查看: 1076|回复: 2
如何AHDL编写4 bit Latch电路
ID:140371 发表于 2023-1-31 18:49 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
请问先进 如何用AHDL编写 4 bit Latch  电路 ,
ID:155507 发表于 2023-2-2 08:11 | 只看该作者
这是将锁存器的输入连接到称为 data_in 的输入线的 AHDL 代码,
锁存器的输出到称为 data_out 的输出线,以及到输入的使能线
称为 latch_enable:
下面是指定八位锁存器的方法:
  1. Latch
  2. A latch in AHDL has two inputs – D and En, and one output Q. When En is low, the output
  3. Q does not change. When En is high, the output Q is equal to the input D. Thus, when En is
  4. low, it will hold the value which was on the D input when En went from high to low. To use
  5. a latch in AHDL, declare it in the VARIABLE section of the program:
  6. VARIABLE
  7. A : LATCH;
  8. will define a one-bit latch. To specify what should on the D input of A, use A.d. To specify
  9. what should on the En input of A, use A.ena. To use the Q output, refer to A.q.
  10. Here is the way to specify an eight-bit latch:
  11. VARIABLE
  12. A[7..0] : LATCH;
  13. Here is AHDL code to connect the inputs of the latch to input lines called data_in, the
  14. outputs of the latch to output lines called data_out, and the the enable lines to an input
  15. called latch_enable:
  16. SUBDESIGN my_latch
  17. (
  18. data_in[7..0] : INPUT;
  19. latch_enable : INPUT;
  20. data_out[7..0] : OUTPUT;
  21. )
  22. VARIABLE
  23. A[7..0] : LATCH;
  24. BEGIN
  25. A[].d = data_in[];
  26. A[].ena = latch_enable;
  27. data_out[] = A[].q;
  28. END;
ID:94031 发表于 2023-2-1 14:25 | 只看该作者
为什么非要AHDL,用VHDL或Verilog HDL不行吗,后两者既通用资料还多。
