查看: 3425|回复: 0
MM32 eMiniBoard开发板片内温度测量与显示
ID:776997 发表于 2020-6-17 23:02 | 显示全部楼层 |阅读模式
1.使用GPIO口模拟I2C接口
MM32 eMiniBoard开发板的例程中提供了一个LED灯闪烁程序,通过它我们可以学习控制GPIO口定义输出口及输出高低电平信号的方法,
据此可用GPIO口来模拟I2C接口以控制该接口形式的OLED显示屏,该OLED显示屏具有占用引脚少,显示信息量较多的特点。
在引脚的分配上,用PB6来连接OLED屏的SCK引脚,用PB7来连接OLED屏的SDA引脚,为此其输出高低的定义为:
#define OLED_SCLK_Set()  GPIO_SetBits(GPIOB,GPIO_Pin_6)         //PB13
#define OLED_SCLK_Clr()  GPIO_ResetBits(GPIOB,GPIO_Pin_6)
#define OLED_SDIN_Set()  GPIO_SetBits(GPIOB,GPIO_Pin_7)         //PB14
#define OLED_SDIN_Clr()  GPIO_ResetBits(GPIOB,GPIO_Pin_7)
相应的OLED显示屏的初始化函数为:
  1. void OLED_Init(void)
  2. {
  3.     GPIO_InitTypeDef  GPIO_InitStructure;
  4.     RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  5.     GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_6|GPIO_Pin_7;
  6.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  7.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  8.     GPIO_Init(GPIOB, &GPIO_InitStructure);
  9.     OLED_SCLK_Set();
  10.     OLED_SDIN_Set();
  11.     delay_ms(800);
  12.     OLED_WR_Byte(0xAE,OLED_CMD);//--display off
  13.     OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
  14.     OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
  15.     OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
  16.     OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
  17.     OLED_WR_Byte(0x81,OLED_CMD); // contract control
  18.     OLED_WR_Byte(0xFF,OLED_CMD);//--128
  19.     OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
  20.     OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
  21.     OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
  22.     OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
  23.     OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
  24.     OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
  25.     OLED_WR_Byte(0x00,OLED_CMD);//
  26.     OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
  27.     OLED_WR_Byte(0x80,OLED_CMD);//
  28.     OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
  29.     OLED_WR_Byte(0x05,OLED_CMD);//
  30.     OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
  31.     OLED_WR_Byte(0xF1,OLED_CMD);//
  32.     OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
  33.     OLED_WR_Byte(0x12,OLED_CMD);//
  34.     OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
  35.     OLED_WR_Byte(0x30,OLED_CMD);//
  36.     OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
  37.     OLED_WR_Byte(0x14,OLED_CMD);//
  38.     OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
  39. }
2. OLED屏显示驱动
在完成功能引脚定义及初始化的基础下,要实现具体的字符及数值的显示,需相关函数的配合,关键的函数为:
  1. void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
  2. {
  3.             unsigned char c=0,i=0;
  4.             c=chr-' ';
  5.             if(x>Max_Column-1){x=0;y=y+2;}
  6.             if(Char_Size ==16)
  7.             {
  8.                         OLED_Set_Pos(x,y);
  9.                         for(i=0;i<8;i++)
  10.                         OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
  11.                         OLED_Set_Pos(x,y+1);
  12.                         for(i=0;i<8;i++)
  13.                         OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
  14.              }
  15.              else {
  16.                          OLED_Set_Pos(x,y);
  17.                          for(i=0;i<6;i++)
  18.                          OLED_WR_Byte(F6x8[c][i],OLED_DATA);
  19.              }
  20. }
  21. uint32_t oled_pow(uint8_t m,uint8_t n)
  22. {
  23.         uint32_t result=1;
  24.         while(n--)result*=m;
  25.         return result;
  26. }
  27.
  28. void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size2)
  29. {
  30.         uint8_t t,temp;
  31.         uint8_t enshow=0;
  32.         for(t=0;t<len;t++)
  33.         {
  34.                 temp=(num/oled_pow(10,len-t-1))%10;
  35.                 if(enshow==0&&t<(len-1))
  36.                 {
  37.                         if(temp==0)
  38.                         {
  39.                                 OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
  40.                                 continue;
  41.                         }else enshow=1;
  42.
  43.                 }
  44.                 OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
  45.         }
  46. }
  47. void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
  48. {
  49.         unsigned char j=0;
  50.         while (chr[j]!='\0')
  51.         {           OLED_ShowChar(x,y,chr[j],Char_Size);
  52.                      x+=8;
  53.                     if(x>120){x=0;y+=2;}
  54.                     j++;
  55.         }
  56. }
3.显示功能的测试
为了测试OLED屏的显示功能,其主函数如下:
  1. int main(void)
  2. {
  3.                    delay_init();
  4.                    OLED_Init();
  5.                    OLED_Clear();
  6.                    OLED_ShowString(0,0,"MM32L073 TEST",16);
  7.                    OLED_ShowString(0,2,"OLED Display",16);
  8.                    OLED_ShowString(0,4,"jinglixixi",16);
  9.                    OLED_ShowString(0,6,"2020.5.22",16);
  10.                    while(1);
  11. }
相应的显示效果如图1所示,后面就可以为其添加具体的应用功能。
1 显示效果
4.温度测量与显示
在例程中存在一个利用A/D转换测量片内温度的程序,参考该程序的设计,我们可以将其改造成一个利用OLED屏来显示温度值。
实现图2显示效果的主程序如下:
  1. int main(void)
  2. {
  3.     u16 ADCVAL;
  4.     float Temp;
  5.     u32 Tem;
  6.     delay_init();
  7.     uart_initwBaudRate(9600);
  8.     OLED_Init();
  9.     OLED_Clear();
  10.     OLED_ShowString(0,0,"MM32L073 TEST",16);
  11.     OLED_ShowString(0,2,"Temp Display",16);
  12.     ADC1_SingleChannel( ADC_Channel_10);
  13.     while(1)
  14.     {
  15.         ADCVAL=Get_Adc_Average(ADC_Channel_10,5);
  16.         Temp=27.0+(ADCVAL-1800)/5.96;
  17.         Tem=Temp;
  18.         printf("Temp=%.2f \r\n",Temp);
  19.         OLED_ShowString(0,6,"Temp=     C",16);
  20.         OLED_ShowNum(40,6,Tem,4,16);
  21.         delay_ms(1000);
  22.     }
  23. }
2 显示效果
