输出的功能是:有加速键,减速键,启动停止,按下启动一个点击先启动5秒后第二个电机启动,按下停止后两个电机同时停止。
#include <MsTimer2.h>
#include <EEPROM.h>
#define STOP 255
int key1=1;
int key2=2;
int key3=3;
int key4=4;
int btn_start=2;
int btn_stop=3;
int btn_speedup=4;
int btn_speeddown=7;
int pwm1=5;
int pwm2=6;
int pwm3=9;
int pwm4=10;
byte speed_;
byte delay_ms;
bool flag_btn1;
void setup()
// delay(100);
pinMode(3,INPUT_PULLUP);
pinMode(4,INPUT_PULLUP);
pinMode(2,INPUT_PULLUP);
pinMode(7,INPUT_PULLUP);
pinMode(8,INPUT_PULLUP);
pinMode(12,INPUT_PULLUP);
pinMode(pwm1,OUTPUT);
pinMode(pwm2,OUTPUT);
pinMode(pwm3,OUTPUT);
pinMode(pwm4,OUTPUT);
pinMode(9,OUTPUT);//PWM3
Serial.begin(9600);
delay_ms=EEPROM.read(1);
MsTimer2::set((int)delay_ms*100, onTimer); //设置中断,每1000ms进入一次中断服务程序 onTimer()
//////////////////////////////////////2-启动 3-停止 4-加速 5-减速
speed_=EEPROM.read(0);
attachInterrupt( digitalPinToInterrupt(2), start_all, FALLING);
attachInterrupt( digitalPinToInterrupt(3), stop_all, FALLING);
analogWrite(5,STOP);
analogWrite(6,STOP);
analogWrite(9,STOP);
Serial.println(speed_);
Serial.println(delay_ms*100);
delay(100);
flag_btn1=false;
///////////////////////////全部停止
void speed_up()
if(speed_<=245)
speed_+=10;
analogWrite(6,speed_);
analogWrite(5,speed_);
analogWrite(9,speed_);
delay(100);
while(!digitalRead(4));
void speed_down()
if(speed_>=10)
speed_-=10;
speed_=0;
delay(100);
while(!digitalRead(7));
void stop_all()
flag_btn1=false;
delay(100);
while(!digitalRead(3));
///////////////////////////全部启动
void start_all()
flag_btn1=true;
MsTimer2::start();
delay(100);
while(!digitalRead(2));
void onTimer()
MsTimer2::stop();
// Serial.print("timer ");
// Serial.println(tick++);
void loop()
if(digitalRead(4)==LOW)
if(speed_<=245)
speed_=speed_+10;
speed_=255;
EEPROM.write(0, speed_);
delay(100);
while(digitalRead(4)==LOW);
if(digitalRead(7)==LOW)
if(speed_>=10)
speed_=speed_-10;
speed_=0;
delay(100);
while(digitalRead(7)==LOW);
if(digitalRead(8)==LOW)
if(delay_ms<50)
delay_ms++;
delay_ms=50;
MsTimer2::set(delay_ms*100, onTimer);
EEPROM.write(1, delay_ms);
delay(100);
while(digitalRead(8)==LOW);
if(digitalRead(12)==LOW)
if(delay_ms>1)
delay_ms--;
delay_ms=0;
delay(100);
while(digitalRead(12)==LOW);
