//晶振11.0592 //灯光在单片机控制之下完成由亮到暗的逐渐变化,感觉像是在呼吸 //本例在51hei-5型开发板上实现了一个数码管和一个led灯一起实现呼吸效果 //文件下载:http://www.51hei.com/f/fxd.rar #include<reg52.h> #define uint unsigned int #define uchar unsigned char sbit D1=P0^7; uchar sr; uchar jf; uchar code table[]={ 0,1,2,3,4,5,6,7,8,9,10, 11,12,13,14,15,16,17,18, 19,20,21,22,23,24,25,26,27, 28,29,30,31,32,33,34,35,36, 37,38,39,40,41,42,43,44,45, 46,47,48,49}; void light(uchar num); void delay(uint z); void main() { //设置计数器 //选取计数方式1 TMOD = 0x11; //给计数器写初值 TH0 = 0; TL0 = 0; //////////////////// //操作单片机 //开启CPU中断 EA = 1; /////////////////// //开启定时器T0位中断 ET0 = 1; //开启计数器 TR0 = 1; //操作二极管 P1=0; while(1) { if(sr<50) light(sr); else sr=0; } } //子函数 void light(uchar num) { uchar tme; D1 = 0; tme = table[num]; delay(tme); D1 = 1; delay(49-tme); } //中断函数 void time () interrupt 1 { //自变量自加 if (jf<2) { jf++; TH0 =0; TL0 = 0; } if (jf==2) { //写初值 jf=0; TH0 = 254; TL0 = 254; sr++; } } void delay(uint z) { uint x,y; for(x=10;x>0;x--) for(y=z;y>0;y--); }
