查看: 1944|回复: 1
薄膜传感器(足型)基于Arduino源程序
ID:503763 发表于 2019-4-3 01:18 | 显示全部楼层 |阅读模式
int Dpin = 2;
int Apin=0;
int val;
int data;
int A=7;
int B=8;
int C=9;
int channel=0;//0,1,5
int a;
int b;
int c;
int aa;
int bb;
int cc;
void setup()
  pinMode(Dpin, INPUT);
  pinMode(Apin,INPUT);
    pinMode(A, OUTPUT);
    pinMode(B, OUTPUT);
    pinMode(C, OUTPUT);
    Serial.begin(9600);         //设置波特率为9600
void loop()
  while(Serial.read()>= 0){};
  if(channel>7) channel=0;
  if(channel==0)
     a=0;
     aa=LOW;
     b=0;
     bb=LOW;
     c=0;
     cc=LOW;
   else if(channel==1)
     a=1;
     aa=HIGH;
     b=0;
     bb=LOW;
     c=0;
     cc=LOW;
   else if(channel==2)
     a=0;
     aa=LOW;
     b=1;
     bb=HIGH;
     c=0;
     cc=LOW;
   else if(channel==3)
     a=1;
     aa=HIGH;
     b=1;
     bb=HIGH;
     c=0;
     cc=LOW;
   else if(channel==4)
     a=0;
     aa=LOW;
     b=0;
     bb=LOW;
     c=1;
     cc=HIGH;
   else if(channel==5)
     a=1;
     aa=HIGH;
     b=0;
     bb=LOW;
     c=1;
     cc=HIGH;
   else if(channel==6)
     a=0;
     aa=LOW;
     b=1;
     bb=HIGH;
     c=1;
     cc=HIGH;
   else if(channel==7)
     a=1;
     aa=HIGH;
     b=1;
     bb=HIGH;
     c=1;
     cc=HIGH;
   digitalWrite(C,cc);
   digitalWrite(B,bb);
   digitalWrite(A,aa);
   delay(10);
   data=analogRead(Apin);
   val = digitalRead(Dpin);
   Serial.print(channel);
   Serial.print(' ');
   Serial.print(val);
   Serial.print(' ');
   Serial.println(data);
   //delay(50);
    channel++;
ID:1 发表于 2019-4-3 03:39 | 显示全部楼层
