO_DIV4 3
- #define ENABLE 1
- #define DISABLE 0
- #define STC15F_L2K08S2 8
- #define STC15F_L2K16S2 16
- #define STC15F_L2K24S2 24
- #define STC15F_L2K32S2 32
- #define STC15F_L2K40S2 40
- #define STC15F_L2K48S2 48
- #define STC15F_L2K56S2 56
- #define STC15F_L2K60S2 60
- #define IAP15F_L2K61S2 61
- #endif
复制代码 |
