*程序功能:STC15W404AS,DHT11读取
*AUTHOR:BY LSK
/********************定义数据*************************/
#include <STC15F2K60S2.H>
#include <intrins.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 无符号8位整型变量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符号8位整型变量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 无符号16位整型变量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符号16位整型变量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 无符号32位整型变量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符号32位整型变量 */
typedef float F32; /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double F64; /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
#define Data_0_time 4
sbit RT_IO = P3^3 ;//P3.3脚外部中断1
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U8 outdata[5]; //定义发送的字节数
U8 indata[5];
U8 count, count_r=0;
U8 str[5]={"DATA:"};
U16 U16temp1,U16temp2;
SendData(U8 *a)
outdata[0] = a[0];
outdata[1] = a[1];
outdata[2] = a[2];
outdata[3] = a[3];
outdata[4] = a[4];
count = 1;
SBUF=outdata[0];
void Delay(U16 j)
U8 i;
for(;j>0;j--)
for(i=0;i<27;i++);
void Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!RT_IO)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(RT_IO)U8temp=1;
U8FLAG=2;
while((RT_IO)&&U8FLAG++);
//超时则跳出for循环
if(U8FLAG==1)break;
//判断数据位是0还是1 如果高电平高过预定0高电平值则数据位为 1
U8comdata<<=1;
U8comdata|=U8temp; //0
//-----湿度读取子程序 ------------
void RH(void)
//主机拉低18ms
RT_IO=0;
Delay(180);
RT_IO=1;
//总线由上拉电阻拉高 主机延时20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主机设为输入 判断从机响应信号
RT_IO=1;
//判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
if(!RT_IO) //T !
U8FLAG=2;
//判断从机是否发出 80us 的低电平响应信号是否结束
U8FLAG=2;
//判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
//数据接收状态
COM();
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
RT_IO=1;
//数据校验
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
void RSINTR() interrupt 4 using 2
U8 InPut3;
if(TI==1) //发送中断
TI=0;
if(count!=5) //发送完5位数据
SBUF= outdata[count];
count++;
if(RI==1) //接收中断
InPut3=SBUF;
indata[count_r]=InPut3;
count_r++;
RI=0;
if (count_r==5)//接收完4位数据
//数据接收完毕处理。
count_r=0;
str[0]=indata[0];
str[1]=indata[1];
str[2]=indata[2];
str[3]=indata[3];
str[4]=indata[4];
P0=0;
/*----------串口发数据------------------------------------*/
U8 i,j;
//uchar str[6]={"RS232"};
/* 系统初始化 */
SCON = 0x50; //8位数据,可变波特率
AUXR |= 0x01; //串口1选择定时器2为波特率发生器
AUXR |= 0x04; //定时器2时钟为Fosc,即1T
T2L = 0xE0; //设定定时初值
T2H = 0xFE; //设定定时初值
AUXR |= 0x10; //启动定时器2
ES = 1;
EA = 1; // 打开所以中断
TI = 0;
RI = 0;
SendData(str) ; //发送到串口
Delay(1); //延时100US(12M晶振)
//调用温湿度读取子程序
RH();
//串口显示程序
str[0]=U8RH_data_H;
str[1]=U8RH_data_L;
str[2]=U8T_data_H;
str[3]=U8T_data_L;
str[4]=U8checkdata;
//读取模块数据周期不易小于 2S
Delay(10000);
