c程序如下:
# include <stdio.h>
# include <malloc.h>
struct BTNode
char data;
struct BTNode * pLchild;
struct BTNode * pRchild;
struct BTNode * creat_BTree(void);
void pro_traverse(struct BTNode * pT);
void mid_traverse(struct BTNode * pT);
void rear_traverse(struct BTNode * pT);
int main(void)
struct BTNode * pT = creat_BTree();
printf("二叉树前序遍历结果如下:\n");
pro_traverse(pT);
printf("\n");
printf("二叉树中序遍历结果如下:\n");
mid_traverse(pT);
printf("\n");
printf("二叉树后序遍历结果如下:\n");
rear_traverse(pT);
printf("\n");
return 0;
if(pT != NULL)
printf("%c ",pT->data);
if(NULL != pT->pLchild)
pro_traverse(pT->pLchild);
if(NULL != pT->pRchild)
pro_traverse(pT->pRchild);
if(pT != NULL)
mid_traverse(pT->pLchild);
mid_traverse(pT->pRchild);
if(pT != NULL)
rear_traverse(pT->pLchild);
rear_traverse(pT->pRchild);
struct BTNode * pA = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pB = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pC = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pD = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pE = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pF = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pI = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pG = (struct BTNode *)malloc(sizeof(struct BTNode));
struct BTNode * pH = (struct BTNode *)malloc(sizeof(struct BTNode));
pA->data = 'A';
pB->data = 'B';
pC->data = 'C';
pD->data = 'D';
pE->data = 'E';
pF->data = 'F';
pG->data = 'G';
pH->data = 'H';
pI->data = 'I';
pA->pLchild = pB;
pA->pRchild = pE;
pB->pLchild = pC;
pB->pRchild = pD;
pC->pLchild = pC->pRchild = NULL;
pD->pLchild = pD->pRchild = NULL;
pE->pLchild = pF;
pE->pRchild = pI;
pF->pLchild = pF->pRchild = NULL;
pI->pLchild = pG;
pI->pRchild = pH;
pG->pLchild = pG->pRchild = NULL;
pH->pLchild = pH->pRchild = NULL;
return pA;
运行结果如下:
二叉树前序遍历结果如下:
运行结果如下:
二叉树前序遍历结果如下:
A B C D E F I G H
二叉树中序遍历结果如下:
C B D A F E G I H
二叉树后序遍历结果如下:
C D B F G H I E A
Press any key to continue
