专注电子技术学习与研究
freertos创建函数xTaskCreate( vIntegerGenerator, IntGen, 200, NULL, 1, NULL)
作者:未知   来源:布冬冬 的空间   点击数:  更新时间:2014年08月16日   【字体:
signed portBASE_TYPE xTaskGenericCreate( pdTASK_CODE pxTaskCode, const signed char * const pcName, unsigned short usStackDepth, void *pvParameters, unsigned portBASE_TYPE uxPriority, xTaskHandle *pxCreatedTask, portSTACK_TYPE *puxStackBuffer, const xMemoryRegion * const xRegions )
signed portBASE_TYPE xReturn;
tskTCB * pxNewTCB;
 configASSERT( pxTaskCode );
 configASSERT( ( uxPriority < configMAX_PRIORITIES ) );
 //分配任务TCB和堆栈
 pxNewTCB = prvAllocateTCBAndStack( usStackDepth, puxStackBuffer );
 if( pxNewTCB != NULL )
  portSTACK_TYPE *pxTopOfStack;
  #if( portUSING_MPU_WRAPPERS == 1 )
   portBASE_TYPE xRunPrivileged;
   if( ( uxPriority & portPRIVILEGE_BIT ) != 0U )
    xRunPrivileged = pdTRUE;
    xRunPrivileged = pdFALSE;
   uxPriority &= ~portPRIVILEGE_BIT;
  #endif
//判断堆栈增长方式是否是由高到低增长
  #if( portSTACK_GROWTH < 0 )
   pxTopOfStack = pxNewTCB->pxStack + ( usStackDepth - ( unsigned short ) 1 );
//保持堆栈为字节对齐?
   pxTopOfStack = ( portSTACK_TYPE * ) ( ( ( portPOINTER_SIZE_TYPE ) pxTopOfStack ) & ( ( portPOINTER_SIZE_TYPE ) ~portBYTE_ALIGNMENT_MASK  ) );
   configASSERT( ( ( ( unsigned long ) pxTopOfStack & ( unsigned long ) portBYTE_ALIGNMENT_MASK ) == 0UL ) );
  #else
   pxTopOfStack = pxNewTCB->pxStack;
   configASSERT( ( ( ( unsigned long ) pxNewTCB->pxStack & ( unsigned long ) portBYTE_ALIGNMENT_MASK ) == 0UL ) );
   pxNewTCB->pxEndOfStack = pxNewTCB->pxStack + ( usStackDepth - 1 );
  #endif
  //TCB初始化
  prvInitialiseTCBVariables( pxNewTCB, pcName, uxPriority, xRegions, usStackDepth );
   pxNewTCB->pxTopOfStack = pxPortInitialiseStack( pxTopOfStack, pxTaskCode, pvParameters, xRunPrivileged );
  #else
//汇编语言对堆栈进行初始化
   pxNewTCB->pxTopOfStack = pxPortInitialiseStack( pxTopOfStack, pxTaskCode, pvParameters );
  #endif
  portALIGNMENT_ASSERT_pxCurrentTCB( ( ( ( unsigned long ) pxNewTCB->pxTopOfStack & ( unsigned long ) portBYTE_ALIGNMENT_MASK ) == 0UL ) );
  if( ( void * ) pxCreatedTask != NULL )
   *pxCreatedTask = ( xTaskHandle ) pxNewTCB;
  taskENTER_CRITICAL();
   uxCurrentNumberOfTasks++;//更新系统任务数
   if( pxCurrentTCB == NULL )
    pxCurrentTCB =  pxNewTCB;
    if( uxCurrentNumberOfTasks == ( unsigned portBASE_TYPE ) 1 )
     //如果当前任务数为1的话,则证明米有初始化就绪列表,等待列表,挂起列表等
    //初始化就绪列表的时候,定义优先级为一个数据数组,则每个数据数组的元素代表一个优先级
//其他列表则没有这么复杂 直接定义 不区分优先级
     prvInitialiseTaskLists();
    //比较,将当前最高的优先级赋给pxCurrentTCB
    if( xSchedulerRunning == pdFALSE )
     if( pxCurrentTCB->uxPriority <= uxPriority )
   //更新uxTopUsedPriority,方便查询的时候直接从uxTopUsedPriority开始查询
   if( pxNewTCB->uxPriority > uxTopUsedPriority )
    uxTopUsedPriority = pxNewTCB->uxPriority;
   #if ( configUSE_TRACE_FACILITY == 1 )
    pxNewTCB->uxTCBNumber = uxTCBNumber;
   #endif
   uxTCBNumber++;
//将任务添加到就绪列表中。当任务处于阻塞态的时候,从就绪列表中删除,加入到阻塞列表中。
   prvAddTaskToReadyQueue( pxNewTCB );
   xReturn = pdPASS;
   traceTASK_CREATE( pxNewTCB );
  taskEXIT_CRITICAL();
  xReturn = errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY;
  traceTASK_CREATE_FAILED();
 if( xReturn == pdPASS )
  if( xSchedulerRunning != pdFALSE )
   if( pxCurrentTCB->uxPriority < uxPriority )
    portYIELD_WITHIN_API();
 return xReturn;
关闭窗口
相关文章
