专注电子技术学习与研究
用89C51驱动nRf905收发C源代码
作者:未知   来源:不详   点击数:  更新时间:2013年12月27日   【字体:
#include <reg51.h>
#include <intrins.h>
#define uint  unsigned int
#define WC      0x00            // Write configuration register command
#define RC      0x10            // Read  configuration register command
#define WTP     0x20            // Write TX Payload  command
#define RTP     0x21            // Read  TX Payload  command
#define WTA     0x22            // Write TX Address  command
#define RTA     0x23            // Read  TX Address  command
#define RRP     0x24            // Read  RX Payload  command
typedef struct RFConfig
    uchar n;
    uchar buf[10];
}RFConfig;
code RFConfig RxTxConf =
    10,
    0x01, 0x0c, 0x44, 0x20, 0x20, 0xcc, 0xcc, 0xcc,0xcc, 0x58
// The content of this struct is nRF905's initialize data.
// CH_NO=1;433MHZ;Normal Opration,No Retrans;RX,TX Address is 4 Bytes
// RX TX Payload Width is 32 Bytes;Disable Extern Clock;Fosc=16MHZ
// 8 Bits CRC And enable
uchar data TxBuf[32];
uchar data RxBuf[32];
uchar bdata DATA_BUF;
sbit    flag    =DATA_BUF^7;
sbit    flag1   =DATA_BUF^0;
sbit    TX_EN   =P2^6;
sbit    TRX_CE  =P2^5;
sbit    PWR_UP  =P2^4;
sbit    MISO    =P2^3;
sbit    MOSI    =P2^2;
sbit    SCK     =P2^1;
sbit    CSN     =P2^0;
sbit    AM      =P3^2;
sbit    DR      =P3^3;
sbit    CD      =P3^5;
void InitIO(void);              // Initialize IO port
void Inituart(void);            // initialize 232 uart
void Config905(void);           // Config nRF905 module
void SetTxMode(void);           // Set nRF905 in Tx mode
void SetRxMode(void);           // Set nRF905 in Rx mode
void TxPacket(void);            // Send data by nRF905
void RxPacket(void);            // Recive data by nRF905
void SpiWrite(uchar);           // Write data to nRF905
uchar SpiRead(void);            // Read data to nRF905
void Delay(uchar n);            // Delay 100us
void Scankey(void);             // Scan key
void TxData (uchar x);          // Send key_value to CRT display
//function main();
void main(void)
    InitIO();                   // Initialize IO port
    Inituart();                 // initialize 232 uart
    Config905();                // Config nRF905 module
    SetTxMode();                // Set Tx Mode
    TxPacket();                 // Transmit Tx buffer data
    Delay(500);                 // delay for led light
    P0=0xff;                    // led close
    SetRxMode();                // Set nRF905 in Rx mode
    while(1)                    // circulation
        Scankey();              // Scan key
        if (DR)                 // If recive data ready...
            RxPacket();         // ... recive data
//function InitIO();
void InitIO(void)
    P0=0x0f;                    // led light
    CSN=1;                      // Spi  disable
    SCK=0;                      // Spi clock line init high
    DR=1;                       // Init DR for input
    AM=1;                       // Init AM for input
    PWR_UP=1;                   // nRF905 power on
    TRX_CE=0;                   // Set nRF905 in standby mode
    TX_EN=0;                    // set radio in Rx mode
//function Inituart();
void Inituart(void)
    TMOD = 0x20;                //timer1 working mode 1
    TL1 = 0xfd;                 //f7=9600 for 16mhz Fosc,and ...
    TH1 = 0xfd;                 //...fd=19200 for 11.0592mhz Fosc
    SCON = 0xd8;                //uart mode 3,ren==1
    PCON = 0x80;                //smod=0
    TR1 = 1;                    //start timer1
//function Config905();
    uchar i;
    CSN=0;                      // Spi enable for write a spi command
    SpiWrite(WC);               // Write config command
    for (i=0;i<RxTxConf.n;i++)   // Write configration words
        SpiWrite(RxTxConf.buf[i]);
    CSN=1;                      // Disable Spi
//function Delay100us();Delay 100us
void Delay(uchar n)
    uint i;
    while(n--)
    for(i=0;i<80;i++);
//function SpiWrite();
void SpiWrite(uchar  byte)
    uchar i;
    DATA_BUF=byte;              // Put function's parameter into a bdata variable
    for (i=0;i<8;i++)            // Setup byte circulation bits
        if (flag)               // Put DATA_BUF.7 on data line
            MOSI=1;
            MOSI=0;
        SCK=1;                  // Set clock line high
        DATA_BUF=DATA_BUF<<1; // Shift DATA_BUF
        SCK=0;                  // Set clock line low
//function SpiRead();
uchar SpiRead(void)
    uchar i;
        DATA_BUF=DATA_BUF<<1; // Right shift DATA_BUF
        if (MISO)
            flag1=1;            // Read data
            flag1=0;
    return DATA_BUF;            // Return function parameter
//function TxPacket();
void TxPacket(void)
    uchar i;
    //Config905();
    SpiWrite(WTP);              // Write payload command
    for (i=0;i<32;i++)
        SpiWrite(TxBuf[i]);     // Write 32 bytes Tx data
    Delay(1);
    SpiWrite(WTA);              // Write address command
    for (i=0;i<4;i++)            // Write 4 bytes address
        SpiWrite(RxTxConf.buf[i+5]);
    TRX_CE=1;                   // Set TRX_CE high,start Tx data transmission
    Delay(1);                   // while (DR!=1);
    TRX_CE=0;                   // Set TRX_CE low
//function RxPacket();
void RxPacket(void)
    uchar i,xx;
    SpiWrite(RRP);              // Read payload command
    for (i=0;i<32;i++)
        RxBuf[i]=SpiRead();     // Read data and save to buffer
    CSN=1;                      // Disable spi
    while(DR||AM);
    P0= RxBuf[0];               // Buffer[0] output from P0 port...
    TRX_CE=1;
    xx=(RxBuf[0]>>4)&0x0f;
    TxData(xx);
    Delay(500);                 // ...light led
    P0=0xff;                    // Close led
//function SetTxMode();
    TX_EN=1;
    TRX_CE=0;
    Delay(1);                   // delay for mode change(>=650us)
//function SetRxMode();
    TX_EN=0;
    TRX_CE=1;
//Functon Scankey();
void Scankey()
    uchar Temp,xx;
    P0=0xff;
    Temp=P0&0x0f;               // Read key value from port P0
    if (Temp!=0x0f)
    {   Delay(10);
        if (Temp!=0x0f)
            xx=Temp;
            Temp=Temp<<4;     // Left shift 4 bits
            TxBuf[0]=Temp;      // Turn On the LED
            P0=Temp;            // Save to Tx buffer[0]
            TxData (xx);
            Delay(500);         // Delay for LED light
            P0=0xff;            // Close LED display
            SetRxMode();        // Set Rx Mode
            while((P0&0x0f)!=0x0f);
//Function TxData ();
    SBUF=x;
    while(TI==0);
        TI=0;
关闭窗口
相关文章
