飞思卡尔TPMS芯片规格书
FXTH870x6 Tire Pressure Monitor Sensor
FXTH870x6引脚图如下:
The FXTH870x6 family is comprised of the following functions all within the
same package.
Features
• Pressure sensor with one of two calibrated pressure ranges
— 100 - 450 kPa
— 100 - 900 kPa
• Temperature sensor
• Optional XZ- or Z-axis accelerometer with adjustable offset option
• Voltage reference measured by ADC10
• Six-channel, 10-bit analog-to-digital converter (ADC10) with two external
I/O inputs
• 8-bit MCU
— S08 Core with SIM and interrupt
— 512 RAM
— 8K FLASH (in addition to 8K providing factory firmware and trim
data)
— 64-byte, low-power, parameter registers
完整的pdf格式文档51黑下载地址(共页):
FXTH870x6.pdf
(1.21 MB, 下载次数: 13)
