CODE:
程序功能:
LCD液晶显示屏显示时钟并且可以修改时间
#include<reg52.h>
sbit K1=P1^0;//设置三个独立键盘
sbit K2=P1^3;
sbit K3=P1^5;
sbit lcdwrite=P2^5;
sbit lcddatecommand=P2^6;
sbit lcde=P2^7;
uchar code firstline[]="2013-06-03";
uchar code secondline[]="00-00-00";
uchar i;
uchar hour,minutes,seconds;
uchar count,num;
uchar cnt;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=0;y<=112;y++)
void write_command(uchar command)
lcddatecommand=0;
lcdwrite=0;
P0=command;
delay(1);
lcde=1;
delay(1);
lcde=0;
void write_date(uchar date)
lcddatecommand=1;
lcdwrite=0;
P0=date;
delay(1);
lcde=1;
delay(1);
lcde=0;
void LCDinit()
lcde=0;
write_command(0x38);//设置16*2显示,5*7点阵,8位数据接口
write_command(0x0f);//设置开显示,不显示光标
write_command(0x06);// 写一个字符后地址指针加1
write_command(0x80);
for(i=0;i<10;i++)
write_date(firstline[i]);
delay(1);
write_command(0x80+0x40);
for(i=0;i<8;i++)
write_date(secondline[i]);
delay(1);
void Time0init()
TMOD=0x01;//开启定时器1
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void Clockinit()
hour=0;
minutes=0;
seconds=0;
count=0;
num=0;
void display(uchar hour,uchar minutes,uchar seconds)//接收并发送数据到液晶屏幕
uchar hourge,hourshi,minutesshi,minutesge,secondsshi,secondsge;
hourshi=hour/10;
hourge=hour%10;
write_date(hourshi+48);
delay(1);
write_date(hourge+48);
delay(1);
minutesshi=minutes/10;
minutesge=minutes%10;
write_command(0x80+0x43);
write_date(minutesshi+48);
delay(1);
write_date(minutesge+48);
delay(1);
secondsshi=seconds/10;
secondsge=seconds%10;
write_command(0x80+0x46);
write_date(secondsshi+48);
delay(1);
write_date(secondsge+48);
delay(1);
void revise()
if(K1==0)
delay(5);
if(K1==0)
cnt++;//计数第几次按下
TR0=0;
while(!K1);
delay(5);
while(!K1);
if(cnt==1)//第一次按下,调整秒钟,调整时秒钟有光标闪烁
if(K2==0)
delay(5);
if(K2==0)
seconds++;
if(seconds==60)
seconds=0;
while(!K2);
delay(5);
while(!K2);
if(K3==0)
delay(5);
if(K3==0)
seconds--;
if(seconds==-1)//here is a bug
seconds=59;
while(!K3);
delay(5);
while(!K3);
if(cnt==2)//第二次按下,调整分钟,调整时秒钟有光标闪烁
if(K2==0)
delay(5);
if(K2==0)
minutes++;
if(minutes==60)
minutes=0;
while(!K2);
delay(5);
while(!K2);
if(K3==0)
delay(5);
if(K3==0)
minutes--;
if(minutes==-1)//here is a bug
minutes=59;
while(!K3);
delay(5);
while(!K3);
if(cnt==3)//第三次按下,调整时钟,调整时秒钟有光标闪烁
if(K2==0)
delay(5);
if(K2==0)
hour++;
if(hour==24)
hour=0;
while(!K2);
delay(5);
while(!K2);
if(K3==0)
delay(5);
if(K3==0)
hour--;
if(hour==-1)//here is a bug
hour=23;
while(!K3);
delay(5);
while(!K3);
if(cnt==4)
TR0=1;
cnt=0;
LCDinit();
Time0init();
Clockinit();
revise();
display(hour,minutes,seconds);
void Time0() interrupt 1
count++;
if(count==20)
count=0;
seconds++;
if(seconds==60)
seconds=0;
minutes++;
if(minutes==60)
minutes=0;
hour++;
if(hour==24)
hour=0;
