vch
- #include <Keypad.h>
- #include <LiquidCrystal.h>
- //d7--d4,12 11 10 9 e-8 rs-7 1234--A2--A5 5678--2354
- LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
- // 2. Keypad Pins
- const byte Rows = 4;
- const byte Cols = 4;
- char keys[Rows][Cols] =
- {'1', '2', '3', '+'},
- {'4', '5', '6', '-'},
- {'7', '8', '9', '*'},
- {'C', '0', '=', '/'}
- byte rowPins[Rows] = {A2, A3, A4, A5};
- byte colPins[Cols] = {2, 3, 4, 5};
- Keypad customKeypad = Keypad(makeKeymap(keys), rowPins, colPins, Rows, Cols);
- // 3. Dot Button
- int dot = A0;
- int dotFlag = 0;
- int dotButton = 0;
- // 4. Calculator Operators
- float num1, num2, fraction;
- float total;
- char operation, button;
- // 5. Loading Setup
- char input[16];
- int n = 1750;
- void setup()
- // Initialize dot button as input to Arduino
- pinMode(dot, INPUT);
- // Initialize LCD Size
- lcd.begin(16, 2);
- // LCD Loading Setup Begin
- lcd.clear();
- lcd.setCursor(3, 0);
- lcd.print("LOADING...");
- for (int i = 0; i < 16; i++)
- lcd.setCursor(i, 1);
- lcd.write(255);
- delay(50);
- lcd.clear();
- lcd.setCursor(1, 0);
- lcd.print("Simple Arduino");
- lcd.setCursor(3, 1);
- lcd.print("Calculator");
- delay(n);
- lcd.clear();
- lcd.setCursor(0, 0);
- lcd.print("Done By Students");
- lcd.setCursor(2, 1);
- lcd.print("Meznan Bahri");
- delay(n);
- lcd.clear();
- lcd.print("Dareen Zamzami");
- lcd.print("Joud Mannaa");
- delay(n);
- lcd.clear();
- lcd.print("Samira Laihabi");
- lcd.print("& Rana Johar");
- delay(n);
- lcd.clear();
- // LCD Loading Setup End
- void loop()
- // First while loop for num1.
- while (1)
- dotButton = digitalRead(dot);
- button = customKeypad.getKey();
- if (button == 'C')
- dotFlag = 0;
- num1 = 0;
- num2 = 0;
- fraction = 0;
- total = 0;
- operation = 0;
- lcd.clear();
- else if (dotButton == LOW)
- dotFlag = 1;
- else if (button >= '0' && button <= '9')
- if (dotFlag == 0)
- num1 = num1 * 10 + (button - '0');
- lcd.print(num1);
- else if (dotFlag == 1)
- fraction = (button - '0');
- num1 = num1 + (fraction / 10);
- lcd.print(num1);
- dotFlag++;
- else if (dotFlag == 2)
- num1 = num1 + (fraction / 100);
- lcd.print(num1);
- dotFlag++;
- else if (button == '-' || button == '+' || button == '*' || button == '/')
- operation = button;
- dotFlag = 0;
- lcd.setCursor(0, 1);
- lcd.print(operation);
- break;
- // Second while loop for num2.
- while (1)
- dotFlag = 0;
- num1 = 0;
- num2 = 0;
- fraction = 0;
- total = 0;
- operation = 0;
- lcd.clear();
- break;
- dotFlag = 1;
- if (dotFlag == 0)
- num2 = num2 * 10 + (button - '0');
- lcd.setCursor(1, 1);
- lcd.print(num2);
- num2 = num2 + (fraction / 10);
- lcd.print(num2);
- dotFlag++;
- num2 = num2 + (fraction / 100);
- lcd.print(num2);
- dotFlag++;
- if (button == '=')
- domath();
- break;
- // Third while loop for ensuring C button is executed after while loop 2.
- while (1)
- dotFlag = 0;
- num1 = 0;
- num2 = 0;
- fraction = 0;
- total = 0;
- operation = 0;
- lcd.clear();
- break;
- void domath()
- switch (operation)
- case '+':
- total = num1 + num2;
- break;
- case '-':
- total = num1 - num2;
- break;
- case '/':
- total = num1 / num2;
- break;
- case '*':
- total = num1 * num2;
- break;
- lcd.print('=');
- if (operation == '/' && num2 == 0)
- lcd.print("ERROR 0 DIV");
- else
- lcd.print(total);
复制代码 |
