专注电子技术学习与研究
数码管动态扫描三种实现方法
作者:寒竹子   来源:本站原创   点击数:  更新时间:2014年03月21日   【字体:
 本程序所用的原理图下载: 点这里 ,单片机芯片使用的stc89c51;找到数码管部分的原理图即可.这是一整个单片机开发板的电路图其他的忽略.
以下是3个程序的源码:
/**********利用定时器定时50毫秒动态扫描数码管***********/
*功能:定时器T1实现数码管动态扫瞄123456(if)
*作者:徐冉
*日期:2013-06-12-22:10
*备注:不同的方法实现显示设备的动态扫描,节约能耗
/****************AT89C52-RC MCU*************/
/****************51hei开发板*************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
//段选数据编码表
uchar code table[] = {
       0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F  //"9"
//位选数据编码表
uchar code table1[] = {
     0xfe,
     0xfd,
     0xfb,
     0xf7,
     0xef,
     0xdf
uchar j = 1, counter = 0;
//延时程序
void display()
 dula = 1;
 P0 = table[j++];
 dula = 0;
 if(j >= 7)
  j = 1;
//刷新程序
void refrash()
 static uchar i = 0;
 if(0 == i)
  wela = 1;
  P0 = table1[0];
  wela = 0;
 if(1 == i)
  wela = 1;
  P0 = table1[1];
  wela = 0;
 if(2 == i)
  wela = 1;
  P0 = table1[2];
  wela = 0;
 if(3 == i)
  wela = 1;
  P0 = table1[3];
  wela = 0;
 if(4 == i)
  wela = 1;
  P0 = table1[4];
  wela = 0;
 if(5 == i)
  wela = 1;
  P0 = table1[5];
  wela = 0;
 i++;
 if(i >= 6)
  i = 0;
//定时器T1初始化
void init()
 P0 = 0x00;//关闭数码管显示
 TMOD = 0x11;
 TH1 = 0xFC; //T1定时1毫秒
 TL1 = 0x66;
 TR1 = 1;
 EA = 1;
 ET1 = 1;
//主程序
void main(void)
 init();
  if(counter == 50)
   counter = 0;
   display();//显示
   refrash();//刷新
//T1中断服务程序
void timer1_int() interrupt 3
  TH1 = 0xFC;
   TL1 = 0x66;
  counter++;
*功能:定时器T1实现数码管动态扫瞄123456(switch case)
*作者:徐冉
*日期:2013-06-12-21:50
#include <reg52.h>
sbit wela = P2^7;
sbit dula = P2^6;
//段选数据编码表
       0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F  //"9"
//位选数据编码表
     0xfe,
     0xfd,
     0xfb,
     0xf7,
     0xef,
     0xdf
//延时程序
void display()
 dula = 1;
 P0 = table[j++];
 dula = 0;
 if(j >= 7)
  j = 1;
//刷新程序
void refrash()
  static uchar i = 0;
  switch(i)
    case 0: wela = 1; P0 = table1[i]; wela = 0; i++;
   break;
    case 1: wela = 1; P0 = table1[i]; wela = 0; i++;
   break;
    case 2: wela = 1; P0 = table1[i]; wela = 0; i++;
   break;
    case 3: wela = 1; P0 = table1[i]; wela = 0; i++;
   break;
    case 4: wela = 1; P0 = table1[i]; wela = 0; i++;
   break;
    case 5: wela = 1; P0 = table1[i]; wela = 0; i++;
   break;
   default: break;
  if(i >= 6)
   i = 0;
//定时器T1初始化
void init()
 P0 = 0x00;//关闭数码管显示
 TMOD = 0x11;
 TL1 = 0x66;
 TR1 = 1;
 EA = 1;
 ET1 = 1;
//主程序
void main(void)
 init();
  if(counter == 50)
   counter = 0;
   display();//显示
   refrash();//刷新
//T1中断服务程序
  TH1 = 0xFC;
   TL1 = 0x66;
  counter++;
/**********利用延时函数定时50毫秒动态扫描数码管***********/
*功能:延时函数实现数码管动态扫瞄123456
*作者:徐冉
*日期:2013-06-12-20:50
#include <reg52.h>
sbit wela = P2^7;
sbit dula = P2^6;
//段选编码表
    0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F  //"9"
//位选编码表
      0xfe,
      0xfd,
      0xfb,
      0xf7,
      0xef,
      0xdf
//毫秒延时程序
void delay(uint xms)
 uint x, y;
 for(x = 0; x < xms; x++)
   for(y = 0; y < 110; y++);
//动态扫描程序
void display()
 static uchar i = 0;//静态变量i
 dula = 1;
 P0 = table[i+1];//段选数据
 dula = 0;
 P0 = 0xff;//消影
 wela = 1;
 P0 = table1[i]; //位选数据
 wela = 0;
 delay(50);//延时50毫秒
 i++;
 if(i >= 6)
  i = 0;
//主程序
void main(void)
 P0 = 0x00;//开始时关闭所有数码管显示
  display();
关闭窗口
相关文章
