MSP430G2553板LED在P1.0和P1.6,和P1.3连着一个按钮开关,可以对其进行中断编程。
#include "MSP430G2553.h"
int ms,k,i;
char jj[]={
0x01,0x00,0x40,0x00,0x01,0x00,0x40,0x00,0x40,0x00,0x01,
0x00,0x40,0x00,0x01,0x00,0x41,0x00,0x41,0x00,0x41,0x00
void delay(int ms)
while(ms--)
for(i=0;i<120;i++);
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
P1DIR |=BIT6+BIT0;
P1IE |=BIT3;
P1IES |=BIT3;
P1IFG &=~BIT3;
_BIS_SR(GIE);
for(k=0;k<22;k++)
P1OUT=jj[k];
delay(300);
#pragma vector=PORT1_VECTOR
__interrupt void zhansan(void)
for(k=0;k<5;k++)
P1OUT |=BIT6+BIT0;
delay(1000);
P1OUT &=~(BIT6+BIT0);
delay(1000);
P1IFG &=~BIT3;
IAR调试msp430时出现警告提示:
The stack plug-n failed to set a breakpoint on "main". The Stack window will not be able to display stack contents. (You can change this setting in the Tool>Options dialog box.)需要进行以下配置:
1. iar->options->linker->output->format;
选择 Debug information for c-SPY选项
2. iar->Tools->options->stack->去掉选项“stack pointer(s) not valid until program reaches”
