专注电子技术学习与研究
NEC制式红外线解码程序
作者:xiaoyes   来源:本站原创   点击数:  更新时间:2010年08月25日   【字体:
此程序在STC89C52上实验通过!
晶振11.05926,
占用资源,外部中断1,
LCD1602,显示解码!
串口通讯波特率4800KBS;
闫伟东,提示,在中端中不可以用while(p3_2);
否则,不能顺利跳出终端!
#include <AT89X52.H>
#include "LCD.h"
#define uchar  unsigned char
//void Delay(unsigned int i);
void chuangkou(void);
void unint0 (void);
void senddata(unsigned char outdata);
unsigned char yandata[]=
 '0',
 '1',
 '2',
 '3',
 '4',
 '5',
 '6',
 '7',
 '8',
 '9',
 'A',
 'B',
 'C',
 'D',
 'E',
 'F'
unsigned char Iid[4]={0,0,0,0};
void main(void)
 LCD1602();
 Init_Lcd();
 unint0();
 chuangkou();
 P3_2=1;
 senddata('1');
  Display_LCD_Byte(0,0,'I');
  Display_LCD_Byte(0,1,'D');
  Display_LCD_Byte(0,2,':');
  Display_LCD_Byte(0,5,'0');
  Display_LCD_Byte(0,6,'X');
     Display_LCD_Byte(0,7,yandata[ Iid[0] / 16] );
  Display_LCD_Byte(0,8,yandata[ Iid[0] % 16] );
  Display_LCD_Byte(1,0,'D');
  Display_LCD_Byte(1,1,'A');
  Display_LCD_Byte(1,2,'T');
  Display_LCD_Byte(1,3,'A');
  Display_LCD_Byte(1,4,':');
  Display_LCD_Byte(1,5,'0');
  Display_LCD_Byte(1,6,'X');
  Display_LCD_Byte(1,7,yandata[ Iid[2] / 16] );
  Display_LCD_Byte(1,8,yandata[ Iid[2] % 16] );
/*void Delay(unsigned int i)
 while(-- i);
 TMOD = 0X20;// JI SHU QI 1
 TH1=0XFA; //11.0592, 4800KPS
 TL1 =0XFA;
 TR1=1;  //QI DONG
 SCON=0X50; //
 PCON=0X00; //BU JIA BEI
void unint0 (void)
 EA=1;
 EX0=1;
 IT0=1;
 SBUF=outdata;
 while(!TI);
 TI=0;
void INT_0() interrupt 0 using 1
 unsigned char id[4]={0,0,0,0};
 unsigned char cishu0,cishu1,cishu2;
 EX0=0;
 for(cishu0=0;cishu0<10;cishu0++)
 Delay(100);
 if(P3_2) goto exit;
 if(!P3_2)
 Delay(534);
 while(!P3_2);//等待高电平 gou qu
 for(cishu1=0;cishu1< 4 ; cishu1 ++)
 for(cishu2=0;cishu2 < 8 ; cishu2 ++)
 while(!P3_2);//等待该gao电平开始延时,判断高低
 Delay(90);
 if(P3_2)
   id[cishu1]|= 0x01 << cishu2;
  Delay(100);
  //while(P3_2);在解码时千万不要有这样的口令
/* else
  id[cishu1]&= 0xfe << cishu2;
 if(id[0]!=~id[1]) goto exit;
 if(id[0]!=0x02) goto exit;
 if(id[2]!=~id[3]) goto exit;
 senddata(id[0]);
// senddata(id[1]);
 senddata(id[2]);//数据码
// senddata(id[3]);//数据码饭吗
 for(cishu0=0;cishu0<200;cishu0++)
 P2_0=~P2_0;
 Delay(50);
 Iid[0]=id[0];
 Iid[2]=id[2];
exit:
// while(!P3_2);
 EX0=1;
关闭窗口
相关文章
